Had another go, cleared the cache on Firefox, got rid of /usr/bin/node and /usr/lib/node_modules
and the function edit window is garbled again on just this one Pi.
do you have similar errors in your browser console/developer tools, to those reported by @zenofmud above ?
Yes I do get them.
@dceejay if there is anything you want me to try or debugging you want to see, let me know. For the moment I'm back on 0.19.6 but I've flipped it back and forth a couple times already.
In case it is useful. I'm running 0.20 on Windows 10 having upgraded from beta (several beta's in fact) and all is well here - no problems with ACE either - I'd have certainly noticed that since I'm using it extensively for uibuilder v2.
13 Mar 22:22:11 - [info] Node-RED version: v0.20.0
13 Mar 22:22:11 - [info] Node.js version: v10.15.1
13 Mar 22:22:11 - [info] Windows_NT 10.0.17763 x64 LE
Projects currently turned on but it was the same without projects too.
Syncing my project with GitHub is broken...
I'm on Win10 and I used NR 0.20 to do the initial cloning of my rep from GitHub without issue.
After I committed a local change, the Push runs this:
2019-03-14T23:29:18.699Z git -c credential.helper= push origin HEAD:master --porcelain
but it gets stuck here"
[err] error: cannot spawn c:\Users\... ....\node-red-ask-pass-sh: No error
that file contains:
"$NODE_RED_GIT_NODE_PATH" "$NODE_RED_GIT_ASKPASS_PATH" "$NODE_RED_GIT_SOCK_PATH" $@
Anyone else having this issue? I've tried it on both Edge and Firefox browsers.
@SmokeyRider. This issue has been discussed here. Did you manage to sync with GIthub in previous versions of Node-RED ?
No, I'm new to NR. but that command does work from powershell
We still have an outstanding issue being able to access remote git repos on Windows 10.
If you are familiar with git, you can run the commands manually in ~/.node-red/projects/<name-of-project>
in your PowerShell.
As an experiment, just happening to have another mac that has never had Node-RED installed on it, I installed it and I do not see the squished text
problem and nothing shows up in the browser's JavaScript console.
machine with the issue:
Mac mini (Late 2012)
macOS 10.13.6
Node-RED v 0.20.0
node.js v 10.15.1
machine without the issue:
Mac mini (Mid 2011)
macOS 10.13.6
Node-RED v 0.20.0
node.js v 10.14.1
Hi @zenofmud
on each of those machines, can you do the following?
Find the node-red install directory, and the editor code under it:
If you installed it as a global module, run
npm list -g --depth 0 node-red
That will give you output like:
/Users/nol/.nvm/versions/node/v8.14.0/lib └── node-red@0.20.0
Under that same directory should be:
node_modules/@node-red/editor-client/public
Once you have found that public directory, run the following command from that directory:
find . -type f -exec md5 "{}" + > /tmp/nr-checksums.txt
That will generate a list of checksums for all the files.
Once you have that file for each machine, you can compare all the checksums to see if any local file corruption has occurred - alternatively, send me (nick.oleary@gmail.com) the files and I can take a look.
This will help rule out some sort of local file corruption on the bad machine.
@knolleary when I run the find nothing returns (same on both machines)
Downdeep:~ paul$ cd $HOME
Downdeep:~ paul$ cd /usr/local/lib/node_modules/node-red
Downdeep:node-red paul$ npm list -g --depth 0 node-red
/usr/local/lib
└── node-red@0.20.0
Downdeep:node-red paul$ cd node_modules/@node-red/editor-client/public
Downdeep:public paul$ ls
favicon.ico red vendor
Downdeep:public paul$ find . -type f -exec md5 "{}" + > /tmp/nr-checksums.txt
Downdeep:public paul$```
I'll be out for the next 2 1/5 hours
Sorry, should have been more explicit. The command is writing its output to the file /tmp/nr-checksums.txt
- that's what you need to look at.
Had a minute to do this before I dash - the files are the same. (used BBEdit copied the output of each into a window and had BBedit co a compare and they are the same - to see it it would make a difference, I upgraded node.js to v10.15.3 so both machines would match.
