Hello everybody.
I am quite new to node-red so I hope you bear with me. On January I started my first Raspberry Pi projects. Sooner or later I found out some visualization would be quite nice. So I run a search and found Node-red which was exactly what I was looking for. I started some small flows and all was quite promising.
Now, I am running node-red on my Raspberry Pi3 to visualize temperature sensors of my solar boilers. There are 4 temperatur sensors (ds18b20) for each boiler (2 boilers). Furthermore I wanted to display date and time. I created all flows and deployed but as I wanted to display on my dashboard nothing happened. My Raspberry PI was dead no reaction on any mouse click what so ever. CPU on my Raspberry was about 30% but I think that should at least permit to start my console.
Some details:
Node-red version V8.11.3
NPM Version 5.6.0
Since I am a new user I am not allowed to upload my flows. That would make it easier to explain. I am still convinced that Node-red is a super tool but at the moment I have no idea what to do.
All help is much appreciated.
leafboy
If you go to the raspberry pi page in the documents on the node-red website there’s a script you can run to get you onto a standard platform
On the same page there’s details of how to access the log files, if it stops again then look at the logs
Colin
22 June 2018 20:53
3
How do you know what the CPU was if it was not responding?
Dear all.
Thanks a lot for your replay.
@colin : Last time before it freezes I checked but this might be due to other processes. I can’t relate this to node-red.
@ukmoose : I run this script serveral times before. There are a few warnings and this error:
node-pre-gyp ERR! Tried to download(404): https://github.com/kelektiv/node.bcrypt.js/releases/download/v1.0.3/bcrypt_lib-v1.0.3-node-v57-linux-arm.tar.gz
node-pre-gyp ERR! Pre-built binaries not found for bcrypt@1.0.3 and node@8.11.3 (node-v57 ABI) (falling back to source compile with node-gyp)
I am not sure if this is what the problem causes.
Any further hints sorry, as I wrote at the beginning I am a total newbee and some kind of lost.
Many thanks in advance for your assistance.
leafboy
Colin
24 June 2018 13:04
5
Those messages are just for information, they do not indicate a problem.
Is the pi completely unresponsive? Any mouse movement? If you have a keyboard plugged in does the caps lock switch the caps lock led on/off?
When it hangs how do you get the pi going again? Do you have to power cycle? If so then note the time, then wait about a minute and then power cycle. Then have a look in the system log file (/var/log/syslog). Paste the last 20 or 30 lines here from before the reboot log. Looking at the time in the log is the end of the log when it hung or when you power cycled (in other words is there anything written to the log after it hung?
Actually I connect remote to my Pi via my linux laptop. The connection gets lost and I have to restart all over again. I noticed as soon I start Node-red a lot of messages appear in the console. I created a date and time flow which updates every second. Maybe this causes the crash. But how can I delete or alter it without starting Node-red?
thanks
leafboy
I renamed the start file in directory .node-red to startold and ran Node-red again it worked. No crash. It seems as soon as a lot of payloads are created my Pi crashes. Could this be the case and how can I solve that problem?
Thank you very much.
leafboy
read the thread above and paste the logs after nodered has crashed here
sorry - but where can I find the thread?
This thread
post 2 asks for you to look at the logs
post 5 asks you to paste from the logs
Colin
24 June 2018 14:24
11
Paste those messages here.
Sorry - I got it.
I run the scripts on the raspberry pi documentation but this did not solve the problem. Unfortunately I cant paste the messages because when mi Pi freezes not even a screen shot is possible but these are normal payloads from the nodes, as they seem to me. They appear on my linux laptop as well. Do think this has to do regarding lack of memory?
Thanks for your patience
leafboy
the logs should be there after you have restarted your pi- have you checked?
