Hello Everyone,
I have recently upgraded by docker image of node-red to 2.1.4. While i deploy the the node-red pod in kubernetes i am able to see the logs below.
These errors are not impacting the functionality of node-red. Yet i am still trying to understand what these errors implies.
(node:19) [MONGODB DRIVER] Warning: Current Server Discovery and Monitoring engine is deprecated, and will be removed in a future version. To use the new Server Discover and Monitoring engine, pass option { useUnifiedTopology: true } to the MongoClient constructor.
(Use node --trace-warnings ... to show where the warning was created)
7 Jan 08:52:37 - [error] Error: ENOENT: no such file or directory, open '/data/package.json'
7 Jan 08:52:38 - [warn] Use of httpRoot is DEPRECATED. Use httpNodeRoot/httpAdminRoot instead
khayal@test-efk:~/JCI.OpenBlueBridge.NodeRedService$
Issues · debug-js/debug
A tiny JavaScript debugging utility modelled after Node.js core's debugging technique. Works in Node.js and web browsers - Issues · debug-js/debug
