Hi, yesterday in a test with modbus server, I lost connection with node-red server.
Now I'm not able to make any change because node-red crash after a start.
How can I solve it?
See attached log:
Welcome to Node-RED
7 Oct 05:34:08 - [info] Node-RED version: v2.0.6
7 Oct 05:34:08 - [info] Node.js version: v14.17.6
7 Oct 05:34:08 - [info] Linux 5.10.60-v7l+ arm LE
7 Oct 05:34:09 - [info] Loading palette nodes
7 Oct 05:34:12 - [info] Dashboard version 2.29.3 started at /ui
7 Oct 05:34:13 - [info] Settings file : /home/pi/.node-red/settings.js
7 Oct 05:34:13 - [info] Context store : 'default' [module=localfilesystem]
7 Oct 05:34:13 - [info] User directory : /home/pi/.node-red
7 Oct 05:34:13 - [warn] Projects disabled : editorTheme.projects.enabled=false
7 Oct 05:34:13 - [warn] Flows file name not set. Generating name using hostname.
7 Oct 05:34:13 - [info] Flows file : /home/pi/.node-red/flows_raspberrypi.json
7 Oct 05:34:13 - [info] Server now running at http://127.0.0.1:1880/
your credentials.
7 Oct 05:34:13 - [info] Starting flows
7 Oct 05:34:13 - [info] Started flows
http://10.10.5.3/api/get?api_user=sdRC4s&api_secret=8btcXM2VJp81Bp7u&action=periph.caract&periph_id=2391623
http://10.10.5.3/api/get?api_user=sdRC4s&api_secret=8btcXM2VJp81Bp7u&action=periph.caract&periph_id=2461212
http://10.10.5.3/api/get?api_user=sdRC4s&api_secret=8btcXM2VJp81Bp7u&action=periph.caract&periph_id=2461204
7 Oct 05:34:15 - [red] Uncaught Exception:
7 Oct 05:34:15 - RangeError [ERR_BUFFER_OUT_OF_BOUNDS]: Attempt to access memory outside buffer bounds
at boundsError (internal/buffer.js:81:11)
at Buffer.readUInt8 (internal/buffer.js:249:5)
at ModbusServerResponseHandler._handleWriteSingleCoil (/home/pi/.node-red/node_modules/jsmodbus/dist/modbus-server-response-handler.js:133:45)
at ModbusServerResponseHandler.handle (/home/pi/.node-red/node_modules/jsmodbus/dist/modbus-server-response-handler.js:40:33)
at ModbusServerClient._onData (/home/pi/.node-red/node_modules/jsmodbus/dist/modbus-server-client.js:33:35)
at Socket.emit (events.js:400:28)
at addChunk (internal/streams/readable.js:290:12)
at readableAddChunk (internal/streams/readable.js:265:9)
at Socket.Readable.push (internal/streams/readable.js:204:10)
at TCP.onStreamRead (internal/stream_base_commons.js:188:23)
Stop, start in safe mode (node-red --safe), fix issue, restart
Having fixed it as suggested, which modbus node and which version are you using? node-red-contrib-something probably. The crash should be reported as an issue as no mis-configuration should cause node-red to crash.
Hi Colin,
I'm using this version:
node-red-contrib-modbus
5.14.0
I'm going to update to 5.14.1
Thanks!
