Node-red-contrib-rainbird
Hello
Just wondering if anyone uses Node-red-contrib-rainbird. It was working great but ever since Rainbird did a firmware update last week it has stopped working.
Anyone else have the same issue or know how to fix it?
I see this has been raised as an issue against the node, I suggest you watch that issue.
Update on this - Apparently the controller's local API doesn't accept connections on port 80 anymore, only 443. Refer to this link Unable to connect to Rainbird RC2 Controller · Issue #162671 · home-assistant/core · GitHub
It's a long shot, but would anyone what changes need to be made to node-red-contrib-rainbird/node-rainbird.js at main · maciejs20/node-red-contrib-rainbird · GitHub
to get it to work again?
Maybe just try changing this line to use https instead of http?
At a quick glance I would try changing line153 to be https
Hah ! Beat me to it
:wink: Only because I was already in the forum posting another thread for you to read Dave!
Thanks for the reply, that worked.