Its far easier to look at the logs and see rather than guessing as to likely causes
Looking into the log files showed there has been no chance since updating:
make: Verzeichnis »/home/pi/.node-red/node_modules/serialport/build« wird verlassen
node-red-contrib-dht-sensor@1.0.1 /home/pi/.node-red/node_modules/node-red-contrib-dht-sensor
node-dht-sensor@0.0.34 /home/pi/.node-red/node_modules/node-dht-sensor
nan@2.8.0 /home/pi/.node-red/node_modules/node-dht-sensor/node_modules/nan
node-red-contrib-ibm-watson-iot@0.2.8 /home/pi/.node-red/node_modules/node-red-contrib-ibm-watson-iot
ibmiotf@0.2.41 /home/pi/.node-red/node_modules/ibmiotf
axios@0.5.4 /home/pi/.node-red/node_modules/axios
es6-promise@2.3.0 /home/pi/.node-red/node_modules/es6-promise
bluebird@2.11.0 /home/pi/.node-red/node_modules/bluebird
btoa@1.2.1 /home/pi/.node-red/node_modules/btoa
concat-stream@1.6.2 /home/pi/.node-red/node_modules/concat-stream
buffer-from@1.1.0 /home/pi/.node-red/node_modules/buffer-from
inherits@2.0.3 /home/pi/.node-red/node_modules/inherits
readable-stream@2.3.6 /home/pi/.node-red/node_modules/readable-stream
core-util-is@1.0.2 /home/pi/.node-red/node_modules/core-util-is
isarray@1.0.0 /home/pi/.node-red/node_modules/isarray
process-nextick-args@2.0.0 /home/pi/.node-red/node_modules/process-nextick-args
safe-buffer@5.1.2 /home/pi/.node-red/node_modules/safe-buffer
string_decoder@1.1.1 /home/pi/.node-red/node_modules/string_decoder
util-deprecate@1.0.2 /home/pi/.node-red/node_modules/util-deprecate
typedarray@0.0.6 /home/pi/.node-red/node_modules/typedarray
events@1.1.1 /home/pi/.node-red/node_modules/events
form-data@2.3.2 /home/pi/.node-red/node_modules/form-data
asynckit@0.4.0 /home/pi/.node-red/node_modules/asynckit
combined-stream@1.0.6 /home/pi/.node-red/node_modules/combined-stream
delayed-stream@1.0.0 /home/pi/.node-red/node_modules/delayed-stream
mime-types@2.1.18 /home/pi/.node-red/node_modules/mime-types
mime-db@1.33.0 /home/pi/.node-red/node_modules/mime-db
format@0.2.2 /home/pi/.node-red/node_modules/format
loglevel@1.6.1 /home/pi/.node-red/node_modules/loglevel
mqtt@2.18.1 /home/pi/.node-red/node_modules/mqtt
commist@1.0.0 /home/pi/.node-red/node_modules/commist
leven@1.0.2 /home/pi/.node-red/node_modules/leven
minimist@1.2.0 /home/pi/.node-red/node_modules/minimist
end-of-stream@1.4.1 /home/pi/.node-red/node_modules/end-of-stream
once@1.4.0 /home/pi/.node-red/node_modules/once
wrappy@1.0.2 /home/pi/.node-red/node_modules/wrappy
help-me@1.1.0 /home/pi/.node-red/node_modules/help-me
callback-stream@1.1.0 /home/pi/.node-red/node_modules/callback-stream
glob-stream@6.1.0 /home/pi/.node-red/node_modules/glob-stream
extend@3.0.1 /home/pi/.node-red/node_modules/extend
glob@7.1.2 /home/pi/.node-red/node_modules/glob
fs.realpath@1.0.0 /home/pi/.node-red/node_modules/fs.realpath
inflight@1.0.6 /home/pi/.node-red/node_modules/inflight
minimatch@3.0.4 /home/pi/.node-red/node_modules/minimatch
brace-expansion@1.1.11 /home/pi/.node-red/node_modules/brace-expansion
balanced-match@1.0.0 /home/pi/.node-red/node_modules/balanced-match
concat-map@0.0.1 /home/pi/.node-red/node_modules/concat-map
path-is-absolute@1.0.1 /home/pi/.node-red/node_modules/path-is-absolute
glob-parent@3.1.0 /home/pi/.node-red/node_modules/glob-parent
is-glob@3.1.0 /home/pi/.node-red/node_modules/is-glob
is-extglob@2.1.1 /home/pi/.node-red/node_modules/is-extglob
path-dirname@1.0.2 /home/pi/.node-red/node_modules/path-dirname
is-negated-glob@1.0.0 /home/pi/.node-red/node_modules/is-negated-glob
ordered-read-streams@1.0.1 /home/pi/.node-red/node_modules/ordered-read-streams
pumpify@1.5.1 /home/pi/.node-red/node_modules/pumpify
duplexify@3.6.0 /home/pi/.node-red/node_modules/duplexify
stream-shift@1.0.0 /home/pi/.node-red/node_modules/stream-shift
pump@2.0.1 /home/pi/.node-red/node_modules/pumpify/node_modules/pump
remove-trailing-separator@1.1.0 /home/pi/.node-red/node_modules/remove-trailing-separator
to-absolute-glob@2.0.2 /home/pi/.node-red/node_modules/to-absolute-glob
