Password of dashboard in multiples intances
Good morning to everybody;
I have two instances running on my device (localhost:1881 and localhost:1882), does anybody knows how can I put diferents passwords on dashboard on the both instances?
Normaly when I'm using just one instance (localhost:1880) I modify this on settings.js:
// To password protect the node-defined HTTP endpoints (httpNodeRoot), or
// the static content (httpStatic), the following properties can be used.
// The pass field is a bcrypt hash of the password.
// See http://nodered.org/docs/security.html#generating-the-password-hash
httpNodeAuth: {user:"xxxx",pass:"xxxx"
httpStaticAuth: {user:"xxx",pass:"xxxxx`
But now I don't know how I can put password on dashboard when I'm using multiples instances, Can anybody help me?
Thank you all;
How do you launch the separate instances?
Do you specify a userDir or a settings file? or simply specify a different port number?
Please show us
Hi Steve,
I launch this way:
node-red -p 1881 -u c:/nr1881
node-red -p 1882 -u c:/nr1882
Then it should simply be a case of editing the settings.js file in BOTH of those folders.
if not, then specify the settings file with the -s switch
https://nodered.org/docs/getting-started/local#command-line-usage
It worked, thank you Steve!!
