Node flow to convert ip to coordinates?
Thanks for your feedback!
I have tested the entire update process again, and it seems to be working fine here...
Version 1.0.0 is now available on npm:
@Jacq: there are now 3 different solutions for your problem, but you have not responded yet to any of those. Would be nice to get some feedback ....
Wow, thanks for the overwhelming support.
To summarize the options for future visitors:
I have just tested three methods and they work great, thanks:
Here is the demo, need to setup ACCESS_KEY in ipstack to test it:
[{"id":"f2e0329c.73c4e","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"cfbd01d9.4efda","type":"inject","z":"f2e0329c.73c4e","name":"","topic":"","payload":"104.27.163.46","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":310,"y":460,"wires":[["2002343b.9e318c","7cf2a066.8289e","cb1a974f.f068d8"]]},{"id":"2002343b.9e318c","type":"function","z":"f2e0329c.73c4e","name":"geoip-lite","func":"const geoip = global.get('geoipLite');\n \nmsg.payload = geoip.lookup(msg.payload);\n \nreturn msg;","outputs":1,"noerr":0,"x":560,"y":300,"wires":[["6e0f0d03.f28f54"]]},{"id":"6e0f0d03.f28f54","type":"debug","z":"f2e0329c.73c4e","name":"using 'geoip-lite'","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1080,"y":300,"wires":[]},{"id":"7cf2a066.8289e","type":"ip-location-lite","z":"f2e0329c.73c4e","name":"node-red-contrib-ip-location-lite","inputField":"payload","outputField":"payload","x":630,"y":460,"wires":[["fea0b74d.de6a38"]]},{"id":"fea0b74d.de6a38","type":"debug","z":"f2e0329c.73c4e","name":"using 'node-red-contrib-ip-location-lite'","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1010,"y":460,"wires":[]},{"id":"1201e5f0.745bba","type":"http request","z":"f2e0329c.73c4e","name":"ipstack.com","method":"GET","ret":"txt","paytoqs":false,"url":"http://api.ipstack.com/{{ip}}?access_key={{access_key}}&format=1","tls":"","persist":false,"proxy":"","authType":"","x":770,"y":580,"wires":[["d4fa8e70.e25a7"]]},{"id":"d4fa8e70.e25a7","type":"debug","z":"f2e0329c.73c4e","name":"using ''https://ipstack.com/product'","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1020,"y":580,"wires":[]},{"id":"cb1a974f.f068d8","type":"change","z":"f2e0329c.73c4e","name":"set access_key","rules":[{"t":"set","p":"ip","pt":"msg","to":"payload","tot":"msg"},{"t":"set","p":"access_key","pt":"msg","to":"XXXXXXXXXXXXXXXX","tot":"str"}],"action":"","property":"","from":"","to":"","reg":false,"x":580,"y":580,"wires":[["1201e5f0.745bba"]]}]
