The fourth and final beta release of Node-RED 4.0 is now available!
Node-RED 4.x requires at least Node 18.x. We recommend using Node 20
We weren't going to do another beta release, but some churn in our dependencies over the last few days means we've had to make some bigger dependency updates than we were planning. In particular the mqtt module has had a major version update. Whilst it all looks good in our local testing, it felt sensible to do one more beta refresh. I know this delays getting to the final release, but we want to make sure we don't rush out anything at the last minute.
There have been a number of other fixes and small enhancements made alongside the dependency updates.
The Change Log has the full list of changes.
Note: if any issues are reported against the beta, we'll update this post to list them here. If you hit a problem, please do check back here before adding a comment.
Known Issues
- none
Updated Proxy Handling
@Steve-Mcl has done a good job tidying up our support for proxies with the HTTP Request node. Our existing behaviour had a number of issues and didn't fully support the various standard environment variables used to configure proxies.
Details are in the original issue and the pull request that fixed it.
Better feedback for read-only users
Previously if a user had read-only access to the editor, they could make changes and click the deploy button - only to be told at that point they cannot make changes.
With this release, the Deploy button now shows a lock icon if the current user doesn't have permission to deploy changes. They can still make changes in the workspace, but the deploy button won't become enabled.
Other updates
- Middle mouse clicking now pans the workspace properly on Windows - thanks corentin-sodebo-voile
node-red --versionnow reports the node-red, node.js and os information without starting Node-RED.- A new
httpAdminCookieOptionsoption can be used to customise the options set on cookies as part of the authentication system - Various code hygiene fixes from Rotzbua
- Various tooltips and TypedInput fixes from @GogoVega
Be sure to read through the Change Log to see what else is in there.
Installing the beta
If you want to try out the beta, you will need specify node-red@next when you use npm to update. Without the @next you'll still get 3.x
So on a Pi you'd do:
sudo npm install -g --unsafe-perm node-red@next
Docker images
The beta images are available under nodered/node-red-dev:v4.0.0-beta.4 - with the default image being based on node 20.
Reporting problems
If you hit any problems, please report them either as a reply on this topic, or in the #core-dev slack channel. Please do not post new topics to the forum regarding the beta as that could confuse users who are not using the beta.
Outstanding work
This would have been the full release if it weren't for the dependency updates we've had to make. So expect the full release in the next 2 weeks.... which is what I said last time, but there is barely anything left to do at this point.
