Hello Colin.
The issue is that I have around 2000 TCP connections open at the same time currently this takes up 80-90% of my raspberry computing power.
It runs fine in the start, but the longer it runs the more connections are established until InfluxDB shuts down. I don't know whether my flow is bad(see below) or there is an oversight in the node-red-contrib-influxdb so that it doesn't shut down the connections it creates.
I'm sending quite a bit of data and requesting to read quite a bit of data, so maybe it simply can't close the TCP connections as fast as it is creating them.
[{"id":"8463a30a.98469","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"38e32758.e955b8","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP03/light\" WHERE time > now()-10m\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":280,"wires":[["6e5ed824.af83b8"]]},{"id":"ce7ab224.553f2","type":"inject","z":"8463a30a.98469","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"0.5","crontab":"","once":true,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":110,"y":420,"wires":[["38e32758.e955b8","69676660.b82608","bf6b3cb5.5806f","5585e9f4.251548","c85ffadc.91a3c8","54734824.a36aa8","3c51c6a3.e6f1fa","a25f8c36.ddcd3"]]},{"id":"f7ee3802.f7bdc8","type":"debug","z":"8463a30a.98469","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":830,"y":320,"wires":[]},{"id":"8bbe2f64.c9b53","type":"ui_chart","z":"8463a30a.98469","name":"","group":"4f0696b7.3e3b78","order":2,"width":"20","height":"6","label":"Light Intensity over time","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"2","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#e6ff29","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":850,"y":280,"wires":[[]]},{"id":"6e5ed824.af83b8","type":"function","z":"8463a30a.98469","name":"compute series data","func":"var series = [\"light\"];\nvar data = [];\nvar labels = [\"brightness\"];\n\nfor(var i = 0, len = msg.payload.length; i < len; i++){\n data.push({x: msg.payload[i].time, y: msg.payload[i].light});\n}\n\nmsg.payload = [{\"series\": series, \"data\": [data], \"labels\": labels}];\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":280,"wires":[["8bbe2f64.c9b53","f7ee3802.f7bdc8"]]},{"id":"bf6b3cb5.5806f","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP04/temperature\" WHERE time > now()-1h\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":420,"wires":[["95c79a1c.5561a8"]]},{"id":"a1cd2ae2.4f8058","type":"debug","z":"8463a30a.98469","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":480,"wires":[]},{"id":"39ff684f.78e358","type":"ui_chart","z":"8463a30a.98469","name":"","group":"1490c23e.22a8ce","order":2,"width":"20","height":"6","label":"Temperature over time","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"10","ymax":"40","removeOlder":"2","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#b31e1e","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":840,"y":420,"wires":[[]]},{"id":"95c79a1c.5561a8","type":"function","z":"8463a30a.98469","name":"compute series data","func":"var series = [\"temperature\"];\nvar data = [];\nvar labels = [\"Temp in Celsius\"];\n\nfor(var i = 0, len = msg.payload.length; i < len; i++){\n data.push({x: msg.payload[i].time, y: msg.payload[i].temperature});\n}\n\nmsg.payload = [{\"series\": series, \"data\": [data], \"labels\": labels}];\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":420,"wires":[["39ff684f.78e358","a1cd2ae2.4f8058"]]},{"id":"5585e9f4.251548","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP04/humidity\" WHERE time > now()-1h\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":540,"wires":[["c761588b.1da828"]]},{"id":"1c0549be.bea276","type":"debug","z":"8463a30a.98469","name":"","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":810,"y":600,"wires":[]},{"id":"9e16d4de.8926d8","type":"ui_chart","z":"8463a30a.98469","name":"","group":"dfa426fa.425fe8","order":2,"width":"20","height":"6","label":"Humidity over time","chartType":"line","legend":"true","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"2","removeOlderPoints":"10000","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":830,"y":540,"wires":[[]]},{"id":"c761588b.1da828","type":"function","z":"8463a30a.98469","name":"compute series data","func":"var series = [\"humidity\"];\nvar