I too am getting the single line function node. (edit: It's happening in comment nodes too)
I upgrade my install of node-red 10 minutes ago from the time of this posting.
I have node-red installed with the non standard root set in the settings.js file. Might that be the problem?
the setting is httpRoot: '/red'
I also have the setting for static files set to httpStatic: '/var/www/nrstatic/'
Does the URL for that script take into account the non standard root location?
I looked in my console and the only error I see is the
"Loading failed for the <script> with source “https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/mode-nrjavascript.js”."
The only other error that appears is
"Password fields present on an insecure (http://) page. This is a security risk that allows user login credentials to be stolen."
And that only appears when I double click the function node to open it for editing.
additional:
Just checked the source of the page. The request for the mode-nrjavascript.js file doesn't appear in the page source straight from the server. it appears in the generated source as viewed in the debugger console. (Firefox, in this instance)
the request for that script from the CDN is the only instance that appears in the page source that I viewed
<head>
<style id="autocompletion.css">.ace_editor.ace_autocomplete .ace_marker-layer .ace_active-line { background-color: #CAD6FA; z-index: 1;}.ace_dark.ace_editor.ace_autocomplete .ace_marker-layer .ace_active-line { background-color: #3a674e;}.ace_editor.ace_autocomplete .ace_line-hover { border: 1px solid #abbffe; margin-top: -1px; background: rgba(233,233,253,0.4); position: absolute; z-index: 2;}.ace_dark.ace_editor.ace_autocomplete .ace_line-hover { border: 1px solid rgba(109, 150, 13, 0.8); background: rgba(58, 103, 78, 0.62);}.ace_completion-meta { opacity: 0.5; margin: 0.9em;}.ace_editor.ace_autocomplete .ace_completion-highlight{ color: #2d69c7;}.ace_dark.ace_editor.ace_autocomplete .ace_completion-highlight{ color: #93ca12;}.ace_editor.ace_autocomplete { width: 300px; z-index: 200000; border: 1px lightgray solid; position: fixed; box-shadow: 2px 3px 5px rgba(0,0,0,.2); line-height: 1.4; background: #fefefe; color: #111;}.ace_dark.ace_editor.ace_autocomplete { border: 1px #484747 solid; box-shadow: 2px 3px 5px rgba(0, 0, 0, 0.51); line-height: 1.4; background: #25282c; color: #c1c1c1;}
/*# sourceURL=ace/css/autocompletion.css */</style>
<style>.ace_snippet-marker { -moz-box-sizing: border-box; box-sizing: border-box; background: rgba(194, 193, 208, 0.09); border: 1px dotted rgba(211, 208, 235, 0.62); position: absolute;}</style>
<style>
.error_widget_wrapper { background: inherit; color: inherit; border:none } .error_widget { border-top: solid 2px; border-bottom: solid 2px; margin: 5px 0; padding: 10px 40px; white-space: pre-wrap; } .error_widget.ace_error, .error_widget_arrow.ace_error{ border-color: #ff5a5a } .error_widget.ace_warning, .error_widget_arrow.ace_warning{ border-color: #F1D817 } .error_widget.ace_info, .error_widget_arrow.ace_info{ border-color: #5a5a5a } .error_widget.ace_ok, .error_widget_arrow.ace_ok{ border-color: #5aaa5a } .error_widget_arrow { position: absolute; border: solid 5px; border-top-color: transparent!important; border-right-color: transparent!important; border-left-color: transparent!important; top: -5px; }</style>
