Node-red Dashboard ui-template not able to send message/payload
iI searched and tryed many options to get a payload out of this ui-template-node.
Wether version 1 or Version 2 is sending an outpout to a Debug-node.
have no more idea what´s wrong?
Using v3.1.3 and old Dashboard.
Version 1
 <span class="toggle">
    <input type="checkbox"id="checkbox1" onchange="toggleState(this)">
    <label data-off="OFF" data-on="ON"></label>
</span>
<script>
  function toggleState(checkbox) {
    var msg = { payload: "" };
    if (checkbox.checked)
        msg.payload = "TRUE";
else
        msg.payload = "FALSE";
        node.send(msg);
</script>
Version 2
        <input type="checkbox" onclick="onClickHandler(msg)" id="box3" />
        <label data-off="AUS" data-on="AN"></label>
    </span>
<script>
function onClickHandler(msg)
var offValue = event.target.getAttribute('data-off');
var onValue = event.target.getAttribute('data-on');
if (offValue === 'AUS')
else if (onValue === 'AN')
msg.payload = FALSE;
</script>
Thank you for your Idea:
steelbuddy
Try the angularjs ng-model and ng-change
e.g.
    <input ng-model="mycheckbox1" type="checkbox"id="checkbox1" ng-change="toggleState(mycheckbox1)">
</span>
<script>
this.scope.toggleState = function(checked) {
    if (checked){
        checked = "TRUE";
    }else{
        checked = "FALSE";
    this.send({payload:checked})
</script>
Thx, it works :+1:
