Node red flows seem to be slowing down
Hi Colin,
It appears to be but I am confused by knowing that the introduction of the the the Rbe node after the function node "comparadore " seems to allow it to function as expected....
Almost like the function is globally blocking the flow to the rest of the outputs? And the Rbe node somehow corrects this blocking?
Would you mind looking at that branch of the flow....to see if I am missing something stupid? I will send this branch in a second. As I am on my phone now and will do this on my main computer.
Here is the branch of node red flow I mentioned in the last post
[{"id":"c6a641c4.cd1b7","type":"tab","label":"Flow 1","disabled":false,"info":""},{"id":"8e9463e2.a2cf7","type":"function","z":"c6a641c4.cd1b7","name":"spa too hot","func":"if(msg.payload >= 104){\n msg.payload = "off";\n\nreturn msg;\n}","outputs":1,"noerr":0,"x":330,"y":240,"wires":[["61425c53.7f7234","fee13e44.2669"]]},{"id":"61425c53.7f7234","type":"mqtt out","z":"c6a641c4.cd1b7","name":"heat off","topic":"esp8266spa/heat","qos":"","retain":"","broker":"562eb1ef.1c2f1","x":560,"y":240,"wires":},{"id":"ac0a3888.0cd748","type":"delay","z":"c6a641c4.cd1b7","name":"email limit","pauseType":"timed","timeout":"5","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"minute","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":true,"x":440,"y":420,"wires":[["661c7957.42d998"]]},{"id":"661c7957.42d998","type":"e-mail","z":"c6a641c4.cd1b7","server":"smtp.gmail.com","port":"465","secure":true,"tls":true,"name":"troypearce@gmail.com","dname":"email to noderedpearc","x":580,"y":360,"wires":},{"id":"aa6450c1.3a83b","type":"function","z":"c6a641c4.cd1b7","name":"spa just right hot","func":"if(msg.payload >= 103){\n msg.payload = "water temp in hot tub is 103";\n\nreturn msg;\n}","outputs":1,"noerr":0,"x":340,"y":340,"wires":[["ac0a3888.0cd748","76e711df.192dc"]]},{"id":"999f6aac.34aae8","type":"mqtt in","z":"c6a641c4.cd1b7","name":"","topic":"esp8266spa/solartemp","qos":"2","datatype":"auto","broker":"562eb1ef.1c2f1","x":180,"y":460,"wires":[["9975b551.e48458","58c1849d.488bdc","ce9333fb.018d6","25f2a82f.8a5bd8","3a0218da.e2d258"]]},{"id":"ce9333fb.018d6","type":"ui_gauge","z":"c6a641c4.cd1b7","name":"solar panel water Temparature","group":"dc08521.6b0dab","order":0,"width":0,"height":0,"gtype":"gage","title":"solar temperature","label":" ° F","format":"{{value}}","min":"50","max":"130","colors":["#00b500","#e6e600","#ca3838"],"seg1":"80","seg2":"102","x":450,"y":540,"wires":},{"id":"3a0218da.e2d258","type":"ui_chart","z":"c6a641c4.cd1b7","name":"Solar Temp","group":"70c44ff3.93741","order":2,"width":0,"height":0,"label":"solar panel temp","chartType":"line","legend":"false","xformat":"HH:mm:ss","interpolate":"linear","nodata":"","dot":false,"ymin":"60","ymax":"108","removeOlder":"2","removeOlderPoints":"","removeOlderUnit":"3600","cutout":0,"useOneColor":false,"colors":["#1f77b4","#aec7e8","#ff7f0e","#2ca02c","#98df8a","#d62728","#ff9896","#9467bd","#c5b0d5"],"useOldStyle":false,"outputs":1,"x":610,"y":600,"wires":[]},{"id":"2c9331b0.d82e6e","type":"function","z":"c6a641c4.cd1b7","name":"esp8266spa/spatemp","func":"msg.payload=Number(msg.payload);\nmsg.topic = "esp8266spa/spatemp";\nreturn