Ok, it works only if i set "auto" the dimension of template node.
Setting to "auto" the template node dimension, I have another problem: I can't put in the same row the two button. Could you help me?
Here attach the flow. thanks a lot
[{"id":"3d62e5e4.f1c52a","type":"tab","label":"Flow 4","disabled":false,"info":""},{"id":"d5bbd082.f5d26","type":"comment","z":"3d62e5e4.f1c52a","name":"OUTPUT","info":"","x":346.6666564941406,"y":175,"wires":[]},{"id":"114967f4.0f0428","type":"ui_template","z":"3d62e5e4.f1c52a","group":"c007f24.583101","name":"OUTStyle","order":10,"width":"1","height":"1","format":"<style>\n .outButtonON {\n\t\t/*color : rgb(46, 46, 46);*/\n\t\t/*background-color: rgb (255, 222, 121);*/\n\t\t/*padding: 0px;*/\n\t\t/*margin: 0px 0px 0px 0px;*/\n\t\t/*width: 75px;*/\n\t\t/*height: 75px;*/\n\t\t/*padding: 0px;*/\n\t\t/*text-align: left;*/\n\t\t/*text-decoration:none;*/\n\t\t/*border: none;*/\n\t\t/*outline: none;*/\n\t\t/*margin-bottom: 5px;*/\n\t\t/*margin-left: -10px;*/\n\t\t/*margin-top: 16px;*/\n\t\t/*position: relative !important; */\n\t\t/*position: absolute;*/\n\t\t/*top: 3px;*/\n\t\t/*left: 0px;*/\n\t\t/*position-anchor: 0px 0px;*/\n\t\tborder: 5px solid green;\n\t} \n \n .outButtonOFF {\n\t\t/*color : rgb(46, 46, 46);*/\n\t\t/*background-color: rgb (255, 222, 121);*/\n\t\t/*padding: 0px;*/\n\t\t/*margin: 0px 0px 0px 0px;*/\n\t\t/*width: 75px;*/\n\t\t/*height: 75px;*/\n\t\t/*padding: 0px;*/\n\t\t/*text-align: left;*/\n\t\t/*text-decoration:none;*/\n\t\t/*border: none;*/\n\t\t/*outline: none;*/\n\t\t/*margin-bottom: 5px;*/\n\t\t/*margin-left: -10px;*/\n\t\t/*margin-top: 16px;*/\n\t\t/*position: relative !important; */\n\t\t/*position: absolute;*/\n\t\t/*top: 3px;*/\n\t\t/*left: 0px;*/\n\t\t/*position-anchor: 0px 0px;*/\n\t\tborder: 0px solid red;\n\t} \n \n .OutName { \n font: bold 22px sans-serif; \n fill: darkgreen; \n /*text-align: center;*/\n /*text-transform: lowercase;*/\n }\n</style>","storeOutMessages":true,"fwdInMessages":true,"templateScope":"local","x":348.0952568054199,"y":216.90484046936035,"wires":[[]]},{"id":"4ed91b15.08c314","type":"ui_template","z":"3d62e5e4.f1c52a","group":"c007f24.583101","name":"OUT1","order":1,"width":"0","height":"0","format":"<div>\n\t<md-button ng-show=\"msg.Out1ShowButton==='enabled'\" class=\"md-raised {{msg.Out1OnorOff}}\" ng-click=\"send({Out1Toggle:'changeStatus'})\">\n\t<svg width=\"120\" height=\"120\">\n\t\t <image ng-if=\"msg.Out1OnorOff==='outButtonON'\" x=\"22\" y=\"0\" width=\"77\" height=\"90\" preserveAspectRatio=\"xMidYMid meet\"/>\n\t\t\t<image ng-if=\"msg.Out1OnorOff==='outButtonOFF'\" x=\"25\" y=\"-4\" width=\"65\" height=\"95\" preserveAspectRatio=\"xMidYMid meet\"/>\n\t\t <text x=\"15\" y=\"110\" class=\"OutName\">{{msg.Out1Label}}</text>\n\t\t</svg>\t\n\t</md-button>\n</div>\n\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":881.1467456817627,"y":398.6751012802124,"wires":[["d7a3b5d7.5251a8"]]},{"id":"87e717b1.66a1f8","type":"function","z":"3d62e5e4.f1c52a","name":"Output1MNG","func":"var Out1OnorOff = flow.get('flow_Out1OnorOff') || 'outButtonOFF';\nvar out1Flag = global.get(\"global_out1Flag\");\nvar out1Name = global.get(\"global_out1Name\");\nvar Out1ShowButton = global.get(\"global_Out1ShowButton\")|| 'inhibit';\nvar OutputShowOrHide = global.get(\"global_OutputShowOrHide\"); //settato dall'utente dall'impostazioni dashboard\n\n\nif ((Out1ShowButton===\"inhibit\")&&(OutputShowOrHide===\"OutputShow\")&&(out1Flag===\"true\"))\n{\n Out1ShowButton = \"enabled\";\n}\nelse\n{\n if (Out1ShowButton===\"enabled\")\n {\n if ((OutputShowOrHide===\"OutputHide\")||(out1Flag===\"false\"))\n {\n Out1ShowButton = \"inhibit\";\n }\n }\n}\n\nglobal.set(\"global_Out1ShowButton\", Out1ShowButton);\n\n\nmsg.Out1ShowButton = Out1ShowButton;\nmsg.Out1OnorOff = Out1OnorOff;\nmsg.Out1Label = out1Name;\n\n\nreturn