I'm seeing a reproducible crash after upgrading from Node-RED 5.0.4 to 5.0.5 on two separate Raspberry Pi 4 Model B units (Rev 1.1 and Rev 1.2, both aarch64/Cortex-A72).
Environment:
- Raspberry Pi 4 Model B (both Rev 1.1 and Rev 1.2)
- Architecture: aarch64
- Node.js: v22.23.2
- Node-RED: 5.0.5 (crashes), 5.0.4 (works fine)
Symptom:
Running node-red --version or starting the service results in:
Illegal instruction
Via systemd, the service shows:
Main PID: XXXX (code=killed, signal=ILL)
The service enters a restart loop (activating (auto-restart)).
Steps to reproduce:
- Have Node-RED 5.0.4 running on Raspberry Pi 4 Model B with Node.js 22.x
sudo npm uninstall -g node-redsudo npm install -g --unsafe-perm node-red@5.0.5- Run
node-red --versionor start the systemd service
Result: Immediate crash with SIGILL on both devices.
Workaround: Downgrading back to node-red@5.0.4 with the same Node.js 22.23.2 resolves the issue completely; the service runs stable.
Notable: The same 5.0.5 version runs without issue on a Raspberry Pi 5 (Cortex-A76) in my setup, which points toward an ARM instruction-set incompatibility (possibly a native dependency using CPU features not present on Cortex-A72) rather than a general Node-RED bug.
Happy to provide more diagnostic info (cpuinfo, journalctl logs, etc.) if useful.