msg;","outputs":1,"noerr":0,"x":520,"y":180,"wires":[["ffcb7d17.34188"]]},{"id":"58c1849d.488bdc","type":"function","z":"c6a641c4.cd1b7","name":"esp8266spa/solartemp","func":"msg.payload=Number(msg.payload);\nmsg.topic = "esp8266spa/solartemp";\nreturn msg;","outputs":1,"noerr":0,"x":420,"y":500,"wires":[["ffcb7d17.34188"]]},{"id":"ffcb7d17.34188","type":"function","z":"c6a641c4.cd1b7","name":"Comparatore","func":"// this is passed a payload which is an object with\n// properties outside_temp and inside_temp\n\ncontext.set(msg.topic,msg.payload);\n\nvar solartemp = context.get("esp8266spa/solartemp") || 0;\nvar spatemp = context.get("esp8266spa/spatemp") || 0;\n\nnode.warn("Solar " + solartemp);\nnode.warn("Spa " + spatemp);\n\n\n\nif (solartemp > (spatemp+10)) {\n \n msg.payload = "on";\n} else\n{\n \n msg.payload = "off";\n}\nreturn msg;","outputs":1,"noerr":0,"x":850,"y":420,"wires":[["de83160b.4358a8","a3cc4a99.1967a8"]]},{"id":"10b85d70.553653","type":"mqtt out","z":"c6a641c4.cd1b7","name":"turn on/off sol pump","topic":"esp8266spa/solon","qos":"","retain":"","broker":"562eb1ef.1c2f1","x":1250,"y":540,"wires":},{"id":"cc4ba846.a5b358","type":"link in","z":"c6a641c4.cd1b7","name":"","links":["b5060a91.7fd078"],"x":140,"y":140,"wires":[["8e9463e2.a2cf7","2c9331b0.d82e6e","472c4179.73d96","aa6450c1.3a83b"]]},{"id":"fee13e44.2669","type":"debug","z":"c6a641c4.cd1b7","name":"55","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":550,"y":300,"wires":},{"id":"25f2a82f.8a5bd8","type":"debug","z":"c6a641c4.cd1b7","name":"56","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":310,"y":640,"wires":},{"id":"de83160b.4358a8","type":"debug","z":"c6a641c4.cd1b7","name":"57","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":1210,"y":420,"wires":},{"id":"472c4179.73d96","type":"debug","z":"c6a641c4.cd1b7","name":"55db","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":350,"y":100,"wires":},{"id":"76e711df.192dc","type":"debug","z":"c6a641c4.cd1b7","name":"55b","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":370,"y":300,"wires":},{"id":"9975b551.e48458","type":"debug","z":"c6a641c4.cd1b7","name":"56z","active":false,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":390,"y":460,"wires":},{"id":"a3cc4a99.1967a8","type":"rbe","z":"c6a641c4.cd1b7","name":"","func":"rbe","gap":"","start":"","inout":"out","property":"payload","x":990,"y":620,"wires":[["10b85d70.553653"]]},{"id":"562eb1ef.1c2f1","type":"mqtt-broker","z":"","name":"","broker":"192.168.250.8","port":"1883","clientid":"","usetls":false,"compatmode":false,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closeQos":"0","closePayload":"","willTopic":"","willQos":"0","willPayload":""},{"id":"dc08521.6b0dab","type":"ui_group","z":"","name":"spa summerize","tab":"586d995e.971c58","order":1,"disp":true,"width":"6","collapse":false},{"id":"70c44ff3.93741","type":"ui_group","z":"","name":"sensors","tab":"586d995e.971c58","order":2,"disp":true,"width":"6","collapse":false},{"id":"586d995e.971c58","type":"ui_tab","z":"","name":"esp8266spa","icon":"dashboard","order":4,"disabled":false,"hidden":false}]
Your flow can not be imported. Please read this thread and edit your post with a fixed import.
Perhaps the device does not like being told what to do twice a second. (Would you like it :slight_smile: )
Putting the RBE node in has stopped that.
