Node-red-contrib-looptimer-advanced use with dashboard text node
I wanted to see if I could get some help with the configuration of node-red-contrib-looptimer-advanced and trigger node with dashboard text input nodes.
I am trying to use two dashboard text input nodes to change the "Loop every time" of the looptimer and the delay time of a subsequent trigger node.
I have spent hours trying to figure out how to configure the ON time and OFF time test nodes, but have not been able to get them to work. I have tried setting the "ON time" node to msg.loop.duration but this reboots node red everytime the node is used.
I have attached the flow below and would really appriciate some help with setting up the "ON Time" and "OFF Time" nodes.
flows.json (5.5 KB)