<style id="ace-tm">.ace-tm .ace_gutter {background: #f0f0f0;color: #333;}.ace-tm .ace_print-margin {width: 1px;background: #e8e8e8;}.ace-tm .ace_fold {background-color: #6B72E6;}.ace-tm {background-color: #FFFFFF;color: black;}.ace-tm .ace_cursor {color: black;}.ace-tm .ace_invisible {color: rgb(191, 191, 191);}.ace-tm .ace_storage,.ace-tm .ace_keyword {color: blue;}.ace-tm .ace_constant {color: rgb(197, 6, 11);}.ace-tm .ace_constant.ace_buildin {color: rgb(88, 72, 246);}.ace-tm .ace_constant.ace_language {color: rgb(88, 92, 246);}.ace-tm .ace_constant.ace_library {color: rgb(6, 150, 14);}.ace-tm .ace_invalid {background-color: rgba(255, 0, 0, 0.1);color: red;}.ace-tm .ace_support.ace_function {color: rgb(60, 76, 114);}.ace-tm .ace_support.ace_constant {color: rgb(6, 150, 14);}.ace-tm .ace_support.ace_type,.ace-tm .ace_support.ace_class {color: rgb(109, 121, 222);}.ace-tm .ace_keyword.ace_operator {color: rgb(104, 118, 135);}.ace-tm .ace_string {color: rgb(3, 106, 7);}.ace-tm .ace_comment {color: rgb(76, 136, 107);}.ace-tm .ace_comment.ace_doc {color: rgb(0, 102, 255);}.ace-tm .ace_comment.ace_doc.ace_tag {color: rgb(128, 159, 191);}.ace-tm .ace_constant.ace_numeric {color: rgb(0, 0, 205);}.ace-tm .ace_variable {color: rgb(49, 132, 149);}.ace-tm .ace_xml-pe {color: rgb(104, 104, 91);}.ace-tm .ace_entity.ace_name.ace_function {color: #0000A2;}.ace-tm .ace_heading {color: rgb(12, 7, 255);}.ace-tm .ace_list {color:rgb(185, 6, 144);}.ace-tm .ace_meta.ace_tag {color:rgb(0, 22, 142);}.ace-tm .ace_string.ace_regex {color: rgb(255, 0, 0)}.ace-tm .ace_marker-layer .ace_selection {background: rgb(181, 213, 255);}.ace-tm.ace_multiselect .ace_selection.ace_start {box-shadow: 0 0 3px 0px white;}.ace-tm .ace_marker-layer .ace_step {background: rgb(252, 255, 0);}.ace-tm .ace_marker-layer .ace_stack {background: rgb(164, 229, 101);}.ace-tm .ace_marker-layer .ace_bracket {margin: -1px 0 0 -1px;border: 1px solid rgb(192, 192, 192);}.ace-tm .ace_marker-layer .ace_active-line {background: rgba(0, 0, 0, 0.07);}.ace-tm .ace_gutter-active-line {background-color : #dcdcdc;}.ace-tm .ace_marker-layer .ace_selected-word {background: rgb(250, 250, 255);border: 1px solid rgb(200, 200, 250);}.ace-tm .ace_indent-guide {background: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAACCAYAAACZgbYnAAAAE0lEQVQImWP4////f4bLly//BwAmVgd1/w11/gAAAABJRU5ErkJggg==") right repeat-y;}
/*# sourceURL=ace/css/ace-tm */</style>
<style id="ace_editor.css">.ace_br1 {border-top-left-radius : 3px;}.ace_br2 {border-top-right-radius : 3px;}.ace_br3 {border-top-left-radius : 3px; border-top-right-radius: 3px;}.ace_br4 {border-bottom-right-radius: 3px;}.ace_br5 {border-top-left-radius : 3px; border-bottom-right-radius: 3px;}.ace_br6 {border-top-right-radius : 3px; border-bottom-right-radius: 3px;}.ace_br7 {border-top-left-radius : 3px; border-top-right-radius: 3px; border-bottom-right-radius: 3px;}.ace_br8 {border-bottom-left-radius : 3px;}.ace_br9 {border-top-left-radius : 3px; border-bottom-left-radius: 3px;}.ace_br10{border-top-right-radius : 3px; border-bottom-left-radius: 3px;}.ace_br11{border-top-left-radius : 3px; border-top-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br12{border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br13{border-top-left-radius : 3px; border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br14{border-top-right-radius : 3px; border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_br15{border-top-left-radius : 