is-absolute@1.0.0 /home/pi/.node-red/node_modules/is-absolute
is-relative@1.0.0 /home/pi/.node-red/node_modules/is-relative
is-unc-path@1.0.0 /home/pi/.node-red/node_modules/is-unc-path
unc-path-regex@0.1.2 /home/pi/.node-red/node_modules/unc-path-regex
is-windows@1.0.2 /home/pi/.node-red/node_modules/is-windows
unique-stream@2.2.1 /home/pi/.node-red/node_modules/unique-stream
json-stable-stringify@1.0.1 /home/pi/.node-red/node_modules/json-stable-stringify
jsonify@0.0.0 /home/pi/.node-red/node_modules/jsonify
through2-filter@2.0.0 /home/pi/.node-red/node_modules/through2-filter
through2@2.0.3 /home/pi/.node-red/node_modules/through2
xtend@4.0.1 /home/pi/.node-red/node_modules/xtend
mqtt-packet@5.6.0 /home/pi/.node-red/node_modules/mqtt-packet
bl@1.2.2 /home/pi/.node-red/node_modules/bl
pump@3.0.0 /home/pi/.node-red/node_modules/pump
reinterval@1.1.0 /home/pi/.node-red/node_modules/reinterval
split2@2.2.0 /home/pi/.node-red/node_modules/split2
websocket-stream@5.1.2 /home/pi/.node-red/node_modules/websocket-stream
ws@3.3.3 /home/pi/.node-red/node_modules/ws
async-limiter@1.0.0 /home/pi/.node-red/node_modules/async-limiter
ultron@1.1.1 /home/pi/.node-red/node_modules/ultron
node-red-contrib-moment@2.0.7 /home/pi/.node-red/node_modules/node-red-contrib-moment
moment@2.22.2 /home/pi/.node-red/node_modules/moment
moment-parseformat@2.2.1 /home/pi/.node-red/node_modules/moment-parseformat
moment-timezone@0.5.20 /home/pi/.node-red/node_modules/moment-timezone
os-locale@2.1.0 /home/pi/.node-red/node_modules/os-locale
execa@0.7.0 /home/pi/.node-red/node_modules/execa
cross-spawn@5.1.0 /home/pi/.node-red/node_modules/cross-spawn
lru-cache@4.1.3 /home/pi/.node-red/node_modules/lru-cache
pseudomap@1.0.2 /home/pi/.node-red/node_modules/pseudomap
yallist@2.1.2 /home/pi/.node-red/node_modules/yallist
shebang-command@1.2.0 /home/pi/.node-red/node_modules/shebang-command
shebang-regex@1.0.0 /home/pi/.node-red/node_modules/shebang-regex
which@1.3.1 /home/pi/.node-red/node_modules/which
isexe@2.0.0 /home/pi/.node-red/node_modules/isexe
get-stream@3.0.0 /home/pi/.node-red/node_modules/get-stream
is-stream@1.1.0 /home/pi/.node-red/node_modules/is-stream
npm-run-path@2.0.2 /home/pi/.node-red/node_modules/npm-run-path
path-key@2.0.1 /home/pi/.node-red/node_modules/path-key
p-finally@1.0.0 /home/pi/.node-red/node_modules/p-finally
signal-exit@3.0.2 /home/pi/.node-red/node_modules/signal-exit
strip-eof@1.0.0 /home/pi/.node-red/node_modules/strip-eof
lcid@1.0.0 /home/pi/.node-red/node_modules/lcid
invert-kv@1.0.0 /home/pi/.node-red/node_modules/invert-kv
mem@1.1.0 /home/pi/.node-red/node_modules/mem
mimic-fn@1.2.0 /home/pi/.node-red/node_modules/mimic-fn
node-red-contrib-play-audio@2.3.2 /home/pi/.node-red/node_modules/node-red-contrib-play-audio
node-red-contrib-sensor-ds18b20@0.1.0 /home/pi/.node-red/node_modules/node-red-contrib-sensor-ds18b20
ds18b20@0.1.0 /home/pi/.node-red/node_modules/ds18b20
node-red-dashboard@2.9.4 /home/pi/.node-red/node_modules/node-red-dashboard
serve-static@1.13.2 /home/pi/.node-red/node_modules/serve-static
encodeurl@1.0.2 /home/pi/.node-red/node_modules/encodeurl
escape-html@1.0.3 /home/pi/.node-red/node_modules/escape-html
parseurl@1.3.2 /home/pi/.node-red/node_modules/parseurl
send@0.16.2 /home/pi/.node-red/node_modules/send
debug@2.6.9 /home/pi/.node-red/node_modules/send/node_modules/debug
ms@2.0.0 /home/pi/.node-red/node_modules/ms
depd@1.1.2 /home/pi/.node-red/node_modules/depd
destroy@1.0.4 /home/pi/.node-red/node_modules/destroy
etag@1.8.1 /home/pi/.node-red/node_modules/etag
fresh@0.5.2 /home/pi/.node-red/node_modules/fresh
http-errors@1.6.3 /home/pi/.node-red/node_modules/http-errors
setprototypeof@1.1.0 /home/pi/.node-red/node_modules/setprototypeof
statuses@1.4.0 /home/pi/.node-red/node_modules/statuses
mime@1.4.1 /home/pi/.node-red/node_modules/mime
on-finished@2.3.0 /home/pi/.node-red/node_modules/on-finished
ee-first@1.1.1 /home/pi/.node-red/node_modules/ee-first
