I have transfered a project to my home machine from work so I can work on it.
It shower a list of nodes that needed installing. 2 will not install, but these are not used in any flow.
when trying to install I get errors that I do not understand.
These are the nodes
Here are the errors in the terminal window from the point of installation. Sorry they are very long.so had to delete end to get it to post
13 Jun 16:49:18 - [info] Waiting for missing types to be registered:
13 Jun 16:49:18 - [info] - HIDConfig
13 Jun 16:49:18 - [info] - sqldb
13 Jun 16:49:35 - [info] Installing module: node-red-contrib-usbhid, version: 0.0.1
13 Jun 16:50:06 - [warn] Installation of module node-red-contrib-usbhid failed:
13 Jun 16:50:06 - [warn] ------------------------------------------
13 Jun 16:50:06 - [warn] npm WARN npm npm does not support Node.js v10.15.2
npm WARN npm You should probably upgrade to a newer version of node as we
npm WARN npm can't make any promises that npm will work with this version.
npm WARN npm Supported releases of Node.js are the latest release of 4, 6, 7, 8, 9.
npm WARN npm You can find the latest version at https://nodejs.org/
In file included from ../../nan/nan.h:190,
from ../fs-ext.cc:27:
../../nan/nan_maybe_43_inl.h: In function ‘Nan::Maybe Nan::ForceSet(v8::Localv8::Object, v8::Localv8::Value, v8::Localv8::Value, v8::PropertyAttribute)’:
../../nan/nan_maybe_43_inl.h:88:15: error: ‘class v8::Object’ has no member named ‘ForceSet’
return obj->ForceSet(GetCurrentContext(), key, value, attribs);
In file included from ../fs-ext.cc:27:
../../nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value)’:
../../nan/nan.h:817:60: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate, v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
v8::Isolate::GetCurrent(), target, func, argc, argv);
In file included from ../fs-ext.cc:20:
/usr/include/nodejs/src/node.h:177:50: note: declared here
NODE_EXTERN v8::Localv8::Value MakeCallback(
/usr/include/nodejs/src/node.h:91:42: note: in definition of macro ‘NODE_DEPRECATED’
attribute((deprecated(message))) declarator
../../nan/nan.h:817:60: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
../../nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value)’:
../../nan/nan.h:831:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate, v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
v8::Isolate::GetCurrent(), target, symbol, argc, argv);
/usr/include/nodejs/src/node.h:170:50: note: declared here
../../nan/nan.h:831:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::String, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
../../nan/nan.h: In function ‘v8::Localv8::Value Nan::MakeCallback(v8::Localv8::Object, const char*, int, v8::Localv8::Value)’:
../../nan/nan.h:845:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate, v8::Localv8::Object, const char*, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
v8::Isolate::GetCurrent(), target, method, argc, argv);
/usr/include/nodejs/src/node.h:163:50: note: declared here
../../nan/nan.h:845:62: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, const char*, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
../../nan/nan.h: In member function ‘v8::Localv8::Value Nan::Callback::Call_(v8::Isolate*, v8::Localv8::Object, int, v8::Localv8::Value) const’:
../../nan/nan.h:1463:5: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate, v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
../../nan/nan.h:1463:5: warning: ‘v8::Localv8::Value node::MakeCallback(v8::Isolate*, v8::Localv8::Object, v8::Localv8::Function, int, v8::Localv8::Value*)’ is deprecated: Use MakeCallback(..., async_context) [-Wdeprecated-declarations]
../../nan/nan.h: In function ‘void Nan::AsyncQueueWorker(Nan::AsyncWorker*)’:
../../nan/nan.h:1706:62: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
, reinterpret_cast<uv_after_work_cb>(AsyncExecuteComplete)
../fs-ext.cc: In function ‘void EIO_After(uv_work_t*)’:
../fs-ext.cc:108:20: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
argv[0] = Nan::NanErrnoException(store_data->error);
../../nan/nan.h:862:46: note: declared here
NAN_DEPRECATED inline v8::Localv8::Value NanErrnoException(
../fs-ext.cc:108:55: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
../fs-ext.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Flock(Nan::NAN_METHOD_ARGS_TYPE)’:
../fs-ext.cc:281:40: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
flock_data->fd = info[0]->Int32Value();
In file included from /usr/include/nodejs/deps/v8/include/v8.h:26,
from /usr/include/nodejs/src/node.h:63,
