Node-red-contrib-tuya-smart-device "Cannot find the device"
Hello.
As said in the title, I can't seem to find the tuya device (socket) i'm looking for.
I have the Local key, device ID and IP addr. from the tuyaAPI (Im not using both ID & IP).
I can find the device and control it via. "smart industry" app.
The weird thing is, that I have been connected, and without any changes it disconnected and now i don't seem to be able to connect again.
Im running node-red on win10.
Can't ping the IP.
Am connected to same network.
You cannot have Tuya devices connected to 2 hubs. So, either Node-red nodes OR "smart industry" app. (and only 1 Node-red-contrib-tuya-smart-device node also)
Having said that, you should be able to ping the device, I can ping all mine from Windows. Check that it is still turned on (had that happen to me before) and recheck the API results
Also check on your router/device that gives out IP addresses and see if it is getting an address and if it corresponds to what you have put in the app
Craig
