node-red-contrib-opcua – Value and timestamp do not update after write
I am using node-red-contrib-opcua and following the example flow from here:
The server starts correctly and I can connect with UaExpert without any problems. Browsing works and I can see the variables.
However, when I change a variable value — either:
  • by writing from UaExpert, or
  • by updating the value from Node-RED (via inject / server message)
the following happens:
  • The value does not change (it stays the same as before), and
  • The timestamp is not updated.
There are no visible errors in Node-RED.
I am using:
  • node-red-contrib-opcua version: 0.2.348
  • OPC UA Server running on opc.tcp://127.0.0.1:53880
  • Anonymous login, SecurityPolicy: None
Questions:
  • Is there anything special required to trigger a DataChange?
  • Does the server require a specific message format to properly update value and timestamp?
  • Is sourceTimestamp handled automatically or must it be set manually?
Any hints would be appreciated.
Thank you!
I have exactly the same and when I try to write on a variable that is created automatically by the OPC-UA server (MyVariable2) it is working??
I downgraded from 0.2.350 to 0.2.340 and it is working perfectly I am suspecting a bug on 350 maybe in the command to change the variable value...
What have you downgraded?
Opc-ua package to 0.2.340 right now the latest is 0.2.350 and the guy who started the chat is in 0.2.348.
