Node-red dashboard login sign in/out simultaneously in all devices
Hello, I'm facing a serious problem and I have no idea how to solve it.
I've added login to my dashboard using the flow below, It works fine "if you use only one device", but when I tried to sign in from another device and I found my self already signed in although I didn't, I hope I made it clear, I thought it's becaude of Google Chrome password synchronization, but even when I disabled it and used different browsers and devices I still have the same problem.
If it's not a same browser issue then Where is the problem ?
[{"id":"b89692f.2818a7","type":"ui_form","z":"12a1b8f7.edcdb7","name":"Dashboard Sign-In","label":"","group":"4dda6590.4ca25c","order":0,"width":0,"height":0,"options":[{"label":"username","value":"username","type":"text","required":true},{"label":"password","value":"password","type":"password","required":true}],"formValue":{"username":"","password":""},"payload":"","submit":"submit","cancel":"cancel","topic":"","x":106.5,"y":114,"wires":[["2a4de911.37c606","574a3fba.d3df2"]]},{"id":"466292da.f7b10c","type":"debug","z":"12a1b8f7.edcdb7","name":"Debug Account Log ","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","x":492.5,"y":76,"wires":[]},{"id":"561986e6.30d448","type":"comment","z":"12a1b8f7.edcdb7","name":"Sign-In Section","info":"","x":98.5,"y":51,"wires":[]},{"id":"2a4de911.37c606","type":"function","z":"12a1b8f7.edcdb7","name":"Account Log","func":"var accountlog = flow.get(\"accountlog\") || [] ; \n\naccountlog.push({ accessAt : new Date(), username : msg.payload.username})\n\nflow.set(\"accountlog\", accountlog);\n\nmsg.payload = accountlog;\nreturn msg;","outputs":1,"noerr":0,"x":297.5,"y":78,"wires":[["466292da.f7b10c"]]},{"id":"574a3fba.d3df2","type":"function","z":"12a1b8f7.edcdb7","name":"Account Verification","func":"var accounts = flow.get(\"accounts\") || [ { username : \"admin\", password : \"admin\"},{ username : \"guest\", password : \"guest\"}] ; \n\nvar username = msg.payload.username ;\nvar password = msg.payload.password ; \n\nvar newMsg = {}; newMsg.payload = 1;\n\naccounts.forEach(function ( account ){\n if ( account.username == username ) {\n newMsg.payload = 2;\n if ( account.password == password ) {\n newMsg.payload = 0;\n } \n }\n});\n\nreturn newMsg;","outputs":1,"noerr":0,"x":321.5,"y":148,"wires":[["ec29670c.74e618"]]},{"id":"ec29670c.74e618","type":"switch","z":"12a1b8f7.edcdb7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":489.5,"y":150,"wires":[["ef8bfe45.16e5c"],["c96b9e17.b040c"],["ee466dd6.fe058"]]},{"id":"ef8bfe45.16e5c","type":"function","z":"12a1b8f7.edcdb7","name":"= 0 : Success","func":"/* activate session timer */\nvar sessionTimer = flow.get(\"sessionTimer\") || 0; \nvar currTime = Date.now();\nflow.set(\"sessionTimer\", currTime);\n\n/* ui-control payload */\nvar msg = {};\nmsg.payload = { group: {\n show : [\"Dashboard_SensorData\", \"Dashboard_History\"],\n hide : [\"Dashboard_Signin\"]\n}\n};\n\nreturn msg;","outputs":1,"noerr":0,"x":649.5,"y":116,"wires":[["a4ccc52d.c8f328"]]},{"id":"c96b9e17.b040c","type":"function","z":"12a1b8f7.edcdb7","name":"= 1 : Unknown User","func":"msg.payload = \"Username Doesn't exist!!!