range-parser@1.2.0 /home/pi/.node-red/node_modules/range-parser
socket.io @1.7.4 /home/pi/.node-red/node_modules/socket.io
debug@2.3.3 /home/pi/.node-red/node_modules/socket.io/node_modules/debug
ms@0.7.2 /home/pi/.node-red/node_modules/socket.io/node_modules/ms
engine.io @1.8.5 /home/pi/.node-red/node_modules/engine.io
accepts@1.3.3 /home/pi/.node-red/node_modules/accepts
negotiator@0.6.1 /home/pi/.node-red/node_modules/negotiator
base64id@1.0.0 /home/pi/.node-red/node_modules/base64id
cookie@0.3.1 /home/pi/.node-red/node_modules/cookie
debug@2.3.3 /home/pi/.node-red/node_modules/engine.io/node_modules/debug
ms@0.7.2 /home/pi/.node-red/node_modules/engine.io/node_modules/ms
engine.io-parser@1.3.2 /home/pi/.node-red/node_modules/engine.io-parser
after@0.8.2 /home/pi/.node-red/node_modules/after
arraybuffer.slice@0.0.6 /home/pi/.node-red/node_modules/arraybuffer.slice
base64-arraybuffer@0.1.5 /home/pi/.node-red/node_modules/base64-arraybuffer
blob@0.0.4 /home/pi/.node-red/node_modules/blob
has-binary@0.1.7 /home/pi/.node-red/node_modules/has-binary
isarray@0.0.1 /home/pi/.node-red/node_modules/has-binary/node_modules/isarray
wtf-8@1.0.0 /home/pi/.node-red/node_modules/wtf-8
ws@1.1.5 /home/pi/.node-red/node_modules/engine.io/node_modules/ws
options@0.0.6 /home/pi/.node-red/node_modules/options
ultron@1.0.2 /home/pi/.node-red/node_modules/engine.io/node_modules/ultron
object-assign@4.1.0 /home/pi/.node-red/node_modules/socket.io/node_modules/object-assign
socket.io-adapter@0.5.0 /home/pi/.node-red/node_modules/socket.io-adapter
debug@2.3.3 /home/pi/.node-red/node_modules/socket.io-adapter/node_modules/debug
ms@0.7.2 /home/pi/.node-red/node_modules/socket.io-adapter/node_modules/ms
socket.io-parser@2.3.1 /home/pi/.node-red/node_modules/socket.io-parser
component-emitter@1.1.2 /home/pi/.node-red/node_modules/socket.io-parser/node_modules/component-emitter
debug@2.2.0 /home/pi/.node-red/node_modules/socket.io-parser/node_modules/debug
ms@0.7.1 /home/pi/.node-red/node_modules/socket.io-parser/node_modules/ms
isarray@0.0.1 /home/pi/.node-red/node_modules/socket.io-parser/node_modules/isarray
json3@3.3.2 /home/pi/.node-red/node_modules/json3
socket.io-client@1.7.4 /home/pi/.node-red/node_modules/socket.io-client
backo2@1.0.2 /home/pi/.node-red/node_modules/backo2
component-bind@1.0.0 /home/pi/.node-red/node_modules/component-bind
component-emitter@1.2.1 /home/pi/.node-red/node_modules/component-emitter
debug@2.3.3 /home/pi/.node-red/node_modules/socket.io-client/node_modules/debug
ms@0.7.2 /home/pi/.node-red/node_modules/socket.io-client/node_modules/ms
engine.io-client@1.8.5 /home/pi/.node-red/node_modules/engine.io-client
component-inherit@0.0.3 /home/pi/.node-red/node_modules/component-inherit
debug@2.3.3 /home/pi/.node-red/node_modules/engine.io-client/node_modules/debug
ms@0.7.2 /home/pi/.node-red/node_modules/engine.io-client/node_modules/ms
has-cors@1.1.0 /home/pi/.node-red/node_modules/has-cors
indexof@0.0.1 /home/pi/.node-red/node_modules/indexof
parsejson@0.0.3 /home/pi/.node-red/node_modules/parsejson
better-assert@1.0.2 /home/pi/.node-red/node_modules/better-assert
callsite@1.0.0 /home/pi/.node-red/node_modules/callsite
parseqs@0.0.5 /home/pi/.node-red/node_modules/parseqs
parseuri@0.0.5 /home/pi/.node-red/node_modules/parseuri
ws@1.1.5 /home/pi/.node-red/node_modules/engine.io-client/node_modules/ws
ultron@1.0.2 /home/pi/.node-red/node_modules/engine.io-client/node_modules/ultron
xmlhttprequest-ssl@1.5.3 /home/pi/.node-red/node_modules/xmlhttprequest-ssl
yeast@0.1.2 /home/pi/.node-red/node_modules/yeast
object-component@0.0.3 /home/pi/.node-red/node_modules/object-component
to-array@0.1.4 /home/pi/.node-red/node_modules/to-array
node-red-node-ledborg@0.0.19 /home/pi/.node-red/node_modules/node-red-node-ledborg
node-red-node-pi-sense-hat@0.0.16 /home/pi/.node-red/node_modules/node-red-node-pi-sense-hat
node-red-node-ping@0.0.15 /home/pi/.node-red/node_modules/node-red-node-ping