msg;\n","outputs":1,"noerr":0,"x":632.5398254394531,"y":398.0689835548401,"wires":[["4ed91b15.08c314"]]},{"id":"bbd046e6.208da8","type":"inject","z":"3d62e5e4.f1c52a","name":"","topic":"refreshButton","payload":"","payloadType":"str","repeat":"1","crontab":"","once":true,"onceDelay":0.1,"x":314.01854705810547,"y":521.5134010314941,"wires":[["87e717b1.66a1f8","758985c0.08c69c"]]},{"id":"d7a3b5d7.5251a8","type":"function","z":"3d62e5e4.f1c52a","name":"Out1changeStatusMNG","func":"var Out1OnorOff = flow.get('flow_Out1OnorOff');\n\nif (msg.Out1Toggle === \"changeStatus\")\n{\n if (Out1OnorOff === \"outButtonON\")\n {\n Out1OnorOff = \"outButtonOFF\";\n msg.payload = false;\n }\n else\n {\n Out1OnorOff = \"outButtonON\";\n msg.payload = true;\n }\n\n flow.set('flow_Out1OnorOff',Out1OnorOff )\n return msg; //serve solo per triggerare\n}\n\n","outputs":1,"noerr":0,"x":748.6507415771484,"y":245.8465700149536,"wires":[["87e717b1.66a1f8","55f5e873.b664a8"]]},{"id":"55f5e873.b664a8","type":"rpi-gpio out","z":"3d62e5e4.f1c52a","name":"","pin":"11","set":"","level":"0","freq":"","out":"out","x":1219.5537490844727,"y":248.39287567138672,"wires":[]},{"id":"ffc310fb.2a55b","type":"ui_template","z":"3d62e5e4.f1c52a","group":"c007f24.583101","name":"OUT2","order":3,"width":"0","height":"0","format":"<div>\n\t<md-button ng-show=\"msg.Out2ShowButton==='enabled'\" class=\"md-raised {{msg.Out2OnorOff}}\" ng-click=\"send({Out2Toggle:'changeStatus'})\">\n\t\t<svg width=\"120\" height=\"120\">\n\t\t <image ng-if=\"msg.Out2OnorOff==='outButtonON'\" x=\"22\" y=\"0\" width=\"77\" height=\"90\" preserveAspectRatio=\"xMidYMid meet\"/>\n\t\t\t<image ng-if=\"msg.Out2OnorOff==='outButtonOFF'\" x=\"25\" y=\"-4\" width=\"65\" height=\"95\" preserveAspectRatio=\"xMidYMid meet\"/>\n\t\t <text x=\"15\" y=\"110\" class=\"OutName\">{{msg.Out2Label}}</text>\n\t\t</svg>\n\t</md-button>\n</div>\n\n","storeOutMessages":false,"fwdInMessages":false,"templateScope":"local","x":858.4523010253906,"y":703.0950050354004,"wires":[["5d119baf.598604"]]},{"id":"758985c0.08c69c","type":"function","z":"3d62e5e4.f1c52a","name":"Output2MNG","func":"var Out2OnorOff = flow.get('flow_Out2OnorOff') || 'outButtonOFF';\nvar out2Flag = global.get(\"global_out2Flag\");\nvar out2Name = global.get(\"global_out2Name\");\nvar Out2ShowButton = global.get(\"global_Out2ShowButton\")|| 'inhibit';\nvar OutputShowOrHide = global.get(\"global_OutputShowOrHide\"); //settato dall'utente dall'impostazioni dashboard\n\n\nif ((Out2ShowButton===\"inhibit\")&&(OutputShowOrHide===\"OutputShow\")&&(out2Flag===\"true\"))\n{\n Out2ShowButton = \"enabled\";\n}\nelse\n{\n if (Out2ShowButton===\"enabled\")\n {\n if ((OutputShowOrHide===\"OutputHide\")||(out2Flag===\"false\"))\n {\n Out2ShowButton = \"inhibit\";\n }\n }\n}\n\nglobal.set(\"global_Out2ShowButton\", Out2ShowButton);\n\n\nmsg.Out2ShowButton = Out2ShowButton;\nmsg.Out2OnorOff = Out2OnorOff;\nmsg.Out2Label = out2Name;\n\n\nreturn msg;\n","outputs":1,"noerr":0,"x":609.845380783081,"y":702.4888873100281,"wires":[["ffc310fb.2a55b"]]},{"id":"5d119baf.598604","type":"function","z":"3d62e5e4.f1c52a","name":"Out2changeStatusMNG","func":"var Out2OnorOff = flow.get('flow_Out2OnorOff');\n\nif (msg.Out2Toggle === \"changeStatus\")\n{\n if (Out2OnorOff === \"outButtonON\")\n {\n Out2OnorOff = \"outButtonOFF\";\n msg.payload = false;\n }\n else\n {\n Out2OnorOff = \"outButtonON\";\n msg.payload = true;\n }\n\n flow.set('flow_Out2OnorOff',Out2OnorOff )\n return msg; //serve solo per triggerare\n}\n\n","outputs":1,"noerr":0,"x":725.9562969207764,"y":550.2664737701416,"wires":[["758985c0.08c69c","68c485d.21f7d7c","9ad97182.ee46"]]},{"id":"68c485d.21f7d7c","type":"rpi-gpio out","z":"3d62e5e4.f1c52a","name":"","pin":"13","set":"","level":"0","freq":"","out":"out","x":1196.8593044281006,"y":552.8127794265747,"wires":[]},{"id":"9ad97182.ee46","type":"debug","z":"3d62e5e4.f1c52a","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":1037.410659790039,"y":635.5951118469238,"wires":[]},{"id":"c007f24.583101","type":"ui_group","z":"","name":"Outputs","tab":"4b0c78d9.193098","order":5,"disp":false,"width":"7","collapse":false},{"id":"4b0c78d9.193098","type":"ui_tab","z":"","name":"HOME/LAVORO","icon":"dashboard","order":2,"disabled":false,"hidden":false}]
