Node module update issue
Hi
I'm trying to update node-red-node-email from Node-red's manage pallete section, but it throws error that the module is not installed locally.
So after reading forums I found out that I need to see where my module is initially installed and for that I ran the command npm ls -g node-red-node-email which returned the following result:
Screenshot%20from%202018-09-03%2012-01-30
However, when I install the module globally (as per forums instructions) with the command sudo npm ls -g node-red-node-email and re-run the npm ls -g node-red-node-email command, so the hierarchy ends up like this:
/usr/lib
โ”œโ”€โ”ฌ node-red@0.19.2
โ”‚ โ””โ”€โ”€ node-red-node-email@0.1.29
โ””โ”€โ”€ node-red-node-email@1.0.1
So, my question is, why do I end up with two different instances of same module? and where exactly is ver 1.0.1 residing?
Also, how can I fix this? (preferably by removing the old version)
Just answered this in another thread
It is a good idea to read the install notes for a node - see the last line.
Install
Version 0.x of this node is usually installed by default by Node-RED. To install version 1.x you need to uninstall the existing version.
    sudo npm uninstall -g node-red-node-email
Then run the following command in your Node-RED user directory - typically ~/.node-red
    npm i node-red-node-email
Note : this installs the new version locally rather than globally. This can then be managed by the palette manager.
Uninstalling the module with the command leaves back to the following state:
Seems like the command only removes node-red-node-email@1.0.1, though node-red-node-email@0.1.29 module is still present.
thatโ€™s the version of Node-RED (0.19.2) not any email node
my bad, I fixed the typo.
how can I uninstall node-red-node-email@0.1.29?
I had to remove the folder manually:
sudo rm -r /usr/lib/node_modules/node-red/node_modules/node-red-node-email
where my npm root is:
npm root -g
Is it safe to delete the folder rather than uninstalling the module properly?
I mean, doesn't npm keep track of modules installed and later complain when missing without uninstalling?
Well I first did the uninstall but the folder hasn't been removed!
Unfortunately, in my case, the folder isn't empty.
which folder?
Ok, here is what I did:
cd ~/.node-red
this way the node-red-node-email is installed in the .node-red folder.
I'm not fully convinced with deleting the module folder part. This is what I did:
and it outputs:
up to date in 0.038s
which means uninstall did nothing.
later I called:
and it outputs:
/usr/lib
โ””โ”€โ”ฌ node-red@0.19.2
then I removed the module folder as you suggested:
and re-printed the module status, and this time I get the following:
Screenshot%20from%202018-09-03%2013-53-39
As I pointed earlier, node-red keeps track of installed modules and deleting the module-folder just like that doesn't seem the right way.
I know that, probably because of the node-red package.json dependency
"node-red-node-email": "0.1.*",
But if you go on installing the node locally in ./node-red and restart node-red, what happens?
Installing module:
waqas@aslam:~/.node-red$ npm i node-red-node-email
npm WARN deprecated mailparser@0.6.2: Mailparser versions older than v2.3.0 are deprecated
npm WARN deprecated mimelib@0.3.1: This project is unmaintained
+ node-red-node-email@1.0.1
added 19 packages from 12 contributors in 1.47s
Showing local listing:
waqas@aslam:~/.node-red$ sudo npm ls node-red-node-email
node-red-project@0.0.1 /home/waslam/.node-red
Showing global listing:
waqas@aslam:~/.node-red$ sudo npm ls -g node-red-node-email
/usr/lib
  โ””โ”€โ”€ UNMET DEPENDENCY node-red-node-email@0.1.*
npm ERR! missing: node-red-node-email@0.1.*, required by node-red@0.19.2
Looks like my global listing is messed up.
did you restart node-red and check the node-red-node-email version?
It looks fine in node-red UI with correct version.
Seems like I've fixed the global listing issue by removing
from package.json file in /usr/lib/node_modules/node-red
and now this is what I get when print global listing:
/usr/lib
โ””โ”€โ”€ (empty)
which means there's no such package installed globally.
I did also remove the dependency but I think we should ask @knolleary or @dceejay for the best praxis.
Maybe update package.json?
I wonder if you need to do a remove not uninstall
I'm not sure I undestand you.
I just did an uninstall following the doc but actually it doesn't uninstall (probably because it's installed in the node-red path) so I've removed the folder with all the included files manually.
