Hi yes as Nick suggested over there - 🎉 Node-RED 1.2.2 released the most likely cause is dhcp on your network giving you a different hostname for your laptop - in the log above - MacBook-Pro.lan1 - If you look in your ~/.node-red directory you will probably find several different flows_ files that are the missing ones... you can edit your settings.js file to set the flow file to a fixed name and it won't move again.
