Rainbird control from node-red
Hello
I have successfully installed node-rainbird - npm and using it in node-red.
The example on how to use the package states:
const RainBirdClass = require('node-rainbird');
let rainbird = new RainBirdClass("your_ip_address", "your_password");
rainbird.setDebug(); // Only set this for verbose logging information
rainbird
.stopIrrigation()
.then(console.log)
.catch(console.error);
I can run this on my machine using node.js and return the message successfully to console. But how do I return the console.log into a msg.payload instead in a node-red function?
In my function I tried:
let rainbird = new RainBirdClass("MY_IP", "MY_PASSWORD");
let temp = rainbird.getSerialNumber();
msg.payload = temp;
but I get an empty payload :\
The function node does not support require - use the setup tab
This article should help: Use any npm module in Node-RED • FlowFuse
Sorry I pasted my function wrong
I have
var rainbird = new RainBirdClass("MY_IP", "MY_PASSWORD");
msg.payload = temp;
Add node.warn({ RainBirdClass }) to the start of the function, fire a msg into it then inspect the debug sidebar - what do you see?
I see this:
Then your solution is
const rainbird = new RainBirdClass("MY_IP", "MY_PASSWORD");
msg.payload = await rainbird.getSerialNumber();
return msg
The functions in the README dont say they return a promise but a quick glance at the package reveals they return a request promise. Therefore you eaither need to await or do the then().catch
If you want to do promise chain then its like this...
const rainbird = new RainBirdClass.RainBirdClass("MY_IP", "MY_PASSWORD");
rainbird.getSerialNumber().then(result => {
    msg.payload = result
    node.send(msg)
}).catch(err => {
    node.error(err, msg)
Thank you very much!
