I get this error
Flushing file \Users\Muham\.node red\*.$$$ to disk failed : Error: ENOENT: no such file or directory, open 'C:\Users\Muham\.node-red\*.$$$'" 6/14/2022, 11:31:01 AM msg : string[92] "Error saving flows: ENOENT: no such file or directory, open 'C:\Users\Muham\.node-red\*.$$$'" 6/14/2022, 11:31:01 AM msg : string[79] "Error: ENOENT: no such file or directory, open 'C:\Users\Muham\.node-red\*.$$$
whenever I deploy any flow in node-red.
Kindly help me so that I can continue my learning.
What is the exact command you use to start node-red?
Have you modified settings.js
Are you using the account Muham to run node-red?
What version of node-red and node-js are you using?
Is this node-red running in docker or other container?
