Thanks. I check for that.
What about this error:
https://github.com/tessel/node-usb/releases/download/1.5.0/usb_bindings-v1.5.0-node-v64-linux-arm.tar.gz
This URL does not exist...
When you have multiple problems and have a probable fix for one then fix that one first, then move on to the next. You never know whether fixing one will fix others.
Thanks for the help!!!
Downgrade from Node 10 to node 8 and now I can install it.
Now checking if it will work for my device.
What version of NODEJS & NODE-RED do people suggest loading onto a raspberry pi so it supports both node-red-contrib-generic-ble & node-red-contrib-mqtt-broker
Many thanks
Peter
I think that's a really good question. I've had to go back to 8.11.1 in order to use anything that is noble based (because of a dependency it has). I don't know if that's changed or if there are alternatives that can be used with more modern versions of Node.
Just if someone is still wondering - my finding is that https://github.com/abandonware may help here (https://github.com/abandonware/noble, https://github.com/abandonware/node-bluetooth-hci-socket) - these are "updates" of abandoned nodes.
Just in case - I still can't confirm it fully solve my particular task (trying to get eq3 node up) as I can't find similar "refresh" of noble-device. But maybe awareness of "abandonware" can help someone with their noble-related searches across the forum.
I had problems but ultimately got it working and thought I would share it here.
This is for a wireless pressure sensor.
[{"id":"35ad4fe4.069a3","type":"subflow","name":"SaveChart","info":"","category":"","in":[{"x":80,"y":60,"wires":[{"id":"f4457c36.28ce1"}]}],"out":[{"x":820,"y":80,"wires":[{"id":"cf553dbd.50f9a","port":0}]}]},{"id":"db9cbd5c.fb547","type":"file","z":"35ad4fe4.069a3","name":"","filename":"","appendNewline":true,"createDir":true,"overwriteFile":"true","x":690,"y":40,"wires":[[]]},{"id":"f7f46486.9881a8","type":"file in","z":"35ad4fe4.069a3","name":"","filename":"","format":"utf8","sendError":true,"x":530,"y":80,"wires":[["cf553dbd.50f9a"]]},{"id":"ac2168dc.ee28f8","type":"json","z":"35ad4fe4.069a3","name":"","x":530,"y":40,"wires":[["db9cbd5c.fb547"]]},{"id":"cf553dbd.50f9a","type":"json","z":"35ad4fe4.069a3","name":"","property":"payload","action":"","pretty":false,"x":690,"y":80,"wires":[[]]},{"id":"f4457c36.28ce1","type":"function","z":"35ad4fe4.069a3","name":"LoadSave","func":"var strSafe=msg.topic;\nif(strSafe)\n{\n strSafe=strSafe.replace(/[^a-z0-9]/gi, '_').toLowerCase();\n var loaded=context.get(strSafe)||0;\n msg.filename =\"/home/pi/charts/\"+strSafe+\".dat\";\n //node.warn(loaded);\n if(0===loaded)\n {\n //load chart!! \n msg.payload=\"load\";\n context.set(strSafe,1);\n \n //node.warn(\"Loading \" +strSafe);\n }\n else\n {\n //node.warn(\"Writing \" +strSafe);\n }\n return msg; \n}\nreturn null;\n\n","outputs":1,"noerr":0,"initialize":"","finalize":"","x":230,"y":60,"wires":[["99a5d40b.95d618"]]},{"id":"99a5d40b.95d618","type":"switch","z":"35ad4fe4.069a3","name":"Load