Node-red-contrib-ui-table headerHozAlign
Hi
I recently discovered the ui-table node. Very cool - kudos to the developer!!
My issue is that the headerHozAlign attribute does not do anything to the table. All the other options have an effect (formating is in node named "ui_control table"). Below the json object to import.
[ { "id": "67b0dda5c1bb8eae", "type": "change", "z": "e69e2b820328072e", "name": "ui_control table", "rules": [ { "t": "set", "p": "ui_control", "pt": "msg", "to": "{\"tabulator\":{\"columns\":[{\"headerHozAlign\":\"center\",\"title\":\"Attribut\",\"field\":\"Attribut\",\"width\":220,\"frozen\":true},{\"headerHozAlign\":\"center\",\"title\":\"Nominal\",\"field\":\"Nominal\",\"width\":150,\"hozAlign\":\"center\"},{\"title\":\"Actual\",\"field\":\"Actual\",\"width\":100,\"align\":\"center\"}],\"formatter\":\"plaintext\",\"layout\":\"fitColumns\",\"movableColumns\":true,\"groupBy\":\"\",\"initialSort\":[{\"column\":\"Attribut\",\"dir\":\"asc\"}]}}", "tot": "json" } ], "action": "", "property": "", "from": "", "to": "", "reg": false, "x": 580, "y": 380, "wires": [ [ "ed66aed26e2e01ea" ] ] }, { "id": "ed66aed26e2e01ea", "type": "link out", "z": "e69e2b820328072e", "name": "ui_control header return", "mode": "return", "links": [], "x": 755, "y": 380, "wires": [] }, { "id": "8460896df5bfaab0", "type": "link in", "z": "e69e2b820328072e", "name": "ui_control table", "links": [], "x": 425, "y": 380, "wires": [ [ "67b0dda5c1bb8eae" ] ] }, { "id": "73a983a364284c76", "type": "function", "z": "e69e2b820328072e", "name": "table generator", "func": "\n\nlet _table = []\n\n _table.push({\n \"Attribut\": \"y\",\n \"Nominal\" : 10,\n \"Actual\" : 11,\n \"tol\": \"red\"\n },\n {\n \"Attribut\": \"b\",\n \"Nominal\": 20,\n \"Actual\": 20,\n \"tol\": \"\"\n },\n {\n \"Attribut\": \"c\",\n \"Nominal\": 5,\n \"Actual\": 10,\n \"tol\": \"red\"\n }\n )\n \n\n//msg.onlyUpdateRows=true\n\nmsg.payload = _table\n\n\nreturn msg;", "outputs": 1, "noerr": 0, "initialize": "", "finalize": "", "libs": [], "x": 380, "y": 540, "wires": [ [ "4439ec4124259b98" ] ] }, { "id": "4439ec4124259b98", "type": "link call", "z": "e69e2b820328072e", "name": "", "links": [ "8460896df5bfaab0" ], "linkType": "static", "timeout": "30", "x": 600, "y": 540, "wires": [ [ "e6722dbe12656673", "4a8a2bde719c5837" ] ] }, { "id": "e6722dbe12656673", "type": "ui_table", "z": "e69e2b820328072e", "group": "0e44d66d97260f34", "name": "nominal vs real", "order": 1, "width": 8, "height": 18, "columns": [], "outputs": 0, "cts": false, "x": 860, "y": 540, "wires": [] }, { "id": "3c262e5e819dd87b", "type": "inject", "z": "e69e2b820328072e", "name": "", "props": [ { "p": "payload" }, { "p": "topic", "vt": "str" } ], "repeat": "", "crontab": "", "once": false, "onceDelay": 0.1, "topic": "", "payload": "", "payloadType": "date", "x": 180, "y": 540, "wires": [ [ "73a983a364284c76" ] ] }, { "id": "4a8a2bde719c5837", "type": "debug", "z": "e69e2b820328072e", "name": "debug 1", "active": true, "tosidebar": true, "console": false, "tostatus": false, "complete": "true", "targetType": "full", "statusVal": "", "statusType": "auto", "x": 860, "y": 460, "wires": [] }, { "id": "0e44d66d97260f34", "type": "ui_group", "name": "Nominale VS Reale Werte", "tab": "f0b58557b2604459", "order": 1, "disp": true, "width": "8", "collapse": false, "className": "" }, { "id": "f0b58557b2604459", "type": "ui_tab", "name": "Recipe vs. current values", "icon": "dashboard", "order": 1, "disabled": false, "hidden": false } ]
According to gitHub-Page they moved to tabulator v5 so the function should exist.
Am I doing something wrong?
Thank you very much!
No we still use tabulator v4. So headerHozAlign is not available.