data = [];\nvar labels = [\"STPLC_01\"];\n\nfor(var i = 0, len = msg.payload.length; i < len; i++){\n data.push({x: msg.payload[i].time, y: msg.payload[i].humidity});\n}\n\nmsg.payload = [{\"series\": series, \"data\": [data], \"labels\": labels}];\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":540,"wires":[["1c0549be.bea276","9e16d4de.8926d8"]]},{"id":"69676660.b82608","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP01/light\" WHERE time > now()-10s\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":200,"wires":[["de5ad39e.4d33"]]},{"id":"78287bac.e3fc34","type":"ui_gauge","z":"8463a30a.98469","name":"light_intensity","group":"2f2c6a68.1b0326","order":1,"width":0,"height":0,"gtype":"gage","title":"Light Intensity","label":"","format":"{{value}}","min":0,"max":"255","colors":["#00b500","#e6e600","#ca3838"],"seg1":"100","seg2":"200","x":740,"y":200,"wires":[]},{"id":"de5ad39e.4d33","type":"function","z":"8463a30a.98469","name":"","func":"msg.payload = [msg.payload[0].light];\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":200,"wires":[["78287bac.e3fc34"]]},{"id":"c85ffadc.91a3c8","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP07/detection\" WHERE time > now()-10m\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":680,"wires":[["de6fdcb7.9268f"]]},{"id":"59da06a0.646fc8","type":"ui_led","z":"8463a30a.98469","order":0,"group":"5d4d0fbb.ae46a","width":0,"height":0,"label":"Object moved on","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#008000","value":"0","valueType":"str"},{"color":"#ff0000","value":"1","valueType":"str"},{"color":"#ff0000","value":"2","valueType":"str"},{"color":"#ff0000","value":"3","valueType":"str"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":970,"y":660,"wires":[]},{"id":"de6fdcb7.9268f","type":"function","z":"8463a30a.98469","name":"","func":"msg.payload = msg.payload[msg.payload.length-1].detection;\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":680,"wires":[["59da06a0.646fc8","302b7465.628f1c","769a3f32.47275","7b28567b.b75478"]]},{"id":"302b7465.628f1c","type":"ui_led","z":"8463a30a.98469","order":0,"group":"5d4d0fbb.ae46a","width":0,"height":0,"label":"Object detected","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"0","valueType":"str"},{"color":"#008000","value":"1","valueType":"str"},{"color":"#ff0000","value":"2","valueType":"str"},{"color":"#ff0000","value":"3","valueType":"str"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":970,"y":700,"wires":[]},{"id":"769a3f32.47275","type":"ui_led","z":"8463a30a.98469","order":0,"group":"5d4d0fbb.ae46a","width":0,"height":0,"label":"Object still here","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"0","valueType":"str"},{"color":"#ff0000","value":"1","valueType":"str"},{"color":"#008000","value":"2","valueType":"str"},{"color":"#ff0000","value":"3","valueType":"str"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":970,"y":740,"wires":[]},{"id":"7b28567b.b75478","type":"ui_led","z":"8463a30a.98469","order":0,"group":"5d4d0fbb.ae46a","width":0,"height":0,"label":"No object","labelPlacement":"left","labelAlignment":"left","colorForValue":[{"color":"#ff0000","value":"2","valueType":"str"},{"color":"#008000","value":"3","valueType":"str"},{"color":"#ff0000","value":"1","valueType":"str"},{"color":"#ff0000","value":"0","valueType":"str"}],"allowColorForValueInMessage":false,"shape":"circle","showGlow":true,"name":"","x":970,"y":780,"wires":[]},{"id":"516f18ba.697f48","type":"ui_text","z":"8463a30a.98469","group":"c77859de.54fe38","order":0,"width":0,"height":0,"name":"","label":"X-axis","format":"{{msg.payload['x']}}","layout":"row-left","x":970,"y":820,"wires":[]},{"id":"5b55cce2.c9d854","type":"ui_text","z":"8463a30a.98469","group":"c77859de.54fe38","order":0,"width":0,"height":0,"name":"","label":"Y-axis","format":"{{msg.payload['y']}}","layout":"row-left","x":970,"y":860,"wires":[]},{"id":"79835ce7.f99804","type":"ui_text","z":"8463a30a.98469","group":"c77859de.54fe38","order":0,"width":0,"height":0,"name":"","label":"Z-axis","format":"{{msg.payload['z']}}","layout":"row-left","x":970,"y":900,"wires":[]},{"id":"b28deb83.01b7c8","type":"ui_chart","z":"8463a30a.98469","name":"","group":"ff3b6aa4.06fe98","order":0,"width":0,"height":0,"label":"IMU","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":1,"removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":970,"y":940,"wires":[[]]},{"id":"54734824.a36aa8","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP01/acceleration\" WHERE