node-red-node-random@0.1.0 /home/pi/.node-red/node_modules/node-red-node-random
node-red-node-serialport@0.6.7 /home/pi/.node-red/node_modules/node-red-node-serialport
serialport@6.2.0 /home/pi/.node-red/node_modules/serialport
bindings@1.3.0 /home/pi/.node-red/node_modules/bindings
commander@2.15.1 /home/pi/.node-red/node_modules/commander
debug@3.1.0 /home/pi/.node-red/node_modules/debug
nan@2.10.0 /home/pi/.node-red/node_modules/nan
parser-byte-length@1.0.2 /home/pi/.node-red/node_modules/parser-byte-length
parser-cctalk@1.0.2 /home/pi/.node-red/node_modules/parser-cctalk
parser-delimiter@1.0.2 /home/pi/.node-red/node_modules/parser-delimiter
parser-readline@1.0.2 /home/pi/.node-red/node_modules/parser-readline
parser-ready@1.0.2 /home/pi/.node-red/node_modules/parser-ready
parser-regex@1.0.2 /home/pi/.node-red/node_modules/parser-regex
prebuild-install@2.5.3 /home/pi/.node-red/node_modules/prebuild-install
detect-libc@1.0.3 /home/pi/.node-red/node_modules/detect-libc
expand-template@1.1.1 /home/pi/.node-red/node_modules/expand-template
github-from-package@0.0.0 /home/pi/.node-red/node_modules/github-from-package
mkdirp@0.5.1 /home/pi/.node-red/node_modules/mkdirp
minimist@0.0.8 /home/pi/.node-red/node_modules/mkdirp/node_modules/minimist
node-abi@2.4.1 /home/pi/.node-red/node_modules/node-abi
semver@5.5.0 /home/pi/.node-red/node_modules/semver
noop-logger@0.1.1 /home/pi/.node-red/node_modules/noop-logger
npmlog@4.1.2 /home/pi/.node-red/node_modules/npmlog
are-we-there-yet@1.1.5 /home/pi/.node-red/node_modules/are-we-there-yet
delegates@1.0.0 /home/pi/.node-red/node_modules/delegates
console-control-strings@1.1.0 /home/pi/.node-red/node_modules/console-control-strings
gauge@2.7.4 /home/pi/.node-red/node_modules/gauge
aproba@1.2.0 /home/pi/.node-red/node_modules/aproba
has-unicode@2.0.1 /home/pi/.node-red/node_modules/has-unicode
object-assign@4.1.1 /home/pi/.node-red/node_modules/object-assign
string-width@1.0.2 /home/pi/.node-red/node_modules/string-width
code-point-at@1.1.0 /home/pi/.node-red/node_modules/code-point-at
is-fullwidth-code-point@1.0.0 /home/pi/.node-red/node_modules/is-fullwidth-code-point
number-is-nan@1.0.1 /home/pi/.node-red/node_modules/number-is-nan
strip-ansi@3.0.1 /home/pi/.node-red/node_modules/strip-ansi
ansi-regex@2.1.1 /home/pi/.node-red/node_modules/ansi-regex
wide-align@1.1.3 /home/pi/.node-red/node_modules/wide-align
set-blocking@2.0.0 /home/pi/.node-red/node_modules/set-blocking
os-homedir@1.0.2 /home/pi/.node-red/node_modules/os-homedir
pump@2.0.1 /home/pi/.node-red/node_modules/prebuild-install/node_modules/pump
rc@1.2.8 /home/pi/.node-red/node_modules/rc
deep-extend@0.6.0 /home/pi/.node-red/node_modules/deep-extend
ini@1.3.5 /home/pi/.node-red/node_modules/ini
strip-json-comments@2.0.1 /home/pi/.node-red/node_modules/strip-json-comments
simple-get@2.8.1 /home/pi/.node-red/node_modules/simple-get
decompress-response@3.3.0 /home/pi/.node-red/node_modules/decompress-response
mimic-response@1.0.0 /home/pi/.node-red/node_modules/mimic-response
simple-concat@1.0.0 /home/pi/.node-red/node_modules/simple-concat
tar-fs@1.16.2 /home/pi/.node-red/node_modules/tar-fs
chownr@1.0.1 /home/pi/.node-red/node_modules/chownr
pump@1.0.3 /home/pi/.node-red/node_modules/tar-fs/node_modules/pump
tar-stream@1.6.1 /home/pi/.node-red/node_modules/tar-stream
buffer-alloc@1.2.0 /home/pi/.node-red/node_modules/buffer-alloc
buffer-alloc-unsafe@1.1.0 /home/pi/.node-red/node_modules/buffer-alloc-unsafe
buffer-fill@1.0.0 /home/pi/.node-red/node_modules/buffer-fill
fs-constants@1.0.0 /home/pi/.node-red/node_modules/fs-constants
to-buffer@1.1.1 /home/pi/.node-red/node_modules/to-buffer
tunnel-agent@0.6.0 /home/pi/.node-red/node_modules/tunnel-agent
which-pm-runs@1.0.0 /home/pi/.node-red/node_modules/which-pm-runs
promirepl@1.0.1 /home/pi/.node-red/node_modules/promirepl
prompt-list@3.2.0 /home/pi/.node-red/node_modules/prompt-list
ansi-cyan@0.1.1 /home/pi/.node-red/node_modules/ansi-cyan
