Frankly at end I started node red as a service
sudo systemctl enable nodered.service
It seems working although i had to reimport flows
That does not start node-red as a service, it just tells systemd to start it on boot (as a service).
node-red-start does start it as a service immediately but also shows you the startup log. It is effectively the same as sudo systemctl start nodered followed by sudo journalctl -f -n 0 -u nodered -o cat.
Yes.
The thing that worries me about using the upgrade command in the future is that I didn't understand what happened and why I lost my flows while keeping the palette.
Had you asked about how to fix that we could probably have helped. It may still be possible to work out what the problem was.
What does this command show?
ls -al /home/roberto/.node-red
i have a problem to have function of flowfuse.dashbard 2.0 (addon of home assistant).
[{"id":"0c44ce7ae7f9dcb0","type":"tab","label":"porte","disabled":false,"info":"","env":[]},{"id":"9d82c9d86212a10a","type":"ui-button","z":"0c44ce7ae7f9dcb0","group":"1cf97d7dc0a099ff","name":"texte","label":"button","order":1,"width":0,"height":0,"emulateClick":false,"tooltip":"","color":"","bgcolor":"","className":"","icon":"","iconPosition":"left","payload":"essai","payloadType":"str","topic":"topic","topicType":"msg","buttonColor":"","textColor":"","iconColor":"","x":250,"y":1080,"wires":[["dbf414e857f99ae2"]]},{"id":"dbf414e857f99ae2","type":"debug","z":"0c44ce7ae7f9dcb0","name":"debug 1","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":420,"y":1080,"wires":[]},{"id":"1cf97d7dc0a099ff","type":"ui-group","name":"My Group","page":"3e5a7def77e29cf0","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false"},{"id":"3e5a7def77e29cf0","type":"ui-page","name":"texte","ui":"9d35493ff7cdb9d8","path":"/texte","icon":"home","layout":"grid","theme":"723f3a378be587ae","order":1,"className":"","visible":"true","disabled":"false"},{"id":"9d35493ff7cdb9d8","type":"ui-base","name":"My Dashboard","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-text"],"showPathInSidebar":false,"showPageTitle":true,"navigationStyle":"default","titleBarStyle":"default"},{"id":"723f3a378be587ae","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px"}}]
home assistant addon configuration
theme: default
http_node:
username: patrick
password: xxxxxx
http_static:
username: patrick
password: cxxxx
ssl: true
certfile: fullchain.pem
keyfile: privkey.pem
system_packages: []
npm_packages: []
init_commands: []
log_level: error
start-up log
s6-rc: info: service legacy-services: stopping
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service nginx: stopping
s6-rc: info: service nginx successfully stopped
s6-rc: info: service init-nginx: stopping
s6-rc: info: service nodered: stopping
s6-rc: info: service init-nginx successfully stopped
s6-rc: info: service nodered successfully stopped
s6-rc: info: service init-nodered: stopping
s6-rc: info: service init-nodered successfully stopped
s6-rc: info: service init-customizations: stopping
s6-rc: info: service init-customizations successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service base-addon-log-level: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service base-addon-log-level successfully stopped
s6-rc: info: service base-addon-banner: stopping
s6-rc: info: service base-addon-banner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service base-addon-banner: starting
Add-on: Node-RED
Flow-based programming for the Internet of Things
Add-on version: 18.0.4
You are running the latest version of this add-on.
System: Home Assistant OS 12.4 (aarch64 / raspberrypi4-64)
Home Assistant Core: 2024.7.4
Home Assistant Supervisor: 2024.06.2
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
Log level is set to ERROR
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-nginx: starting
s6-rc: info: service init-customizations: starting
s6-rc: info: service init-customizations successfully started
s6-rc: info: service init-nodered: starting
s6-rc: info: service init-nginx successfully started
up to date, audited 163 packages in 4s
16 packages are looking for funding
run `npm fund` for details
est ce que quelq'un a la derniere version de nodered v4.0.2
found 0 vulnerabilities
npm notice
npm notice New minor version of npm available! 10.7.0 -> 10.8.2
npm notice Changelog: https://github.com/npm/cli/releases/tag/v10.8.2
npm notice To update run: npm install -g npm@10.8.2
npm notice
s6-rc: info: service init-nodered successfully started
s6-rc: info: service nodered: starting
s6-rc: info: service nodered successfully started
s6-rc: info: service nginx: starting
s6-rc: info: service nginx successfully started
s6-rc: info: service legacy-services: starting
s6-rc: info: service legacy-services successfully started
> start
> node $NODE_OPTIONS node_modules/node-red/red.js --settings /etc/node-red/config.js
url dashboard
https://xxxxx.duckdns.org/a0d7b954_nodered/ingress
@patrickL I am afraid the right people are not going to see this post burried at the bottom of this old Node-RED v4.0.0 release post.
Please start a new post in the Dashboard category and add the tag dashboard-2
Also add a description of the problem (currently you only have a bunch of logs). Perhaps a screenshot would help too.
thank you your response
so y do it now
I upgraded to v4.0.3
Some nodes are not compatible (PCCC, Telegram, etc.)
Are there any solutions?
How to get back to Vers. 3?
25 Sep 23:11:44 - [info] Node-RED version: v4.0.3
25 Sep 23:11:44 - [info] Node.js version: v20.17.0
25 Sep 23:11:44 - [info] Windows_NT 10.0.19045 x64 LE
25 Sep 23:11:45 - [info] Loading palette nodes
25 Sep 23:03:27 - [info] Waiting for missing types to be registered:
25 Sep 23:03:27 - [info] - node-red-contrib-whatsapp-cmb-account
25 Sep 23:03:27 - [info] - telegrambot-config
25 Sep 23:03:27 - [info] - pccc endpoint
25 Sep 23:03:27 - [info] - pccc out
25 Sep 23:03:27 - [info] - pccc in
2024-09-25T21:12:48.057Z Install : node-red-contrib-pccc 1.0.2
2024-09-25T21:12:52.144Z [err] npm error notsup Required: {"node":"8.x || 10.x"}
2024-09-25T21:12:52.144Z [err] npm error notsup Actual: {"npm":"10.8.3","node":"v20.17.0"}
Telegram is compatible with NodeRed 4.0.3 and NodeJs 20.17.0, Windows and Linux
It isn't the fact that you have upgraded node red that is causing the problem, but the fact that you have upgraded nodejs, but have not updated the nodes to their latest versions.
In your .node-red folder remove the node_modules folder and the file package.json.lock. Then in a command window go into that folder and run
npm install
which will install the latest versions of all the nodes. Then you will know whether you have a real problem.
If there are no errors then restart node-red.
Also, go to .node-red folder an run command npm rebuild
Since the node_modules folder has been removed and all packages have been re-installed, there is no need to rebuild. Normally, after a nodejs upgrade, it is only necessary to rebuild, but in this case some packages had not been updated to the latest versions before upgrading nodejs, so the easiest way is to get rid of them and re-install.
Thank you for your help.
To solve it I had to delete the entire .node-red folder.
Reinstall node-red and install all the nodes needed by my application updated.
Now everything is working
Thank you very much
You did not need to do all that. Did the procedure I suggested not work?
Unfortunately the procedure did not work correctly.
Surely I did something wrong.
Soon I will have to update other machines, and I will try again.
Thanks again
R.
On the next system, if you get problems, then come back and tell us what happened.