\"\nreturn msg;","outputs":1,"noerr":0,"x":669.5,"y":155,"wires":[["e8e1dd24.9f3ed"]]},{"id":"ee466dd6.fe058","type":"function","z":"12a1b8f7.edcdb7","name":"= 2 : Wrong Password","func":"msg.payload = \"Invalid Password\";\nreturn msg;","outputs":1,"noerr":0,"x":672.5,"y":194,"wires":[["e8e1dd24.9f3ed"]]},{"id":"a4ccc52d.c8f328","type":"ui_ui_control","z":"12a1b8f7.edcdb7","name":"Go to Sensor/History Group","x":938.5,"y":115,"wires":[[]]},{"id":"e8e1dd24.9f3ed","type":"ui_toast","z":"12a1b8f7.edcdb7","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Authentication Failed","name":"Authentication Failure Dialog","x":939.5,"y":176,"wires":[[]]},{"id":"ac43b826.84ca38","type":"comment","z":"12a1b8f7.edcdb7","name":"Session Management - 15 secs for this demo","info":"","x":188,"y":234.00000667572021,"wires":[]},{"id":"215df146.1e462e","type":"inject","z":"12a1b8f7.edcdb7","name":"Timer","topic":"","payload":"","payloadType":"date","repeat":"3","crontab":"","once":false,"onceDelay":0.1,"x":88.49999618530273,"y":337.0000057220459,"wires":[["e7f6cd3b.3f36c","b4cf366.4befdc8"]]},{"id":"e7f6cd3b.3f36c","type":"function","z":"12a1b8f7.edcdb7","name":"Detect Session Timer","func":"var sessionTimer = flow.get(\"sessionTimer\") || 0; \nvar currTime = Date.now();\nvar SESSION_TIMEOUT = 15000; //15 secs\n\nif ( sessionTimer === 0 /* Inactive, No user signed in */ ) {\n msg.payload = 2;\n} else {\n if ( currTime - sessionTimer > SESSION_TIMEOUT ) {\n msg.payload = 0; \n } else {\n msg.payload = 1; \n }\n}\nreturn msg;","outputs":1,"noerr":0,"x":272.5,"y":298.99999809265137,"wires":[["9309e91a.e488f8"]]},{"id":"9309e91a.e488f8","type":"switch","z":"12a1b8f7.edcdb7","name":"","property":"payload","propertyType":"msg","rules":[{"t":"eq","v":"0","vt":"str"},{"t":"eq","v":"1","vt":"str"},{"t":"eq","v":"2","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":446.50000381469727,"y":298.99999809265137,"wires":[["ac9c6ee6.03b42"],["fda0446a.36ac28"],["55e8bd2b.b91784"]]},{"id":"ac9c6ee6.03b42","type":"function","z":"12a1b8f7.edcdb7","name":"Time-Out","func":"/* activate session timer */\nvar sessionTimer = flow.get(\"sessionTimer\") || 0; \nflow.set(\"sessionTimer\", 0);\n\nmsg.payload = \"Session Expired! Please singin again!\";\nreturn msg;","outputs":1,"noerr":0,"x":586.5,"y":259,"wires":[["ae766df1.29561","7c68531e.1ced1c"]]},{"id":"ae766df1.29561","type":"ui_toast","z":"12a1b8f7.edcdb7","position":"dialog","displayTime":"3","highlight":"","outputs":1,"ok":"OK","cancel":"","topic":"Session Timeout","name":"Time-Out Dialog","x":776.0000457763672,"y":236.00000953674316,"wires":[[]]},{"id":"fbb315d8.828908","type":"ui_ui_control","z":"12a1b8f7.edcdb7","name":"Go to Signin Group","x":984.0000190734863,"y":276.99999713897705,"wires":[[]]},{"id":"7c68531e.1ced1c","type":"function","z":"12a1b8f7.edcdb7","name":"Sign-In Redirection","func":"var msg = {};\nmsg.payload = { group: {\n hide : [\"Dashboard_SensorData\", \"Dashboard_History\"],\n show : [\"Dashboard_Signin\"]\n}\n};\nreturn msg;","outputs":1,"noerr":0,"x":786.5000457763672,"y":277.00000286102295,"wires":[["fbb315d8.828908"]]},{"id":"6e77a342.6b010c","type":"ui_toast","z":"12a1b8f7.edcdb7","position":"bottom right","displayTime":"1","highlight":"","outputs":0,"ok":"OK","cancel":"","topic":"Timer","name":"Display Remaining Time","x":602.9999923706055,"y":400.99999809265137,"wires":[]},{"id":"47481dd0.83e404","type":"comment","z":"12a1b8f7.edcdb7","name":"Sensor Data Collection","info":"","x":117.5,"y":452.0000057220459,"wires":[]},{"id":"561782d2.e287cc","type":"inject","z":"12a1b8f7.edcdb7","name":"Timer","topic":"","payload":"","payloadType":"date","repeat":"2","crontab":"","once":false,"onceDelay":0.1,"x":89.99999237060547,"y":529.0000133514404,"wires":[["f811a1d4.f7c0d"]]},{"id":"a536c3aa.58a11","type":"comment","z":"12a1b8f7.edcdb7","name":"MQTT ? CoAP?","info":"Expecting data from the actaul sensors.","x":265,"y":488.99999809265137,"wires":[]},{"id":"b4cf366.4befdc8","type":"function","z":"12a1b8f7.edcdb7","name":"Calculating