ansi-wrap@0.1.0 /home/pi/.node-red/node_modules/ansi-wrap
ansi-dim@0.1.1 /home/pi/.node-red/node_modules/ansi-dim
prompt-radio@1.2.1 /home/pi/.node-red/node_modules/prompt-radio
debug@2.6.9 /home/pi/.node-red/node_modules/prompt-radio/node_modules/debug
prompt-checkbox@2.2.0 /home/pi/.node-red/node_modules/prompt-checkbox
debug@2.6.9 /home/pi/.node-red/node_modules/prompt-checkbox/node_modules/debug
prompt-base@4.1.0 /home/pi/.node-red/node_modules/prompt-base
koalas@1.0.2 /home/pi/.node-red/node_modules/koalas
log-utils@0.2.1 /home/pi/.node-red/node_modules/log-utils
ansi-colors@0.2.0 /home/pi/.node-red/node_modules/ansi-colors
ansi-bgblack@0.1.1 /home/pi/.node-red/node_modules/ansi-bgblack
ansi-bgblue@0.1.1 /home/pi/.node-red/node_modules/ansi-bgblue
ansi-bgcyan@0.1.1 /home/pi/.node-red/node_modules/ansi-bgcyan
ansi-bggreen@0.1.1 /home/pi/.node-red/node_modules/ansi-bggreen
ansi-bgmagenta@0.1.1 /home/pi/.node-red/node_modules/ansi-bgmagenta
ansi-bgred@0.1.1 /home/pi/.node-red/node_modules/ansi-bgred
ansi-bgwhite@0.1.1 /home/pi/.node-red/node_modules/ansi-bgwhite
ansi-bgyellow@0.1.1 /home/pi/.node-red/node_modules/ansi-bgyellow
ansi-black@0.1.1 /home/pi/.node-red/node_modules/ansi-black
ansi-blue@0.1.1 /home/pi/.node-red/node_modules/ansi-blue
ansi-bold@0.1.1 /home/pi/.node-red/node_modules/ansi-bold
ansi-gray@0.1.1 /home/pi/.node-red/node_modules/ansi-gray
ansi-green@0.1.1 /home/pi/.node-red/node_modules/ansi-green
ansi-grey@0.1.1 /home/pi/.node-red/node_modules/ansi-grey
ansi-hidden@0.1.1 /home/pi/.node-red/node_modules/ansi-hidden
ansi-inverse@0.1.1 /home/pi/.node-red/node_modules/ansi-inverse
ansi-italic@0.1.1 /home/pi/.node-red/node_modules/ansi-italic
ansi-magenta@0.1.1 /home/pi/.node-red/node_modules/ansi-magenta
ansi-red@0.1.1 /home/pi/.node-red/node_modules/ansi-red
ansi-reset@0.1.1 /home/pi/.node-red/node_modules/ansi-reset
ansi-strikethrough@0.1.1 /home/pi/.node-red/node_modules/ansi-strikethrough
ansi-underline@0.1.1 /home/pi/.node-red/node_modules/ansi-underline
ansi-white@0.1.1 /home/pi/.node-red/node_modules/ansi-white
ansi-yellow@0.1.1 /home/pi/.node-red/node_modules/ansi-yellow
lazy-cache@2.0.2 /home/pi/.node-red/node_modules/lazy-cache
set-getter@0.1.0 /home/pi/.node-red/node_modules/set-getter
to-object-path@0.3.0 /home/pi/.node-red/node_modules/to-object-path
kind-of@3.2.2 /home/pi/.node-red/node_modules/kind-of
is-buffer@1.1.6 /home/pi/.node-red/node_modules/is-buffer
error-symbol@0.1.0 /home/pi/.node-red/node_modules/error-symbol
info-symbol@0.1.0 /home/pi/.node-red/node_modules/info-symbol
log-ok@0.1.1 /home/pi/.node-red/node_modules/log-ok
success-symbol@0.1.0 /home/pi/.node-red/node_modules/success-symbol
time-stamp@1.1.0 /home/pi/.node-red/node_modules/time-stamp
warning-symbol@0.1.0 /home/pi/.node-red/node_modules/warning-symbol
prompt-actions@3.0.2 /home/pi/.node-red/node_modules/prompt-actions
debug@2.6.9 /home/pi/.node-red/node_modules/prompt-actions/node_modules/debug
prompt-question@5.0.2 /home/pi/.node-red/node_modules/prompt-question
clone-deep@1.0.0 /home/pi/.node-red/node_modules/clone-deep
for-own@1.0.0 /home/pi/.node-red/node_modules/for-own
for-in@1.0.2 /home/pi/.node-red/node_modules/for-in
is-plain-object@2.0.4 /home/pi/.node-red/node_modules/is-plain-object
isobject@3.0.1 /home/pi/.node-red/node_modules/isobject
kind-of@5.1.0 /home/pi/.node-red/node_modules/clone-deep/node_modules/kind-of
shallow-clone@1.0.0 /home/pi/.node-red/node_modules/shallow-clone
is-extendable@0.1.1 /home/pi/.node-red/node_modules/is-extendable
kind-of@5.1.0 /home/pi/.node-red/node_modules/shallow-clone/node_modules/kind-of
mixin-object@2.0.1 /home/pi/.node-red/node_modules/mixin-object
for-in@0.1.8 /home/pi/.node-red/node_modules/mixin-object/node_modules/for-in
define-property@1.0.0 /home/pi/.node-red/node_modules/define-property
is-descriptor@1.0.2 /home/pi/.node-red/node_modules/is-descriptor
is-accessor-descriptor@1.0.0 /home/pi/.node-red/node_modules/is-accessor-descriptor
