I discovered an interesting behavior in node red.
I'm using the node-red-contrib-modbus pallete and its modbus-server node to read data from a modbus tcp. Debugging its output with the debug node works fine. When adding a function debugging keeps working until I add the following command code line:
var int1 = bufint.readBigInt64BE(0);
the method shown here refers to this package: https://nodejs.org/api/buffer.html
And the interesting thing is. Although the debug node is not showing anything the following code is writing the right result to the console. So node red keeps working.
console.log(int1)
My test flow for testing:
[{"id":"94000c64.5b6b5","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"b93a9741.e0d148","type":"modbus-server","z":"94000c64.5b6b5","name":"","logEnabled":false,"hostname":"0.0.0.0","serverPort":10502,"responseDelay":100,"delayUnit":"ms","coilsBufferSize":"0","holdingBufferSize":"5","inputBufferSize":"1","discreteBufferSize":"0","showErrors":false,"x":600,"y":160,"wires":[["a0675782.ca5198"],[],[],[],[]]},{"id":"dceda277.20686","type":"function","z":"94000c64.5b6b5","name":"","func":"msg.payload = { 'value': msg.payload, \n'register': 'holding', \n'address': 2, \n'disableMsgOutput' : 0 }; \nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":340,"y":160,"wires":[["b93a9741.e0d148"]]},{"id":"e7bd997.b998968","type":"inject","z":"94000c64.5b6b5","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"2","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"2.1","payloadType":"num","x":110,"y":160,"wires":[["dceda277.20686"]]},{"id":"a0675782.ca5198","type":"function","z":"94000c64.5b6b5","name":"","func":"var buf = msg.payload;\nvar bufint = buf.subarray(0,8);\nvar int1 = bufint.readBigInt64BE(0);\nvar msg1 = { payload : int1 };\nconsole.log(msg1)\nreturn msg1;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":860,"y":140,"wires":[["e4a42523.50cee8"]]},{"id":"e4a42523.50cee8","type":"debug","z":"94000c64.5b6b5","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1070,"y":140,"wires":[]}]
Thank you in advance for your help!
