I am testing a disconnection of a tcp in node. I have an external computer connected to my node-red running on a pi. I set the the keep alive parameter on the pi set as
net.ipv4.tcp_keepalive_time = 60
net.ipv4.tcp_keepalive_intvl = 60
net.ipv4.tcp_keepalive_probes = 2
I pull the ethernet cable out of the external computer after it has started reporting after a couple of minutes I got the following message on the console that I started node-red on.
9 Nov 16:10:12 - [info] Started flows
29 Nov 16:10:12 - [info] [tcp in:743745e5.05653c] listening on port 12000
29 Nov 16:10:12 - [info] [mqtt-broker:Data Server broker] Connected to broker: mqtt://localhost:1883
29 Nov 16:13:03 - [info] [tcp in:743745e5.05653c] Error: read ETIMEDOUT
So node-red detected the error.
I have a catch node set up to catch errors on the [tcp in:743745e5.05653c] using the selected node option. From the catch node I have a debug node but the msg never showed up anything.
Interestingly if I put the status node looking at the same "tcp in" when the connection is made I get 1 connection showing and once the error occurs I get 0 connections.
Anyone got an idea why I would not have seen the the error in the debug node? Should it not catch this condition?
And can someone tell me where/how to look for known defects so I can check that list out.
