I am trying to follow this tutorial to create a login for node red.
From what I can gather node-red admin is built into node red so why would I need to install a package? I get an error when using the tutorial trying npm install -g --unsafe-perm node-red-admin
Anyways but in Linux terminal this command works:
node-red-admin hash-pw
To retrieve the hash and sudo nano ~/.node-red/settings.js following the tutorial to uncomment the correct lines on my end it looks like this:
/** To password protect the Node-RED editor and admin API, the following
* property can be used. See http://nodered.org/docs/security.html for details.
adminAuth: {
type: "credentials",
users: [{
username: "ben",
password: "supersecretP@$$word",
permissions: "*"
/** The following property can be used to enable HTTPS
* This property can be either an object, containing both a (private) key
* and a (public) certificate, or a function that returns such an object.
* See http://nodejs.org/api/https.html#https_https_createserver_options_requestlistener
* for details of its contents.
And then thru nano writing the file and doing a sudo reboot I cant login with this username and password, any ideas to try?
