Node-red-contrib-cip-ethernet-ip Using Multiple Endpoints
I use the node-red-contrib-cip-ethernet-ip to read/write to ControlLogix PLC (1756-L73 via 1756-EN2T).
My Node-REd runs on a Windows Server 2019 machine.
Node Red V2.2.2
Node.js V 16.14.0
Has anyone successfully used node-red-contrib-cip-ethernet-ip or node-red-contrib-cip-st-ethernet-ip using multiple endpoints.
When I tried adding the endpoint for a CompactLogix PLC, I lost connection to the ControlLogix PLC, so I disabled the Endpoint for the CompactLogix PLC.
I can confirm I’ve had success doing this in the past although it wasn’t specifically with multiple AB devices.
Don’t think brand of device should really matter though.