Remaining Time (Debug)","func":"var sessionTimer = flow.get(\"sessionTimer\") || 0; \nvar currTime = Date.now();\nvar remainingSecs = Math.floor((15000 - (currTime - sessionTimer))/1000) + 1;\n \nif ( sessionTimer == 0 /* Inactive, No user signed in */ ) {\n return null;\n} else {\n \n if ( remainingSecs <= 7 ) msg.payload = \"Remaining : \" + remainingSecs + \" secs\"; \n else return null;\n}\nreturn msg;","outputs":1,"noerr":0,"x":320.5,"y":400.00001335144043,"wires":[["6e77a342.6b010c"]]},{"id":"5b1e9c02.b32ec4","type":"ui_text","z":"12a1b8f7.edcdb7","group":"1c73c43f.d461fc","order":0,"width":0,"height":0,"name":"Label Display","label":"","format":"{{msg.payload}}","layout":"row-spread","x":1003.0000076293945,"y":612.0001049041748,"wires":[]},{"id":"f811a1d4.f7c0d","type":"function","z":"12a1b8f7.edcdb7","name":"Decode MySensor Message","func":"\nvar mySensorsMessage = {}\nvar newPayload = {};\nvar timestamp = new Date();\n\nnewPayload.nodeId = 3;\nnewPayload.type = Math.floor( Math.random() * Math.floor(2)); // 0 or 1\nif ( newPayload.type === 0 /* temperature */ ) newPayload.value = Math.floor( Math.random() * Math.floor(30)) + 10; // 10 - 39\nelse newPayload.value = Math.floor( Math.random() * Math.floor(40)) + 40; // 40 - 79\n\nmsg.payload = newPayload; \n\nreturn msg;","outputs":1,"noerr":0,"x":286,"y":530.000020980835,"wires":[["d2b9a96.3eb6058","1a884f9f.2d46"]]},{"id":"d2b9a96.3eb6058","type":"function","z":"12a1b8f7.edcdb7","name":"Filter : temperature","func":"if (msg.payload.nodeId == 3 && msg.payload.type === 0) {\n var msg;\n msg.payload = msg.payload.value;\n msg.topic = \"Temperature\"\n return msg;\n} ","outputs":1,"noerr":0,"x":491.0000762939453,"y":474.0000066757202,"wires":[["fb435430.ade1a8","29fc8f0f.de3fc","93bea02d.2dae"]]},{"id":"fb435430.ade1a8","type":"ui_gauge","z":"12a1b8f7.edcdb7","name":"Gauge : Temperature","group":"1c73c43f.d461fc","order":0,"width":0,"height":0,"gtype":"gage","title":"Temperature DHT22","label":"MySensors v2","format":"{{value}}°C","min":0,"max":"50","colors":["#66ccff","#ff8000","#ca3838"],"seg1":"","seg2":"","x":754.0000228881836,"y":467.99998664855957,"wires":[]},{"id":"1a884f9f.2d46","type":"function","z":"12a1b8f7.edcdb7","name":"Filter : humidity","func":"if (msg.payload.nodeId == 3 && msg.payload.type === 1) {\n var msg;\n msg.payload = msg.payload.value;\n msg.topic = \"Humidity\"\n return msg;\n} ","outputs":1,"noerr":0,"x":478.00008392333984,"y":592.0000095367432,"wires":[["adec7ade.484ec8","29fc8f0f.de3fc","93bea02d.2dae"]]},{"id":"adec7ade.484ec8","type":"ui_gauge","z":"12a1b8f7.edcdb7","name":"Gauge : Humidity","group":"1c73c43f.d461fc","order":0,"width":"0","height":"0","gtype":"gage","title":"Humidity DHT22","label":"MySensors v2","format":"{{value}}%","min":0,"max":"100","colors":["#1a25ab","#e6e600","#ca3838"],"seg1":"","seg2":"","x":745.0000648498535,"y":509.00003242492676,"wires":[]},{"id":"29fc8f0f.de3fc","type":"function","z":"12a1b8f7.edcdb7","name":"Attention : temperature & humidity","func":"context.data = context.data || new Object();\n\nswitch (msg.topic) {\n case \"Temperature\":\n context.data.temperature = msg.payload;\n msg = null;\n break;\n case \"Humidity\":\n context.data.humidity = msg.payload;\n msg = null;\n break;\n default:\n msg = null;\n \tbreak;\n\n}\n\nif(context.data.temperature !== null && context.data.humidity !== null && context.data.temperature !== undefined && context.data.humidity !