kind-of@6.0.2 /home/pi/.node-red/node_modules/is-accessor-descriptor/node_modules/kind-of
is-data-descriptor@1.0.0 /home/pi/.node-red/node_modules/is-data-descriptor
kind-of@6.0.2 /home/pi/.node-red/node_modules/is-data-descriptor/node_modules/kind-of
kind-of@6.0.2 /home/pi/.node-red/node_modules/is-descriptor/node_modules/kind-of
kind-of@5.1.0 /home/pi/.node-red/node_modules/prompt-question/node_modules/kind-of
prompt-choices@4.1.0 /home/pi/.node-red/node_modules/prompt-choices
arr-flatten@1.1.0 /home/pi/.node-red/node_modules/arr-flatten
arr-swap@1.0.1 /home/pi/.node-red/node_modules/arr-swap
is-number@3.0.0 /home/pi/.node-red/node_modules/arr-swap/node_modules/is-number
choices-separator@2.0.0 /home/pi/.node-red/node_modules/choices-separator
debug@2.6.9 /home/pi/.node-red/node_modules/choices-separator/node_modules/debug
strip-color@0.1.0 /home/pi/.node-red/node_modules/strip-color
clone-deep@4.0.0 /home/pi/.node-red/node_modules/prompt-choices/node_modules/clone-deep
kind-of@6.0.2 /home/pi/.node-red/node_modules/prompt-choices/node_modules/kind-of
shallow-clone@3.0.0 /home/pi/.node-red/node_modules/prompt-choices/node_modules/shallow-clone
collection-visit@1.0.0 /home/pi/.node-red/node_modules/collection-visit
map-visit@1.0.0 /home/pi/.node-red/node_modules/map-visit
object-visit@1.0.1 /home/pi/.node-red/node_modules/object-visit
define-property@2.0.2 /home/pi/.node-red/node_modules/prompt-choices/node_modules/define-property
is-number@6.0.0 /home/pi/.node-red/node_modules/is-number
pointer-symbol@1.0.0 /home/pi/.node-red/node_modules/pointer-symbol
radio-symbol@2.0.0 /home/pi/.node-red/node_modules/radio-symbol
set-value@3.0.0 /home/pi/.node-red/node_modules/set-value
terminal-paginator@2.0.2 /home/pi/.node-red/node_modules/terminal-paginator
debug@2.6.9 /home/pi/.node-red/node_modules/terminal-paginator/node_modules/debug
extend-shallow@2.0.1 /home/pi/.node-red/node_modules/extend-shallow
toggle-array@1.0.1 /home/pi/.node-red/node_modules/toggle-array
readline-ui@2.2.3 /home/pi/.node-red/node_modules/readline-ui
debug@2.6.9 /home/pi/.node-red/node_modules/readline-ui/node_modules/debug
readline-utils@2.2.3 /home/pi/.node-red/node_modules/readline-utils
is-number@3.0.0 /home/pi/.node-red/node_modules/readline-utils/node_modules/is-number
mute-stream@0.0.7 /home/pi/.node-red/node_modules/mute-stream
window-size@1.1.0 /home/pi/.node-red/node_modules/window-size
is-number@3.0.0 /home/pi/.node-red/node_modules/window-size/node_modules/is-number
string-width@2.1.1 /home/pi/.node-red/node_modules/readline-ui/node_modules/string-width
is-fullwidth-code-point@2.0.0 /home/pi/.node-red/node_modules/readline-ui/node_modules/is-fullwidth-code-point
strip-ansi@4.0.0 /home/pi/.node-red/node_modules/readline-ui/node_modules/strip-ansi
ansi-regex@3.0.0 /home/pi/.node-red/node_modules/readline-ui/node_modules/ansi-regex
static-extend@0.1.2 /home/pi/.node-red/node_modules/static-extend
define-property@0.2.5 /home/pi/.node-red/node_modules/static-extend/node_modules/define-property
is-descriptor@0.1.6 /home/pi/.node-red/node_modules/static-extend/node_modules/is-descriptor
is-accessor-descriptor@0.1.6 /home/pi/.node-red/node_modules/static-extend/node_modules/is-accessor-descriptor
kind-of@3.2.2 /home/pi/.node-red/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
is-data-descriptor@0.1.4 /home/pi/.node-red/node_modules/static-extend/node_modules/is-data-descriptor
kind-of@3.2.2 /home/pi/.node-red/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
kind-of@5.1.0 /home/pi/.node-red/node_modules/static-extend/node_modules/kind-of
object-copy@0.1.0 /home/pi/.node-red/node_modules/object-copy
copy-descriptor@0.1.1 /home/pi/.node-red/node_modules/copy-descriptor
define-property@0.2.5 /home/pi/.node-red/node_modules/object-copy/node_modules/define-property
is-descriptor@0.1.6 /home/pi/.node-red/node_modules/object-copy/node_modules/is-descriptor
is-accessor-descriptor@0.1.6 /home/pi/.node-red/node_modules/object-copy/node_modules/is-accessor-descriptor