data","property":"payload","propertyType":"msg","rules":[{"t":"neq","v":"load","vt":"str"},{"t":"eq","v":"load","vt":"str"}],"checkall":"false","repair":false,"outputs":2,"x":380,"y":60,"wires":[["ac2168dc.ee28f8"],["f7f46486.9881a8"]]},{"id":"f0623c31.28231","type":"inject","z":"c0d5dea4.880a9","name":"UUID2","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"835ab4c051e411e3a5bd0002a5d5c51b","payloadType":"str","x":170,"y":1060,"wires":[["9a0a1022.e97b68"]]},{"id":"4ee45d82.7d6984","type":"inject","z":"c0d5dea4.880a9","name":"Connect","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"connect","payloadType":"str","x":160,"y":1220,"wires":[["9a0a1022.e97b68"]]},{"id":"64a7bc8a.60895c","type":"inject","z":"c0d5dea4.880a9","name":"Disconnect","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":"","topic":"disconnect","x":160,"y":1260,"wires":[["9a0a1022.e97b68"]]},{"id":"d9ab88b6.f5d72","type":"inject","z":"c0d5dea4.880a9","name":"Subscribe","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"notify\":true,\"period\":300000}","payloadType":"json","x":160,"y":1300,"wires":[["9a0a1022.e97b68"]]},{"id":"9a0a1022.e97b68","type":"Generic BLE in","z":"c0d5dea4.880a9","name":"91039","genericBle":"84923153.a4594","useString":false,"notification":true,"x":390,"y":780,"wires":[["b122747d.ae8bf8"]]},{"id":"9b6490ee.d0915","type":"inject","z":"c0d5dea4.880a9","name":"Temperature","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a1c","x":150,"y":1020,"wires":[["9a0a1022.e97b68"]]},{"id":"3641ba9b.c527d6","type":"inject","z":"c0d5dea4.880a9","name":"UUID4","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"8cd67da0da9b11e390870002a5d5c51b","payloadType":"str","x":170,"y":1100,"wires":[["9a0a1022.e97b68"]]},{"id":"8765a6.765c9258","type":"inject","z":"c0d5dea4.880a9","name":"Measurement Interval","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a21","x":120,"y":980,"wires":[["9a0a1022.e97b68"]]},{"id":"7f9522da.dd3b24","type":"inject","z":"c0d5dea4.880a9","name":"Model Number","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a24","payloadType":"str","x":140,"y":900,"wires":[["9a0a1022.e97b68"]]},{"id":"b0c87c42.73eee8","type":"inject","z":"c0d5dea4.880a9","name":"Advertising Blob","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2aff","x":140,"y":940,"wires":[["9a0a1022.e97b68"]]},{"id":"84262a31.571158","type":"inject","z":"c0d5dea4.880a9","name":"Serial Number","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a25","x":150,"y":860,"wires":[["9a0a1022.e97b68"]]},{"id":"b38cbeae.f8196","type":"inject","z":"c0d5dea4.880a9","name":"Tx Power Level","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a07","payloadType":"str","x":140,"y":740,"wires":[["9a0a1022.e97b68"]]},{"id":"873ab5a3.a94b28","type":"inject","z":"c0d5dea4.880a9","name":"Firmware Revision","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a26","x":130,"y":820,"wires":[["9a0a1022.e97b68"]]},{"id":"2a1da5ef.c9438a","type":"inject","z":"c0d5dea4.880a9","name":"Manufacturer Name","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2a29","x":130,"y":780,"wires":[["9a0a1022.e97b68"]]},{"id":"b122747d.ae8bf8","type":"switch","z":"c0d5dea4.880a9","name":"","property":"payload.characteristics","propertyType":"msg","rules":[{"t":"hask","v":"2a07","vt":"str"},{"t":"hask","v":"2a29","vt":"str"},{"t":"hask","v":"2a26","vt":"str"},{"t":"hask","v":"2a25","vt":"str"},{"t":"hask","v":"2a24","vt":"str"},{"t":"hask","v":"2a21","vt":"str"},{"t":"hask","v":"2a1c","vt":"str"},{"t":"hask","v":"835ab4c051e411e3a5bd0002a5d5c51b","vt":"str"},{"t":"hask","v":"8cd67da0da9b11e390870002a5d5c51b","vt":"str"},{"t":"hask","v":"2aff","vt":"str"}],"checkall":"true","repair":false,"outputs":10,"x":550,"y":840,"wires":[["ef8770a2.c9f4f"],["7a67e2d5.3ef014"],["ef26d7e4.adb84"],["4c0386d9.f433a"],["807030ff.6e79"],["e3fe0737.88889"],["7bc659f5.3f20f8"],["4847047d.6e9414"],["419a1af0.665ef4"],["dc24018b.f20328"]]},{"id":"6f16aba8.2c8c7c","type":"inject","z":"c0d5dea4.880a9","name":"Probe","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":170,"y":1180,"wires":[["9a0a1022.e97b68"]]},{"id":"7bc659f5.3f20f8","type":"function","z":"c0d5dea4.880a9","name":"Temperature","func":"msg.topic = \"Temperature - 91039\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a1c\"];\n value = value.slice(1,5);\n value = value.readFloatBE();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":750,"y":940,"wires":[["59b52dda.bc0584"]]},{"id":"419a1af0.665ef4","type":"function","z":"c0d5dea4.880a9","name":"Pressure - UUID4","func":"msg.topic = \"Pressure\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"8cd67da0da9b11e390870002a5d5c51b\"][0];\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":770,"y":1020,"wires":[[]]},{"id":"4847047d.6e9414","type":"function","z":"c0d5dea4.880a9","name":"Pressure -UUID2","func":"msg.topic = \"Pressure - 91039\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"835ab4c051e411e3a5bd0002a5d5c51b\"];\n value = value.readInt16BE();\n value = ( value * .01 );\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":770,"y":980,"wires":[["9f5473e4.e02f08"]]},{"id":"fe7736ec.37fc3","type":"inject","z":"c0d5dea4.880a9","name":"Scale Value","props":[{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"2904","x":150,"y":1140,"wires":[["9a0a1022.e97b68"]]},{"id":"7a67e2d5.3ef014","type":"function","z":"c0d5dea4.880a9","name":"Manufacturer Name","func":"msg.topic = \"Manufacturer Name\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a29\"];\n value = value.toString();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":780,"y":740,"wires":[["715e79f1.f2f198"]]},{"id":"ef8770a2.c9f4f","type":"function","z":"c0d5dea4.880a9","name":"Tx Power","func":"msg.topic = \"Tx Power\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a07\"];\n value = value.readInt8(0);\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":740,"y":700,"wires":[["38745dab.ea67c2"]]},{"id":"ef26d7e4.adb84","type":"function","z":"c0d5dea4.880a9","name":"Firmware Revision","func":"msg.topic = \"Firmware Revision\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a26\"];\n value = value.toString();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":770,"y":780,"wires":[["fead7d07.d51c88"]]},{"id":"4c0386d9.f433a","type":"function","z":"c0d5dea4.880a9","name":"Serial Number","func":"msg.topic = \"Serial Number\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a25\"];\n value = value.toString();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":820,"wires":[["97078a73.c88768"]]},{"id":"807030ff.6e79","type":"function","z":"c0d5dea4.880a9","name":"Model Number","func":"msg.topic = \"Model Number\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a24\"];\n value = value.toString();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":860,"wires":[["25350398.e5b4b4"]]},{"id":"e3fe0737.88889","type":"function","z":"c0d5dea4.880a9","name":"Measurement Interval","func":"msg.topic = \"Measurement Interval\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload.characteristics[\"2a21\"];\n value = value.readInt16LE();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":780,"y":900,"wires":[["cacbb89f.dec4b8"]]},{"id":"dc24018b.f20328","type":"buffer-parser","z":"c0d5dea4.880a9","name":"Advertising Blob","data":"payload.characteristics[\"2aff\"]","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int32le","name":"Pressure","offset":0,"length":3,"offsetbit":0,"scale":"1","mask":""},{"type":"int16le","name":"Temperature","offset":2,"length":2,"offsetbit":0,"scale":"1","mask":""},{"type":"int8","name":"Battery