Flows lost ; where are they gone?
hello
I was working with nodered for some month, and suddenly, my flows have disappeared.
It seems that one node or one flow makes node-red crash.
I can see it when i run node-red manually.
Ok, I can understand this, even if I didn't make no chnage in the involved node
But what is strange is that my flows have disappeared.
In my flows, there are some notofications wich are sent by IFTTT and a mail, also.
I receive the notification and the mail. so that means that my flows are still in may machine
but when I try to access to the node-red interface, by starting node-red with the comman --safe mode, to be sure that no flow is started, it works
But unfirtunately, I can see no more flow in the :1880 web interface.
How can it be?
Where are my flows?
How can I get them back on the node-red web interface?
I use :slight_smile:
1 Sep 22:42:59 - [info] Node-RED version: v0.20.5
1 Sep 22:42:59 - [info] Node.js  version: v10.15.3
1 Sep 22:42:59 - [info] Linux 4.14.63-rt40-pxc arm LE
The chances are that your machine has changed its name, which is used in the flows filename or you are starting Node-RED as a different user.
Change directory into your .node-red directory and see if there are more than one flows files in there. ( the startup messages list the directory you need and what the current loaded flows file is called.)
Hello
Quiet strange
How can the name of my device change?
How can i know the name of my device,
and modify it?
It's a PLC, running a kind of debian
2 Sep 16:03:12 - [info] Node-RED version:
v0.20.7
2 Sep 16:03:12 - [info] Node.js version:
v10.15.3
2 Sep 16:03:12 - [info] Linux 4.14.63-rt40-pxc
arm LE
2 Sep 16:03:24 - [info] Loading palette
nodes
ukmoose via Node-RED
Forum nodered@discoursemail.com
To:
mschneider@phoenixcontact.fr,
Date:
01/09/2019 23:22
Subject:
[Node-RED Forum]
[General] Flows lost ; where are they gi=one?
If it’s a PLC did the IP address change?
no, the IP adress did not chnage
To:
Date:
02/09/2019 16:35
Subject:
[Node-RED Forum]
[General] Flows lost ; where are they gone?
Show us the whole of the startup log. In there will be the name of the flow file in use.
Also have you done this?
Hello
finally, I found the error.
My flows have not diappeared
I made an error i the safe mode commande
In the help, it is written to type node-red --safe mode
But in fact, it is just necessary to type the command node-red --safe
I don't know the complete mecanism of node-red, but with the command node-red --safe mode, it tries to lauch a flow called mode, wich doesn't exist on my machine...
And so, I see an empty flow...
Thanks for your help : I Mis-interprete the information given in this page, because in the ggole search, only the simple text appeared, without any color.
