Next value in msg max 1 higher than last
You should not have Apply mode separately set.
Ok ive taken out these standardsetting and ill take a look if its works^^
//Edit
It worked the last 10 minutes and in Debug-Output are higher values that not going to Database!
Thx for ya help Colin!
Do you ever get a value coming in that is just a little smaller than the last good one? If so then the node will pass that through as it only looks for absolute difference, it does not care about which one is the larger.
