Problem with Node-Red Machine Learning
Hello together,
I want to gain some experience concerning machine learning. Therefore I tried the NR example:
node-red-contrib-machine-learning-v2, but I cant get the first part of the flow working. I receive always the errormessage: "TypeError: The "options" argument must be of type object. Received an instance of Array"
I tried to solve it with Chatgbt, but without success.
Here is the flow:
        "id": "303046aefb5b7d4b",
        "type": "create dataset",
        "z": "971acec15c383851",
        "name": "Create dataset",
        "path": "C:\\Users\\henz\\Desktop\\nodered_project\\test\\iris.data",
        "saveFolder": "C:\\Users\\henz\\Desktop\\nodered_project\\test\\datasets",
        "saveName": "iris",
        "input": "[0,1,2,3]",
        "output": "4",
        "trainingPartition": "80",
        "shuffle": true,
        "seed": "42",
        "x": 720,
        "y": 120,
                "35158521a6ddcce8"
        "id": "add958568b34bc5d",
        "type": "inject",
        "name": "start",
        "props": [
                "p": "topic",
                "vt": "str"
                "p": "payload"
        "repeat": "",
        "crontab": "",
        "once": false,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 230,
        "y": 120,
                "303046aefb5b7d4b"
        "id": "35158521a6ddcce8",
        "type": "debug",
        "name": "print",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "payload",
        "targetType": "msg",
        "statusVal": "",
        "statusType": "auto",
        "x": 950,
        "y": 80,
path to test folder: C:\Users\henz\Desktop\nodered_project\test
path to dataset folder C:\Users\henz\Desktop\nodered_project\test\datasets
Maybe some of you guys can help me.
Thank you in advance!