3px; border-top-right-radius: 3px; border-bottom-right-radius: 3px; border-bottom-left-radius: 3px;}.ace_editor {position: relative;overflow: hidden;font: 12px/normal 'Monaco', 'Menlo', 'Ubuntu Mono', 'Consolas', 'source-code-pro', monospace;direction: ltr;text-align: left;-webkit-tap-highlight-color: rgba(0, 0, 0, 0);}.ace_scroller {position: absolute;overflow: hidden;top: 0;bottom: 0;background-color: inherit;-ms-user-select: none;-moz-user-select: none;-webkit-user-select: none;user-select: none;cursor: text;}.ace_content {position: absolute;box-sizing: border-box;min-width: 100%;contain: style size layout;}.ace_dragging .ace_scroller:before{position: absolute;top: 0;left: 0;right: 0;bottom: 0;content: '';background: rgba(250, 250, 250, 0.01);z-index: 1000;}.ace_dragging.ace_dark .ace_scroller:before{background: rgba(0, 0, 0, 0.01);}.ace_selecting, .ace_selecting * {cursor: text !important;}.ace_gutter {position: absolute;overflow : hidden;width: auto;top: 0;bottom: 0;left: 0;cursor: default;z-index: 4;-ms-user-select: none;-moz-user-select: none;-webkit-user-select: none;user-select: none;contain: style size layout;}.ace_gutter-active-line {position: absolute;left: 0;right: 0;}.ace_scroller.ace_scroll-left {box-shadow: 17px 0 16px -16px rgba(0, 0, 0, 0.4) inset;}.ace_gutter-cell {position: absolute;top: 0;left: 0;right: 0;padding-left: 19px;padding-right: 6px;background-repeat: no-repeat;}.ace_gutter-cell.ace_error {background-image: url("data:image/png;base64,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");background-repeat: no-repeat;background-position: 2px center;}.ace_gutter-cell.ace_warning {background-image: url("data:image/png;base64,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");background-position: 2px center;}.ace_gutter-cell.ace_info {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQCAAAAAA6mKC9AAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAAJ0Uk5TAAB2k804AAAAPklEQVQY02NgIB68QuO3tiLznjAwpKTgNyDbMegwisCHZUETUZV0ZqOquBpXj2rtnpSJT1AEnnRmL2OgGgAAIKkRQap2htgAAAAASUVORK5CYII=");background-position: 2px center;}.ace_dark .ace_gutter-cell.ace_info {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABAAAAAQBAMAAADt3eJSAAAAJFBMVEUAAAChoaGAgIAqKiq+vr6tra1ZWVmUlJSbm5s8PDxubm56enrdgzg3AAAAAXRSTlMAQObYZgAAAClJREFUeNpjYMAPdsMYHegyJZFQBlsUlMFVCWUYKkAZMxZAGdxlDMQBAG+TBP4B6RyJAAAAAElFTkSuQmCC");}.ace_scrollbar {contain: strict;position: absolute;right: 0;bottom: 0;z-index: 6;}.ace_scrollbar-inner {position: absolute;cursor: text;left: 0;top: 0;}.ace_scrollbar-v{overflow-x: hidden;overflow-y: scroll;top: 0;}.ace_scrollbar-h {overflow-x: scroll;overflow-y: hidden;left: 0;}.ace_print-margin {position: absolute;height: 100%;}.ace_text-input {position: absolute;z-index: 0;width: 0.5em;height: 1em;opacity: 0;background: transparent;-moz-appearance: none;appearance: none;border: none;resize: none;outline: none;overflow: hidden;font: inherit;padding: 0 1px;margin: 0 -1px;contain: strict;-ms-user-select: text;-moz-user-select: text;-webkit-user-select: text;user-select: text;white-space: pre!important;}.ace_text-input.ace_composition {background: transparent;color: inherit;z-index: 1000;opacity: 1;}.ace_composition_placeholder { color: transparent }.ace_composition_marker { border-bottom: 1px solid;position: absolute;border-radius: 0;margin-top: 1px;}[ace_nocontext=true] {transform: none!important;filter: none!important;perspective: