Hi everyone!
I have a problems while installing the node node-red-contrib-bluetooth-serial-port.
With node-red-contrib-bluetooth-serial-api (node) - Node-RED too but i resolved installing Visual Studio.
Can anyone help me to describe how to install the node node-red-contrib-bluetooth-serial-port?
Thans in advance
Colin
31 October 2023 21:07
2
Welcome to the forum.
See this issue. It appears the node no longer works, and is no longer maintained.
opened 03:55PM - 28 Oct 21 UTC
Unable to install the node. Raspberry Pi with Raspbian.
See console.log.txt for… installation output messages.
[2021-10-28T15_37_48_361Z-debug.log](https://github.com/RomRider/node-red-contrib-bluetooth-serial-port/files/7435604/2021-10-28T15_37_48_361Z-debug.log)
[console.log.txt](https://github.com/RomRider/node-red-contrib-bluetooth-serial-port/files/7435631/console.log.txt)
Colin:
d is no longer
Thanks Colin for your answer. Do you know if there are other node wich functions are similar to node-red-contrib-bluetooth-serial-port node?
I think the user TomerAbutbulQuris in the post you linked, shows a solution. How can i solved to works with this node?
I hope my english understand
Colin
1 November 2023 13:49
4
There is a link there to a fork that is supposed to fix the problem. You can install that by going into your .node-red folder (that is important) and running
npm install TomerAbutbulQuris/node-red-contrib-bluetooth-serial-port
then restart node-red.