== undefined) {\n\tmsgOut = \"\"; //new Object();\n msgOut = \"Temerature : \" \n msgOut += context.data.temperature.toString(); \n msgOut+= \"°C - Humidity : \"; \n msgOut+= context.data.humidity.toString();\n msgOut+= \"%\";\n context.data=null;\n var msg = {};\n msg.payload = msgOut;\n\treturn msg;\n} \n//else return msg;","outputs":1,"noerr":0,"x":766.9999694824219,"y":612.0000381469727,"wires":[["5b1e9c02.b32ec4"]]},{"id":"93bea02d.2dae","type":"ui_chart","z":"12a1b8f7.edcdb7","name":"History : Temperature & Humidity","group":"7bb6904.00fcd7","order":0,"width":"6","height":"9","label":"Temperature & Humidity","chartType":"line","legend":"true","xformat":"%H:%M","interpolate":"linear","nodata":"No Data Yet","dot":false,"ymin":"0","ymax":"80","removeOlder":"12","removeOlderPoints":"","removeOlderUnit":"3600","cutout":"","useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":true,"x":795.0000495910645,"y":550.0000829696655,"wires":[[],[]]},{"id":"1c42befd.671181","type":"ui_ui_control","z":"12a1b8f7.edcdb7","name":"Stay in Sensor Group","x":972.9999694824219,"y":314.99999237060547,"wires":[[]]},{"id":"fda0446a.36ac28","type":"function","z":"12a1b8f7.edcdb7","name":"Sensor/History Goup","func":"var msg = {};\nmsg.payload = { group: {\n show : [\"Dashboard_SensorData\", \"Dashboard_History\"],\n hide : [\"Dashboard_Signin\"]\n}\n};\nreturn msg;","outputs":1,"noerr":0,"x":661,"y":319.9999942779541,"wires":[["1c42befd.671181"]]},{"id":"55e8bd2b.b91784","type":"function","z":"12a1b8f7.edcdb7","name":"Signin Goup","func":"var msg = {};\nmsg.payload = { group: {\n hide : [\"Dashboard_SensorData\", \"Dashboard_History\"],\n show : [\"Dashboard_Signin\"]\n}\n};\nreturn msg;","outputs":1,"noerr":0,"x":638.0000228881836,"y":360.0000219345093,"wires":[["e714728e.44ef8"]]},{"id":"e714728e.44ef8","type":"ui_ui_control","z":"12a1b8f7.edcdb7","name":"Go to Signin Group","x":978.0000762939453,"y":356.0000343322754,"wires":[[]]},{"id":"4dda6590.4ca25c","type":"ui_group","z":"","name":"Signin","tab":"7d44c889.f36c58","order":1,"disp":true,"width":"6","collapse":false},{"id":"1c73c43f.d461fc","type":"ui_group","z":"","name":"SensorData","tab":"7d44c889.f36c58","order":2,"disp":true,"width":"6","collapse":false},{"id":"7bb6904.00fcd7","type":"ui_group","z":"","name":"History","tab":"7d44c889.f36c58","order":3,"disp":true,"width":"6","collapse":false},{"id":"7d44c889.f36c58","type":"ui_tab","z":"","name":"Dashboard","icon":"dashboard","order":1}]
This is because Dashboard isn't multi-user aware. Whenever any connection is made whether it is another connection from yourself or someone else, Dashboard tries to talk to all of them.
You have not added anything yourself to remedy this. You can test this by putting two windows side-by-side and logging in on one of them, the other should update as though by magic!
You would need to do something like, for the login form, take note of the socket id that is send with msgs from Dashboard, apply a cookie against that if login is successful. On every interaction you would need to check that the cookie is still valid. Alternatively, investigate JWT and set an authorisation header. Though note that JWT on its own isn't really meant to be used for login security - despite how you will see it used in most tutorials - that's because it is subject to hijack attacks. This might not be an issue for something simple though.
Remember that, in order to only send an update to a single window/tab instance, you need to include the socket id in the output message. Also remember that the browser may sometimes end up with a new socket id so you may get some unexpected logouts.
I wasn't aware of that, Thank you !
