Node-red-contrib-dynamic-thermostat switch state?
i am attempting to use this dynamic thermostat with a underfloor heating project but in testing found that whenever i update the current it changes the switch state to true thereby locking the output on.
the yellow load is just a random value to represent changing current temp
sample outputs
as you can see the switch state is set to true each time but i have only changed the current temp in?
i am sure there is an easy way to fix this but how do i send topic switch:false at same time as topic current newValue?
if i click the switch false inject then the next output is correct
Please export your flow and attach it to a reply.
In order to make code readable and usable it is necessary to surround your code with three backticks (also known as a left quote or backquote ```)
   code goes here
You can edit and correct your post by clicking the pencil :pencil2: icon.
thanks for your reply @zenofmud but i have found node-red-contrib-heater controller which fits my needs perfectly.
