With free new installation, if i install node-red-contrib-s7 for first it work, and all other modules installed before have this issue.
In this case i have installed first node-red-dashboard and all other modules make this issue.
First package installed node-red-dashboard with v15, all other with v12.
then
reinstalled v15 then, from this moment I can't install any packages with v15
it work for the first package installed node-red-contrib-s7comm installed correctly, but in package.json it will add always "\"~\ before version. i have tried to install another package and will not work.
Ok, found problem... Thanks, i will continue use v12 for now ... or I will fix the file every time before installing a package.
Side note, I did notice that upgrading to 1.2.2 broke the restart persistence on the node-red-contrib-stoptimer-varidelay node (at least for me). Rolling back to 1.1.3 fixed it. I run my instances in docker containers, in case it matters.
I submitted an issue to the author, but thought I would mention it here as it certainly seems 1.2.x related since the only thing I did to make it work again was roll back to 1.1.3.
EDIT: Put the container back to 1.2.2 and confirmed that the node does not continue after restart, as mentioned. Rolled back to 1.1.3 and it is working as expected again after a NR restart. Definitely seems NR 1.2.x related...
Running it on my laptop - accessing via localhost. This isn't related to an upgrade however just in general, sometimes if I restart the instance; I login to find my flows missing. It's happened 3 or 4 times in the past 2 months since I've started using Node-RED again. Startup log doesn't mention anything right now but everything's working at the moment.
I want to use Node-RED in commercial environments but not sure if my clients may restart their systems and find that the flows are gone
That certainly should not happen unless something has changed on your system. Does it recover by itself or do you have to restore the flows from your backup?
As Nick asked, start node-red in a terminal and post the log here as that may give us a clue. When pasting the text in then use the </> button at the top of the forum text entry window and paste the log in.
Actually, since this isn't about an upgrade or about the new release of node-red it would be better to start a new thread for your issue. Please post the additional information there. Thanks.
I think that Nick is the only full-time Node-RED (core) developer. Some folk here use it professionally though. The rest of us vary in our day-jobs and, like Batman, inhabit the forum at night
