Node-red-contrib-postgresql 0.9.0 with global variables
I'm using "node-red-contrib-postgresql 0.9.0" to change data with a PostgresSQL database.
To use variables in my query it's necessary to use {{{msg.payload.VARIABLE}}}, and it's working fine. But when i tried to use {{{global.get("VARIABLE")}}} this not work.
Can anyone help me telling the right syntax to use global variables in my case?
Thanks.
Have you tried {{{global.VARIABLE}}}
Thanks for the answer!
I tested it and, does not work yet.
I have tried:
-{{{global.VARIABLE}}}
-{{{global."VARIABLE"}}}
-{{{global.get("VARIABLE")}}}
Exactly where are you entering that?
Also what do you mean by does not work?
In my case, i need to read the column "modelo_turno" from the table "usuario".
The query camp is working like that:
SELECT modelo_turno
FROM {{{msg.payload.schema}}}.usuario
The schema will be a string variable, because of that i am using a function node before the PostgresSQL node to read a string from a global variable and write it on the msg.payload to use in my query.
Would simplify my program if i use the global variable directly, instead of using the function all time.
So what exactly isn't working?
Everything is working, but i want to know if its possible to use the global variable instead of the msg.payload in my query.
In what way. In what node (full name e.g. node-red-contrib-xxxx)?
Can you show us how you are attempting to use this format?
I'm using Node-red-contrib-postgresql 0.9.0.
It seems the author has elected to only support the msg object (see here: node-red-contrib-postgresql/postgresql.js at a524c9a77cd6481e6090d0dfee138c43509df574 · alexandrainst/node-red-contrib-postgresql · GitHub)
as opposed to the built in template node which supports global and flow context (node-red/packages/node_modules/@node-red/nodes/core/function/80-template.js at 702545e0b238f160cce9b339808b230f9d741b08 · Steve-Mcl/node-red · GitHub)
You could raise a request on the issues page of that node asking if the author would support accessing {{{flow.var}}} and {{{global.var}}} in the node.
That said, you are far better off using parameters (as described here: GitHub - alexandrainst/node-red-contrib-postgresql: Node-RED node for PostgreSQL, supporting parameters, split, back-pressure) as they will help you avoid the problem of quotes in string values and avoid SQL injection issues.