time > now()-3s\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":800,"wires":[["91cb3e9c.b5bc8"]]},{"id":"91cb3e9c.b5bc8","type":"function","z":"8463a30a.98469","name":"","func":"msg.payload = msg.payload[msg.payload.length-1]\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":800,"wires":[["516f18ba.697f48","5b55cce2.c9d854","79835ce7.f99804"]]},{"id":"3c51c6a3.e6f1fa","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP01/acceleration\" WHERE time > now()-1h\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":860,"wires":[["d651b5df.dcc068"]]},{"id":"d651b5df.dcc068","type":"function","z":"8463a30a.98469","name":"","func":"var series = [\"IMU\"];\nvar msg1 = [];\nvar msg2 = [];\nvar msg3 = [];\nvar labels = [\"X-axis\", \"Y-axis\", \"Z-axis\"];\n\nfor(var i = 0, len = msg.payload.length; i < len; i++){\n msg1.push({x: msg.payload[i].time, y: msg.payload[i].x});\n msg2.push({x: msg.payload[i].time, y: msg.payload[i].y});\n msg3.push({x: msg.payload[i].time, y: msg.payload[i].z});\n}\n\nmsg.payload = [{\"series\": series, \"data\": [msg1, msg2, msg3], \"labels\": labels}];\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":540,"y":860,"wires":[["b28deb83.01b7c8"]]},{"id":"a25f8c36.ddcd3","type":"influxdb in","z":"8463a30a.98469","influxdb":"5ecb4dc3.6713a4","name":"Influxdb","query":"SELECT * FROM \"ESP08/sound\" WHERE time > now()-1h\n","rawOutput":false,"precision":"ms","retentionPolicy":"","org":"my-org","x":380,"y":360,"wires":[["53d2415.5dc4ec"]]},{"id":"53d2415.5dc4ec","type":"function","z":"8463a30a.98469","name":"compute series data","func":"var series = [\"light\"];\nvar data = [];\nvar labels = [\"brightness\"];\n\nfor(var i = 0, len = msg.payload.length; i < len; i++){\n data.push({x: msg.payload[i].time, y: msg.payload[i].sound});\n}\n\nmsg.payload = [{\"series\": series, \"data\": [data], \"labels\": labels}];\n\nreturn msg","outputs":1,"noerr":0,"initialize":"","finalize":"","x":580,"y":360,"wires":[["1618b786.2961e8"]]},{"id":"1618b786.2961e8","type":"ui_chart","z":"8463a30a.98469","name":"","group":"a7f6f0cf.271e6","order":2,"width":"21","height":"7","label":"Sound Intensity over time","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"","ymax":"","removeOlder":"2","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"useUTC":false,"colors":["#e6ff29","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"outputs":1,"useDifferentColor":false,"x":850,"y":360,"wires":[[]]},{"id":"5ecb4dc3.6713a4","type":"influxdb","hostname":"172.20.66.5","port":"8086","protocol":"http","database":"FestoSensors","name":"smartProdLab","usetls":false,"tls":"d50d0c9f.31e858","influxdbVersion":"1.x","url":"http://localhost:8086","rejectUnauthorized":true},{"id":"4f0696b7.3e3b78","type":"ui_group","name":"Light","tab":"4ff4ca1.8bd2f34","order":6,"disp":true,"width":"20","collapse":false},{"id":"1490c23e.22a8ce","type":"ui_group","name":"Temperature","tab":"4ff4ca1.8bd2f34","order":5,"disp":true,"width":"20","collapse":false},{"id":"dfa426fa.425fe8","type":"ui_group","name":"Humidity","tab":"4ff4ca1.8bd2f34","order":7,"disp":true,"width":"20","collapse":false},{"id":"2f2c6a68.1b0326","type":"ui_group","name":"Light(Live)","tab":"4ff4ca1.8bd2f34","order":1,"disp":true,"width":"6","collapse":false},{"id":"5d4d0fbb.ae46a","type":"ui_group","name":"Linetracker","tab":"4ff4ca1.8bd2f34","order":3,"disp":true,"width":"6","collapse":false},{"id":"c77859de.54fe38","type":"ui_group","name":"IMU(live)","tab":"4ff4ca1.8bd2f34","order":2,"disp":true,"width":"6","collapse":false},{"id":"ff3b6aa4.06fe98","type":"ui_group","name":"IMU","tab":"4ff4ca1.8bd2f34","order":9,"disp":true,"width":"20","collapse":false},{"id":"a7f6f0cf.271e6","type":"ui_group","name":"festoSound","tab":"4ff4ca1.8bd2f34","order":10,"disp":true,"width":"21","collapse":false},{"id":"d50d0c9f.31e858","type":"tls-config","name":"","cert":"","key":"","ca":"","certname":"","keyname":"","caname":"","servername":"","verifyservercert":false},{"id":"4ff4ca1.8bd2f34","type":"ui_tab","name":"Festo Dashboard","icon":"FestoSensors","disabled":false,"hidden":false}]