is-data-descriptor@0.1.4 /home/pi/.node-red/node_modules/object-copy/node_modules/is-data-descriptor
kind-of@5.1.0 /home/pi/.node-red/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
node-red-node-smooth@0.1.0 /home/pi/.node-red/node_modules/node-red-node-smooth
Der Benutzer »pi« ist bereits ein Mitglied der Gruppe »gpio«.
Finished : Son Jun 24 12:31:45 UTC 2018
Due to restrictions I had to delete the first lines (only 32000 char. are allowed). This is the last line since I update as shown on the raspberry I docs
leafboy
I managed to create a screen shot of the messages shown in the console. Would this be helpful?
leafboy
Colin
24 June 2018 15:25
16
I thought you were connected via ssh, so the terminal is running on the PC not the pi. Are the messages flashing past very quickly continuously? If so then node red has not crashed it is just that for some reason you are asking it to run something extremely fast. You should be able to see from the messages what it is that is happening so fast.
You will probably find it much easier if you run the browser on the PC rather than the pi (if that is what you are doing) then the pi does not have to do all the work of running the browser.
Yes - I connect to my Pi via SSH and finally I managed to add a screen shot to my posts. These messages seem quite normal but how can I stop it to maintain other settings. As soon as I start node-red I freezes I no access to node-red is possible. Is it not due to lack of memory that it feezes?
tx
leafboy
Colin
24 June 2018 16:40
18
No, it is most unlikely to be lack of memory.
Please make sure you answer all the questions, you did not say whether the messages on the console are continuously coming very fast - faster than you would expect them to be.
Is that screenshot of a pi screen or a PC screen? You said you are connected via ssh so I assumed it would a screenshot of the PC. I don’t use the graphical interface on the pi at all so I don’t know what it looks like.
Also you say node red is freezing, do the debug messages on the console keep going or do they stop? If they stop then it is the messages when it stops that we need to see. If they don’t stop then node-red is still running.
If the messages don’t stop do you mean that it is the browser that is unresponsive?
Are you running the browser on the pi or on the PC? If you are running it on the pi (which will probably require much more resources than node red does) then try running the browser on the PC by pointing to the ip address of the pi.
By the way you can copy out of the terminal window using Ctrl+Shift+C (at least on some operating systems) so you can paste what you see in logs rather than screenshotting.
As I said, please make sure you answer all the questions.
Sorry for my late and not sufficient answer. I deleted my old flows in the .node-red folder and started all over again. Then I created 10 temp-sensors DS18B20 and injected at every 10s a time stamp. So far it works all fine and the debug messages appear correctly. After adding some nodes to display time and date. Still working fine. But after adding a DHT22 sensor my PI crashed again. No debug messages were given and the connection to my Tablet got lost (connection lost). This is when I have to restart my PI because no further actions were possible after that.
The browser is running on my PI.
The added screenshot above is from my PI before it freezes.
I tried to copy the debug messages but my PI already stopped working only a screenshot of the debug messages was possible. See below.
That does not look as error messages to me. Later on I will try running my browser on the PC.
Hopefully I did answer all your questions. Many thanks for your support it is much appreciated.
tx
Leafboy
What node are you using for the dht22? If it is the node-red-contrib-dht-sensor, did you install the BCM2835 library and node-dht-sensor as it tells you to?
Can you paste in your flow now?
