When I use HTTP request to send a request, the debug console occasionally shows "No response from server". Through monitoring the server, the requesting server did not receive the request. I would like to ask for the reason for this issue. Could it be a network issue or an issue with the version of my node.js or node red (my node.js version is V20.11.0, node red version is v3.1.3), or some other reason? This issue has caused a lot of trouble in the project, so I sincerely seek your advice. Thank you very much.
Here is my code.
"id": "17c00b55beda47d3",
"type": "tab",
"label": "流程 7",
"disabled": false,
"info": "",
"env": []
"id": "deb3ed1feedce240",
"type": "http in",
"z": "17c00b55beda47d3",
"name": "RFID返回",
"url": "/PostMessage/RFIDCode",
"method": "post",
"upload": false,
"swaggerDoc": "",
"x": 361,
"y": 280,
"d7f9d1dbca329fe4"
"id": "d7f9d1dbca329fe4",
"type": "function",
"name": "解析",
"func": "var rfidCode = msg.payload[\"code\"];\nvar rfidCardNo = global.get('globalVariable_RFID_LinShiCardNo')||'';\n\nvar globalVariable_Weigh = global.get('globalVariable_Weigh') || \"0\";\nvar floatWeigh = Number(globalVariable_Weigh);\nif(floatWeigh>0.02){\n return null;\n}\n\nif(rfidCardNo==rfidCode){\n return null;\n}else{\n global.set('globalVariable_RFID_LinShiCardNo',rfidCode)\n msg.payload = {\n \"rfidCode\": rfidCode\n }\n}\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 521,
"y": 340,
"6f36379773c09682",
"69d05c2ab22c803c"
"id": "6f36379773c09682",
"type": "http request",
"name": "上传信息",
"method": "POST",
"ret": "txt",
"paytoqs": "ignore",
"url": "http://192.168.1.98:9082/bdDocCar/findListByRfidCode",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"senderr": false,
"x": 561,
"y": 400,
"id": "69d05c2ab22c803c",
"type": "debug",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"statusVal": "",
"statusType": "auto",
"x": 741,
"y": 340,
