I am working on a project that uses an Arduino connected to LabVIEW, and Node-RED. It is a smart home system, with multiple user-defined inputs and outputs. The Node-RED dashboard is able to receive all of the inputs that are sent via LabVIEW, however, when I try to send a signal back to LabVIEW, the program stops and gives an error saying "JSON Message expected". I have tried adding a JSON block before the function with no success. I have tested it with only one input node (instead of connecting multiple to the same function block), and it outputs it just fine. The issue lies when I try to have multiple things output at once. Any help would be appriciated.
Attach a debug node to the output that feeds into the labView node so you can see exactly what you are passing in.
