Once again I got stuck ![]()
My initial try is to simplify a lineString with the turf-node. For some reason it won't accept my options I am giving in the payload array.
It returns the error 'options is invalid' and I can't figure out how to fix it.
My function-node to pass everything into turf-node:
var geojson = {
"type":"FeatureCollection",
"features":[
"type": "Feature",
"properties": {},
"geometry": {
"type": "LineString",
"coordinates": msg.payload.line
// [0.1, 0.02],
// [0.2, 0.03],
// [0.3, 0.04],
// [0.4, 0.04],
// [0.5, 0.04],
// [0.6, 0.04],
// [0.6, 0.05],
// [0.7, 0.06],
// [0.8, 0.06],
// [0.9, 0.06],
// [0.12, 0.07],
// [0.15, 0.08],
// [0.15, 0.09],
// [0.14, 0.2],
// [0.16, 0.3],
// [0.16, 0.4],
// [0.17, 0.5],
// [0.18, 0.5],
// [0.19, 0.6],
// [0.19, 0.6]
// var geojson=turf.line([[msg.payload.line]]);
var options={tolerance:1};
msg.payload=[geojson, options];
// msg.payload=[geojson];
This are my findings so far:
I found in @turf/turf (line 50) that the error is thrown when checking if the options are an object. For some reason that function (line 765) returns 'false'.
I tried another function (transformRotate) where options need to be given as an object and it gave me the same error.
If I pass the function without options, the function works. As far as I can tell, when no options, an empty object is given and after the object-check, default values are applied to the function (see @turf/turf lines 47-53).
Here is the flow of the other function I tried:
"id": "f08a6c2679cbbad8",
"type": "function",
"z": "488c966fd330b21d",
"func": "var geojson = {\n \"type\":\"FeatureCollection\",\n \"features\":[\n {\n \"type\": \"Feature\",\n \"properties\": {},\n \"geometry\": {\n \"type\": \"LineString\",\n \"coordinates\": [\n [0,29],\n [3.5,29],\n [2.5,32],\n [0,29]\n ]\n }\n }\n ]\n};\n\nvar options = {pivot: [0, 25]};\nvar turfcontext=[geojson, 60, options];\n//var turfcontext=[geojson, 60];\nvar turffunction = \"transformRotate\";\n\nmsg.topic=turffunction;\nmsg.payload=turfcontext;\n\nreturn msg;",
"outputs": 1,
"noerr": 0,
"initialize": "",
"finalize": "",
"libs": [],
"x": 1720,
"y": 1640,
"bda6969dc2774169",
"70199edc46546716"
"id": "bda6969dc2774169",
"type": "debug",
"name": "simpifyfunction",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"statusVal": "",
"statusType": "auto",
"x": 1880,
"y": 1580,
"id": "70199edc46546716",
"type": "turf",
"fn": "",
"x": 1890,
"y": 1640,
"d2b1d18b5fc9d603"
"id": "1175fe8e598c32f3",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 1540,
"y": 1640,
"f08a6c2679cbbad8"
"id": "d2b1d18b5fc9d603",
"type": "debug",
"name": "simplify2",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"statusVal": "",
"x": 2040,
"y": 1660,
If anyone could point me in the right direction to get this working... ![]()
Thanks in advance,
node-RED v2.2.2
nodejs v12.22.9
