Node-red-contrib-json-db DataError: The Data Path can't be empty
I have used this node before without issue, however when I run it in the latest docker container I am getting this error message. DataError: The Data Path can't be empty. If I test it outside a docker it works fine, but soon as it is in a docker container the error message appears.
Here is the example flow I have been using.
        "id": "50cbab180f96f2ec",
        "type": "DataIn",
        "z": "54e00243c63a0667",
        "collection": "dd241ba0efa3c601",
        "update": false,
        "topic": "",
        "x": 910,
        "y": 720,
        "id": "b534ad217423053c",
        "type": "DataOut",
        "topic": "",
        "error": false,
        "x": 920,
        "y": 780,
                "668fc139d5107d1c"
        "id": "bd22848411e9cc13",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "datapath",
                "v": "/client",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 720,
        "y": 720,
                "50cbab180f96f2ec"
        "id": "ad69d02b37b5abcf",
        "type": "inject",
        "props": [
                "p": "datapath",
                "v": "/",
                "vt": "str"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "x": 710,
        "y": 780,
                "b534ad217423053c"
        "id": "668fc139d5107d1c",
        "type": "debug",
        "name": "debug 2",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": true,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "payload",
        "statusType": "auto",
        "x": 1100,
        "y": 780,
        "id": "dd241ba0efa3c601",
        "type": "json-db-collection",
        "collection": "workplace",
        "save": true
I thought this could be a permission issue so I did a chmod 777 to the JsonDB folder and file that was created, but still no luck. Does anyone have any ideas as to why this flow works on a stand alone version but not in a docker container?
Well, I tried in docker and it failed.
But so did the example delivered with it, too.
The node has not been updated in 6 years and most of it is way older...
I guess the node simply is broken.
Thanks for testing it out man, I tried what looks to be another clone and it looks to work. json-db-node-red So if anyone else has this issue just do not use that repo and use this one.