/usr/include/nodejs/deps/v8/include/v8.h:2478:46: note: declared here
V8_DEPRECATED("Use maybe version", int32_t Int32Value() const);
/usr/include/nodejs/deps/v8/include/v8config.h:324:3: note: in definition of macro ‘V8_DEPRECATED’
declarator attribute((deprecated(message)))
../fs-ext.cc:282:42: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
flock_data->oper = info[1]->Int32Value();
../fs-ext.cc:288:72: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Flock, (uv_after_work_cb)EIO_After);
../fs-ext.cc:297:45: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
if (i != 0) return Nan::ThrowError(Nan::NanErrnoException(errno));
../fs-ext.cc:297:68: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
../fs-ext.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Seek(Nan::NAN_METHOD_ARGS_TYPE)’:
../fs-ext.cc:332:32: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int fd = info[0]->Int32Value();
../fs-ext.cc:317:74: warning: ‘double v8::Value::NumberValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
if (!(a)->IsUndefined() && !(a)->IsNull() && !IsInt64((a)->NumberValue())) {
../fs-ext.cc:333:3: note: in expansion of macro ‘ASSERT_OFFSET’
ASSERT_OFFSET(info[1]);
/usr/include/nodejs/deps/v8/include/v8.h:2475:45: note: declared here
V8_DEPRECATED("Use maybe version", double NumberValue() const);
../fs-ext.cc:320:60: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
#define GET_OFFSET(a) ((a)->IsNumber() ? (a)->IntegerValue() : -1)
../fs-ext.cc:334:16: note: in expansion of macro ‘GET_OFFSET’
off_t offs = GET_OFFSET(info[1]);
/usr/include/nodejs/deps/v8/include/v8.h:2476:46: note: declared here
V8_DEPRECATED("Use maybe version", int64_t IntegerValue() const);
../fs-ext.cc:335:36: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int whence = info[2]->Int32Value();
../fs-ext.cc:339:56: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
if (offs_result == -1) return Nan::ThrowError(Nan::NanErrnoException(errno));
../fs-ext.cc:339:79: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
../fs-ext.cc:354:69: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Seek, (uv_after_work_cb)EIO_After);
../fs-ext.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE Fcntl(Nan::NAN_METHOD_ARGS_TYPE)’:
../fs-ext.cc:369:32: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
../fs-ext.cc:370:33: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int cmd = info[1]->Int32Value();
../fs-ext.cc:371:33: warning: ‘int32_t v8::Value::Int32Value() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
int arg = info[2]->Int32Value();
../fs-ext.cc:375:51: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
if (result == -1) return Nan::ThrowError(Nan::NanErrnoException(errno));
../fs-ext.cc:375:74: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
../fs-ext.cc:390:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_Fcntl, (uv_after_work_cb)EIO_After);
../fs-ext.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE UTime(Nan::NAN_METHOD_ARGS_TYPE)’:
../fs-ext.cc:423:45: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
String::Utf8Value path(info[0]->ToString());
/usr/include/nodejs/deps/v8/include/v8.h:2892:28: note: declared here
explicit Utf8Value(Localv8::Value obj));
../fs-ext.cc:424:40: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
time_t atime = info[1]->IntegerValue();
../fs-ext.cc:425:40: warning: ‘int64_t v8::Value::IntegerValue() const’ is deprecated: Use maybe version [-Wdeprecated-declarations]
time_t mtime = info[2]->IntegerValue();
../fs-ext.cc:433:47: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
if (ret != 0) return Nan::ThrowError(Nan::NanErrnoException(errno, "utime", "", *path));
../fs-ext.cc:433:90: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
../fs-ext.cc:448:70: warning: cast between incompatible function types from ‘void ()(uv_work_t)’ {aka ‘void ()(uv_work_s)’} to ‘uv_after_work_cb’ {aka ‘void ()(uv_work_s, int)’} [-Wcast-function-type]
uv_queue_work(uv_default_loop(), req, EIO_UTime, (uv_after_work_cb)EIO_After);
../fs-ext.cc: In function ‘Nan::NAN_METHOD_RETURN_TYPE StatVFS(Nan::NAN_METHOD_ARGS_TYPE)’:
../fs-ext.cc:462:45: warning: ‘v8::String::Utf8Value::Utf8Value(v8::Localv8::Value)’ is deprecated: Use Isolate version [-Wdeprecated-declarations]
../fs-ext.cc:469:47: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
if (ret != 0) return Nan::ThrowError(Nan::NanErrnoException(errno, "statvfs", "", *path));
../fs-ext.cc:469:92: warning: ‘v8::Localv8::Value Nan::NanErrnoException(int, const char*, const char*, const char*)’ is deprecated [-Wdeprecated-declarations]