Level","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"string","name":"Device","offset":6,"length":6,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"value","resultTypeType":"output","multipleResult":true,"fanOutMultipleResult":true,"setTopic":true,"outputs":4,"x":520,"y":1120,"wires":[["9fa63c53.de1da"],["2de7df6.58b912"],["3333ede7.c70e62"],["3b1853b7.2125b4"]]},{"id":"9fa63c53.de1da","type":"function","z":"c0d5dea4.880a9","name":"Pressure","func":"msg.topic = \"Pressure\";\nvar now = ( new Date() ).getTime();\nvar array = [\"0x0\"];\narray = array.concat(msg.payload);\nvar value = Buffer.from(array)\n value = value.readUInt32LE();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":740,"y":1060,"wires":[[]]},{"id":"2de7df6.58b912","type":"function","z":"c0d5dea4.880a9","name":"Temperature","func":"msg.topic = \"Temperature\";\nvar now = ( new Date() ).getTime();\nvar value = Buffer.from(msg.payload);\n value = value.readInt16LE(0);\n msg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":750,"y":1100,"wires":[[]]},{"id":"3b1853b7.2125b4","type":"function","z":"c0d5dea4.880a9","name":"Device Address","func":"msg.topic = \"Device Address\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload;\n value = value.toString();\nmsg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":760,"y":1180,"wires":[[]]},{"id":"3333ede7.c70e62","type":"function","z":"c0d5dea4.880a9","name":"Battery Level","func":"msg.topic = \"Battery Level\";\nvar now = ( new Date() ).getTime();\nvar value = msg.payload;\n msg.payload = {\n tstamp: now,\n data: value\n};\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":750,"y":1140,"wires":[["803d9839.8c53b"]]},{"id":"9ccd90f8.64da88","type":"status","z":"c0d5dea4.880a9","name":"91039 Status","scope":["9a0a1022.e97b68"],"x":150,"y":700,"wires":[["3e1d4899.48c7f"]]},{"id":"3e1d4899.48c7f","type":"function","z":"c0d5dea4.880a9","name":"","func":"if (msg.status.text == \"generic-ble.status.missing\") {\n msg.topic = \"connect\";\n} else if (msg.status.text == \"generic-ble.status.disconnected\") {\n msg.topic = \"connect\";\n} else if (msg.status.text == \"generic-ble.status.connected\") {\n msg.topic = \"\";}\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":700,"wires":[["a7a917f5.de3bf8"]]},{"id":"a7a917f5.de3bf8","type":"delay","z":"c0d5dea4.880a9","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"minutes","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":440,"y":700,"wires":[["9a0a1022.e97b68"]]},{"id":"78b5cf63.6417b","type":"ui_chart","z":"c0d5dea4.880a9","name":"Pressure","group":"b81ba18.34770e","order":11,"width":17,"height":6,"label":"Pressure","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"15","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1200,"y":980,"wires":[["81c60e68.4addc"]]},{"id":"7a894093.a733b8","type":"ui_chart","z":"c0d5dea4.880a9","name":"Temperature - Fahrenheit","group":"b81ba18.34770e","order":12,"width":17,"height":6,"label":"Temperature - Fahrenheit","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"365","removeOlderPoints":"","removeOlderUnit":"86400","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":1470,"y":940,"wires":[["ede0294d.cb1c7"]]},{"id":"38745dab.ea67c2","type":"ui_text","z":"c0d5dea4.880a9","group":"b81ba18.34770e","order":10,"width":5,"height":1,"name":"","label":"Tx