Node-Red crashed Starting Flows - help please
Hi there, I've been trying ti configure a new node, GroupMe, I've messed it up and now when Node-Red Crashes on launch, anyone any pointers on how to fix it?
Have tried node-red-start --safe sadly still fails.
Welcome to Node-RED
8 Mar 21:18:31 - [info] Node-RED version: v1.2.9
8 Mar 21:18:31 - [info] Node.js  version: v14.16.0
8 Mar 21:18:31 - [info] Linux 5.10.17-v7l+ arm LE
8 Mar 21:18:31 - [info] Loading palette nodes
8 Mar 21:18:35 - [info] Dashboard version 2.26.1 started at /ui
8 Mar 21:18:36 - [info] Settings file  : /home/pi/.node-red/settings.js
8 Mar 21:18:36 - [info] Context store  : 'default' [module=memory]
8 Mar 21:18:36 - [info] User directory : /home/pi/.node-red
8 Mar 21:18:36 - [warn] Projects disabled : editorTheme.projects.enabled=false
8 Mar 21:18:36 - [info] Flows file     : /home/pi/.node-red/flows_rpi44gb.json
8 Mar 21:18:36 - [info] Server now running at http://127.0.0.1:1880/
8 Mar 21:18:36 - [info] Starting flows
8 Mar 21:18:38 - [info] Started flows
8 Mar 21:18:38 - [info] [mqtt-broker:33bcdad9.ce80a6] Connected to broker: rpi44gb@mqtt://rpi44gb:1883
8 Mar 21:18:39 - [red] Uncaught Exception:
8 Mar 21:18:39 - Error [ERR_UNHANDLED_ERROR]: Unhandled error. ('Subscribing to user or group failed!')
    at IncomingStream.emit (events.js:304:17)
    at IncomingStream.subscribeResponse (/home/pi/node_modules/groupme/lib/IncomingStream.js:167:12)
    at /home/pi/node_modules/groupme/lib/IncomingStream.js:67:20
    at Array.forEach (<anonymous>)
    at each (/home/pi/node_modules/groupme/lib/IncomingStream.js:213:9)
    at WebSocketConnection.<anonymous> (/home/pi/node_modules/groupme/lib/IncomingStream.js:62:11)
    at WebSocketConnection.emit (events.js:315:20)
    at WebSocketConnection.processFrame (/home/pi/node_modules/websocket/lib/WebSocketConnection.js:554:26)
    at /home/pi/node_modules/websocket/lib/WebSocketConnection.js:323:40
    at processTicksAndRejections (internal/process/task_queues.js:75:11)
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
node-red-start doesn't take the --safe argument
You want to run node-red-stop to stop the service instance then run
node-red --safe to run things in safe mode
You also probably want to open an issue with the node-red-contrib-groupme to fix their uncaught exception
Thanks, I'm back in result.