none!important;clip-path: none!important;mask : none!important;contain: none!important;perspective: none!important;mix-blend-mode: initial!important;z-index: auto;}.ace_layer {z-index: 1;position: absolute;overflow: hidden;word-wrap: normal;white-space: pre;height: 100%;width: 100%;box-sizing: border-box;pointer-events: none;}.ace_gutter-layer {position: relative;width: auto;text-align: right;pointer-events: auto;height: 1000000px;contain: style size layout;}.ace_text-layer {font: inherit !important;position: absolute;height: 1000000px;width: 1000000px;contain: style size layout;}.ace_text-layer > .ace_line, .ace_text-layer > .ace_line_group {contain: style size layout;position: absolute;top: 0;left: 0;right: 0;}.ace_hidpi .ace_text-layer,.ace_hidpi .ace_gutter-layer,.ace_hidpi .ace_content,.ace_hidpi .ace_gutter {contain: strict;will-change: transform;}.ace_hidpi .ace_text-layer > .ace_line, .ace_hidpi .ace_text-layer > .ace_line_group {contain: strict;}.ace_cjk {display: inline-block;text-align: center;}.ace_cursor-layer {z-index: 4;}.ace_cursor {z-index: 4;position: absolute;box-sizing: border-box;border-left: 2px solid;transform: translatez(0);}.ace_multiselect .ace_cursor {border-left-width: 1px;}.ace_slim-cursors .ace_cursor {border-left-width: 1px;}.ace_overwrite-cursors .ace_cursor {border-left-width: 0;border-bottom: 1px solid;}.ace_hidden-cursors .ace_cursor {opacity: 0.2;}.ace_smooth-blinking .ace_cursor {transition: opacity 0.18s;}.ace_animate-blinking .ace_cursor {animation-duration: 1000ms;animation-timing-function: step-end;animation-name: blink-ace-animate;animation-iteration-count: infinite;}.ace_animate-blinking.ace_smooth-blinking .ace_cursor {animation-duration: 1000ms;animation-timing-function: ease-in-out;animation-name: blink-ace-animate-smooth;}@keyframes blink-ace-animate {from, to { opacity: 1; }60% { opacity: 0; }}@keyframes blink-ace-animate-smooth {from, to { opacity: 1; }45% { opacity: 1; }60% { opacity: 0; }85% { opacity: 0; }}.ace_marker-layer .ace_step, .ace_marker-layer .ace_stack {position: absolute;z-index: 3;}.ace_marker-layer .ace_selection {position: absolute;z-index: 5;}.ace_marker-layer .ace_bracket {position: absolute;z-index: 6;}.ace_marker-layer .ace_active-line {position: absolute;z-index: 2;}.ace_marker-layer .ace_selected-word {position: absolute;z-index: 4;box-sizing: border-box;}.ace_line .ace_fold {box-sizing: border-box;display: inline-block;height: 11px;margin-top: -2px;vertical-align: middle;background-image:url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABEAAAAJCAYAAADU6McMAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAJpJREFUeNpi/P//PwOlgAXGYGRklAVSokD8GmjwY1wasKljQpYACtpCFeADcHVQfQyMQAwzwAZI3wJKvCLkfKBaMSClBlR7BOQikCFGQEErIH0VqkabiGCAqwUadAzZJRxQr/0gwiXIal8zQQPnNVTgJ1TdawL0T5gBIP1MUJNhBv2HKoQHHjqNrA4WO4zY0glyNKLT2KIfIMAAQsdgGiXvgnYAAAAASUVORK5CYII="),url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAA3CAYAAADNNiA5AAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAACJJREFUeNpi+P//fxgTAwPDBxDxD078RSX+YeEyDFMCIMAAI3INmXiwf2YAAAAASUVORK5CYII=");background-repeat: no-repeat, repeat-x;background-position: center center, top left;color: transparent;border: 1px solid black;border-radius: 2px;cursor: pointer;pointer-events: auto;}.ace_dark .ace_fold {}.ace_fold:hover{background-image:url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAABEAAAAJCAYAAADU6McMAAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAAJpJREFUeNpi/P//PwOlgAXGYGRklAVSokD8GmjwY1wasKljQpYACtpCFeADcHVQfQyMQAwzwAZI3wJKvCLkfKBaMSClBlR7BOQikCFGQEErIH0VqkabiGCAqwUadAzZJRxQr/0gwiXIal8zQQPnNVTgJ1TdawL0T5gBIP1MUJNhBv2HKoQHHjqNrA4WO4zY0glyNKLT2KIfIMAAQsdgGiXvgnYAAAAASUVORK5CYII="),url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAEAAAA3CAYAAADNNiA5AAAAGXRFWHRTb2Z0d2FyZQBBZG9iZSBJbWFnZVJlYWR5ccllPAAAACBJREFUeNpi+P//fz4TAwPDZxDxD5X4i5fLMEwJgAADAEPVDbjNw87ZAAAAAElFTkSuQmCC");}.ace_tooltip {background-color: #FFF;background-image: linear-gradient(to bottom, transparent, rgba(0, 0, 0, 0.1));border: 1px solid gray;border-radius: 1px;box-shadow: 0 1px 2px rgba(0, 0, 0, 0.3);color: black;max-width: 100%;padding: 3px 4px;position: fixed;z-index: 999999;box-sizing: border-box;cursor: default;white-space: pre;word-wrap: break-word;line-height: normal;font-style: normal;font-weight: normal;letter-spacing: normal;pointer-events: none;}.ace_folding-enabled > .ace_gutter-cell {padding-right: 13px;}.ace_fold-widget {box-sizing: border-box;margin: 0 -12px 0 1px;display: none;width: 11px;vertical-align: top;background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAANElEQVR42mWKsQ0AMAzC8ixLlrzQjzmBiEjp0A6WwBCSPgKAXoLkqSot7nN3yMwR7pZ32NzpKkVoDBUxKAAAAABJRU5ErkJggg==");background-repeat: no-repeat;background-position: center;border-radius: 3px;border: 1px solid transparent;cursor: pointer;}.ace_folding-enabled .ace_fold-widget {display: inline-block; }.ace_fold-widget.ace_end {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAANElEQVR42m3HwQkAMAhD0YzsRchFKI7sAikeWkrxwScEB0nh5e7KTPWimZki4tYfVbX+MNl4pyZXejUO1QAAAABJRU5ErkJggg==");}.ace_fold-widget.ace_closed {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAMAAAAGCAYAAAAG5SQMAAAAOUlEQVR42jXKwQkAMAgDwKwqKD4EwQ26sSOkVWjgIIHAzPiCgaqiqnJHZnKICBERHN194O5b9vbLuAVRL+l0YWnZAAAAAElFTkSuQmCCXA==");}.ace_fold-widget:hover {border: 1px solid rgba(0, 0, 0, 0.3);background-color: rgba(255, 255, 255, 0.2);box-shadow: 0 1px 1px rgba(255, 255, 255, 0.7);}.ace_fold-widget:active {border: 1px solid rgba(0, 0, 0, 0.4);background-color: rgba(0, 0, 0, 0.05);box-shadow: 0 1px 1px rgba(255, 255, 255, 0.8);}.ace_dark .ace_fold-widget {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAHklEQVQIW2P4//8/AzoGEQ7oGCaLLAhWiSwB146BAQCSTPYocqT0AAAAAElFTkSuQmCC");}.ace_dark .ace_fold-widget.ace_end {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAUAAAAFCAYAAACNbyblAAAAH0lEQVQIW2P4//8/AxQ7wNjIAjDMgC4AxjCVKBirIAAF0kz2rlhxpAAAAABJRU5ErkJggg==");}.ace_dark .ace_fold-widget.ace_closed {background-image: url("data:image/png;base64,iVBORw0KGgoAAAANSUhEUgAAAAMAAAAFCAYAAACAcVaiAAAAHElEQVQIW2P4//+/AxAzgDADlOOAznHAKgPWAwARji8UIDTfQQAAAABJRU5ErkJggg==");}.ace_dark .ace_fold-widget:hover {box-shadow: 0 1px 1px rgba(255, 255, 255, 0.2);background-color: rgba(255, 255, 255, 0.1);}.ace_dark .ace_fold-widget:active {box-shadow: 0 1px 1px rgba(255, 255, 255, 0.2);}.ace_inline_button {border: 1px solid lightgray;display: inline-block;margin: -1px 8px;padding: 0 5px;pointer-events: auto;cursor: pointer;}.ace_inline_button:hover {border-color: gray;background: rgba(200,200,200,0.2);display: inline-block;pointer-events: auto;}.ace_fold-widget.ace_invalid {background-color: #FFB4B4;border-color: #DE5555;}.ace_fade-fold-widgets .ace_fold-widget {transition: opacity 0.4s ease 0.05s;opacity: 0;}.ace_fade-fold-widgets:hover .ace_fold-widget {transition: opacity 0.05s ease 0.05s;opacity:1;}.ace_underline {text-decoration: underline;}.ace_bold {font-weight: bold;}.ace_nobold .ace_bold {font-weight: normal;}.ace_italic {font-style: italic;}.ace_error-marker {background-color: rgba(255, 0, 0,0.2);position: absolute;z-index: 9;}.ace_highlight-marker {background-color: rgba(255, 255, 0,0.2);position: absolute;z-index: 8;}.ace_text-input-ios {position: absolute !important;top: -100000px !important;left: -100000px !important;}