Power","format":"{{msg.payload.data}}","layout":"row-left","x":960,"y":700,"wires":[]},{"id":"715e79f1.f2f198","type":"ui_text","z":"c0d5dea4.880a9","group":"b81ba18.34770e","order":1,"width":5,"height":1,"name":"","label":"Manufacturer Name","format":"{{msg.payload.data}}","layout":"row-left","x":1000,"y":740,"wires":[]},{"id":"fead7d07.d51c88","type":"ui_text","z":"c0d5dea4.880a9","group":"b81ba18.34770e","order":6,"width":5,"height":1,"name":"","label":"Firmware Revision","format":"{{msg.payload.data}}","layout":"row-left","x":990,"y":780,"wires":[]},{"id":"97078a73.c88768","type":"ui_text","z":"c0d5dea4.880a9","group":"b81ba18.34770e","order":5,"width":5,"height":1,"name":"","label":"Serial Number","format":"{{msg.payload.data}}","layout":"row-left","x":980,"y":820,"wires":[]},{"id":"25350398.e5b4b4","type":"ui_text","z":"c0d5dea4.880a9","group":"b81ba18.34770e","order":3,"width":5,"height":1,"name":"","label":"Model Number","format":"{{msg.payload.data}}","layout":"row-left","x":980,"y":860,"wires":[]},{"id":"cacbb89f.dec4b8","type":"ui_text","z":"c0d5dea4.880a9","group":"b81ba18.34770e","order":8,"width":5,"height":1,"name":"","label":"Measurement Interval","format":"{{msg.payload.data}}","layout":"row-left","x":1000,"y":900,"wires":[]},{"id":"59b52dda.bc0584","type":"change","z":"c0d5dea4.880a9","name":"","rules":[{"t":"move","p":"payload.data","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":940,"wires":[["3dd83ae6.3ea3be"]]},{"id":"9f5473e4.e02f08","type":"change","z":"c0d5dea4.880a9","name":"","rules":[{"t":"move","p":"payload.data","pt":"msg","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":1010,"y":980,"wires":[["78b5cf63.6417b","21404645.47dbc2"]]},{"id":"81c60e68.4addc","type":"subflow:35ad4fe4.069a3","z":"c0d5dea4.880a9","name":"","x":1350,"y":980,"wires":[["78b5cf63.6417b"]]},{"id":"ede0294d.cb1c7","type":"subflow:35ad4fe4.069a3","z":"c0d5dea4.880a9","name":"","x":1670,"y":940,"wires":[["7a894093.a733b8"]]},{"id":"3dd83ae6.3ea3be","type":"unit-converter","z":"c0d5dea4.880a9","category":"temperature","inputUnit":"C","outputUnit":"F","inputField":"payload","outputField":"payload","inputFieldType":"msg","outputFieldType":"msg","roundOutputField":false,"outputFieldDecimals":"","name":"C to F Conversion","x":1230,"y":940,"wires":[["7a894093.a733b8","b47398af.6c1bc"]]},{"id":"b47398af.6c1bc","type":"mqtt out","z":"c0d5dea4.880a9","name":"Temperature - 91087","topic":"Temperature - 91039","qos":"","retain":"","broker":"6b8f56d7.82af78","x":1460,"y":900,"wires":[]},{"id":"21404645.47dbc2","type":"mqtt out","z":"c0d5dea4.880a9","name":"Pressure - 91039","topic":"Pressure - 91039","qos":"","retain":"","broker":"6b8f56d7.82af78","x":1270,"y":1040,"wires":[]},{"id":"803d9839.8c53b","type":"mqtt out","z":"c0d5dea4.880a9","name":"Battery - 91039","topic":"Battery - 91039","qos":"","retain":"","broker":"6b8f56d7.82af78","x":1010,"y":1140,"wires":[]},{"id":"84923153.a4594","type":"Generic BLE","localName":"5B-6D-27-49-C9-28","address":"5b:6d:27:49:c9:28","uuid":"5b6d2749c928","characteristics":[]},{"id":"b81ba18.34770e","type":"ui_group","name":"Sensor 91039","tab":"367ad238.21995e","order":3,"disp":true,"width":17,"collapse":false},{"id":"6b8f56d7.82af78","type":"mqtt-broker","name":"PI","broker":"127.0.0.1","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"home/temperature","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"367ad238.21995e","type":"ui_tab","name":"Pressure Sensors","icon":"dashboard","order":5,"disabled":false,"hidden":false}]
