Node red crashes caused of illegal operation
Hey,
i get these message.
2 Jan 19:35:11 - [red] Uncaught Exception:
2 Jan 19:35:11 - [error] Error: EISDIR: illegal operation on a directory, open '/home/pi/.node-red/node_modules/node-persist/persist/persist'
nodered.service: Main process exited, code=exited, status=1/FAILURE
nodered.service: Failed with result 'exit-code'.
nodered.service: Consumed 1min 34.672s CPU time.
I tried to reinstall (upgrade) node-red but it doesnt work.
Can anybody help me and knows whats to do? This program works a long time before so i didnt know what the problem is.
Best regards!
It would seem a Node RED Node you're using, has an issue.
I am saying this, as the error is originating from the users directory (where your installed Nodes are located)
/home/pi/.node-red
Do you have any Node installed, that deals with persistent storage of values?
what Nodes do you have installed, it would help us to identify the offending Node.
you can try starting Node Red in safe mode (--safe)
i am storing some values in global/flow set/get. Thats some kind of persitent data. Maybe also some other nodes are using this kind of procedure.
With putty i have no access to this folder. Is this a normal behaviour?
Can you share the contents of /home/pi/.node-red/package.json
run in terminal/putty
cat /home/pi/.node-red/package.json
Or start Node RED in safe mode --safe
its likely hidden
--safe -> in safemode the error also happens
"name": "node-red-project",
"description": "initially created for you by Node-RED 1.3.5 ",
"version": "0.0.1",
"private": true,
"dependencies": {
"node-red-contrib-alarm": "~1.4.0",
"node-red-contrib-boolean-logic-ultimate": "~1.1.1",
"node-red-contrib-buffer-parser": "^3.2.2",
"node-red-contrib-button-events": "~2.0.0",
"node-red-contrib-counter": "~0.1.6",
"node-red-contrib-cpu": "0.0.4",
"node-red-contrib-device-stats": "~1.1.2",
"node-red-contrib-doorbird-ultimate": "github:ihrigb/node-red-contrib-doorbi rd-ultimate",
"node-red-contrib-feedparser-extended": "0.0.2",
"node-red-contrib-fritz": "~1.4.5",
"node-red-contrib-fronius-solar": "~1.0.4",
"node-red-contrib-get-feeds": "~1.0.0",
"node-red-contrib-google": "~0.2.0",
"node-red-contrib-google-calendar": "~0.1.5",
"node-red-contrib-google-oauth-calendar": "~0.1.1",
"node-red-contrib-ical-events": "~2.2.5",
"node-red-contrib-image-tools": "~2.0.4",
"node-red-contrib-influxdb": "~0.6.1",
"node-red-contrib-journal": "~0.1.6",
"node-red-contrib-knx-ultimate": "~2.2.29",
"node-red-contrib-msg-resend": "~1.0.0",
"node-red-contrib-os": "~0.2.1",
"node-red-contrib-play-audio": "^2.5.0",
"node-red-contrib-power-monitor": "~1.2.1",
"node-red-contrib-presence-faker": "~1.8.8",
"node-red-contrib-remote": "~1.5.1",
"node-red-contrib-repeat": "0.0.27",
"node-red-contrib-telegrambot": "~15.1.7",
"node-red-contrib-timeouttrigger": "0.0.4",
"node-red-contrib-timerswitch": "~1.4.0",
"node-red-contrib-trashschedule": "~1.3.3",
"node-red-contrib-ui-artless-gauge": "~0.3.12",
"node-red-contrib-ui-led": "~0.4.11",
"node-red-contrib-ui-time-scheduler": "~1.17.2",
"node-red-contrib-vnc": "~0.1.5",
"node-red-contrib-watt2kwh": "~0.1.2",
"node-red-contrib-wled": "0.0.4",
"node-red-contrib-wled2": "~2.4.4",
"node-red-dashboard": "~3.6.1",
"node-red-node-base64": "~0.3.0",
"node-red-node-feedparser": "~0.3.0",
"node-red-node-pi-gpio": "^2.0.6",
"node-red-node-ping": "^0.3.3",
"node-red-node-random": "^0.4.1",
"node-red-node-serialport": "^2.0.2",
"node-red-node-smooth": "^0.1.2",
"node-red-node-sqlite": "~1.1.0",
"node-red-node-ui-iframe": "~0.2.1",
"node-red-node-ui-table": "~0.4.3"
ok do this... (I was hoping for an obvious node :sweat_smile: )
cd /home/pi/.node-red
npm ls node-persist
I did it...but same.
:smiley: Hopefully i have not to fully reinstall the pi.
what does
npm ls node-persist
output?
it will list what nodes depend on it
node-red-project@0.0.1 /home/pi/.node-red
└─┬ node-red-contrib-journal@0.1.6
└── node-persist@0.0.2
i will reinstall the journal node....
So there you go...
node-red-contrib-journal has caused an issue.
you can get back to your Node RED, by removing it...
npm uninstall node-red-contrib-journal
then start Node RED again hopefully it will start
Since --safe does nothing in this instance.
for a permanent fix, you may need to raise an issue with the author
Thank you very much!
In the moment it looks very good.