/*# sourceURL=ace/css/ace_editor.css */</style>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<meta name="viewport" content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=0">
<meta name="apple-mobile-web-app-capable" content="yes">
<meta name="mobile-web-app-capable" content="yes">
Copyright JS Foundation and other contributors, http://js.foundation
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<title>Node-RED : 192.168.0.18</title>
<link rel="icon" type="image/png" href="favicon.ico">
<link rel="mask-icon" href="red/images/node-red-icon-black.svg" color="#8f0000">
<link href="vendor/bootstrap/css/bootstrap.min.css" rel="stylesheet" media="screen">
<link href="vendor/jquery/css/smoothness/jquery-ui-1.10.3.custom.min.css" rel="stylesheet" media="screen">
<link rel="stylesheet" href="vendor/font-awesome/css/font-awesome.min.css">
<link rel="stylesheet" href="vendor/vendor.css">
<link rel="stylesheet" href="red/style.min.css">
<script type="text/javascript" src="blocky/js/lib/basic/blockly_compressed.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/msg/messages.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/blocks_compressed.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/javascript_compressed.js"></script>
<script type="text/javascript" src="blocky/js/lib/basic/msg/js/en.js"></script>
<script type="text/javascript" src="blocky/js/messages/en.js"></script>
<script type="text/javascript" src="blocky/js/lib/json/objectBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/json/objectBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/nodered/nodeRedBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/nodered/nodeRedBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/extra/extraBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/extra/extraBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/buffer/bufferBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/buffer/bufferBlocksDefs.js"></script>
<script type="text/javascript" src="blocky/js/lib/datetime/dateTimeBlocksCodeGen.js"></script>
<script type="text/javascript" src="blocky/js/lib/datetime/dateTimeBlocksDefs.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/theme-tomorrow.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/mode-markdown.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/ace/1.2.3/mode-nrjavascript.js"></script>
@Alacritous Do you have the node-red-contrib-python3-function
node installed? The function editor problem was connected to this.
Yes. I do. And I just removed it, refreshed the page and all is well in the world again. That is a weird one. A virtual beer goes to whoever figured that connection out.
Since v0.20 node-red (I use the docker version) appears automatically in my browser in german (my regular browser setting).
I would like to have node-red in English again. Is there any way to adjust this?
Have the same problem on a Windows node red installation. Any workaround for this?
