Example of my flow:
"id": "afdcbda3.a9446",
"type": "tab",
"label": "SAT",
"disabled": false,
"info": ""
"id": "5afe9c8c.a732e4",
"type": "switch",
"z": "afdcbda3.a9446",
"property": "payload",
"propertyType": "msg",
"rules": [
"t": "cont",
"v": "false",
"vt": "str"
"t": "cont",
"v": "true",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 690,
"y": 180,
"11a25fa4.9147c"
"38c0ce3c.a950b2"
"id": "da00ea5e.6b62f8",
"type": "mqtt in",
"name": "HC2",
"topic": "home/command/#",
"qos": "2",
"datatype": "auto",
"broker": "3629b28a.9a237e",
"x": 130,
"y": 60,
"id": "89a46413.2b00a8",
"type": "nora-switch",
"devicename": "TV",
"roomhint": "",
"passthru": true,
"nora": "df7a24c4.66de68",
"topic": "",
"onvalue": "true",
"onvalueType": "bool",
"offvalue": "false",
"offvalueType": "bool",
"x": 390,
"y": 360,
"3db62e78.e64a32"
"id": "ea782773.ce8968",
"type": "switch",
"rules": [
"t": "true"
"t": "false"
"checkall": "true",
"repair": false,
"outputs": 2,
"x": 550,
"y": 360,
"d8610977.a29678"
"749ae28d.93107c"
"id": "d8610977.a29678",
"type": "http request",
"name": "SAT On",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/powerstate?newstate=4",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 720,
"y": 320,
"579f68fe.a43c48"
"id": "749ae28d.93107c",
"name": "SAT Off",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/powerstate?newstate=5",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 720,
"y": 380,
"579f68fe.a43c48"
"id": "2107a91c.d72156",
"type": "inject",
"topic": "",
"payload": "true",
"payloadType": "bool",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 250,
"y": 340,
"89a46413.2b00a8"
"id": "f4e0c143.065f6",
"type": "inject",
"topic": "",
"payload": "false",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 250,
"y": 400,
"89a46413.2b00a8"
"id": "34938bc3.b47f14",
"name": "SAT Status",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/powerstate",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 550,
"y": 200,
"5afe9c8c.a732e4"
"id": "11a25fa4.9147c",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "true",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 860,
"y": 160,
"89a46413.2b00a8"
"id": "38c0ce3c.a950b2",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 860,
"y": 200,
"89a46413.2b00a8"
"id": "579f68fe.a43c48",
"type": "delay",
"pauseType": "delay",
"timeout": "2",
"timeoutUnits": "seconds",
"rate": "1",
"nbRateUnits": "1",
"rateUnits": "second",
"randomFirst": "1",
"randomLast": "5",
"randomUnits": "seconds",
"drop": false,
"x": 380,
"y": 200,
"34938bc3.b47f14"
"id": "563b4673.7372c8",
"type": "inject",
"topic": "",
"payload": "",
"payloadType": "date",
"repeat": "10",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 190,
"y": 180,
"579f68fe.a43c48"
"id": "3db62e78.e64a32",
"type": "rbe",
"func": "rbei",
"gap": "",
"start": "",
"inout": "out",
"x": 440,
"y": 460,
"ea782773.ce8968"
"id": "9778bffa.544bb",
"name": "SAT Vol Up",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/remotecontrol?command=115",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 710,
"y": 800,
"8516d6f2.c10e58",
"b7ea5d9e.df965",
"89ebb28e.992e1"
"id": "5fbd81eb.86ccd",
"name": "SAT Vol Dw",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/remotecontrol?command=114",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 710,
"y": 960,
"947afb07.eee5b8",
"3c01d4d9.eaeefc",
"884e7240.e1c4e"
"id": "a50714db.df9658",
"name": "SAT Vol Mute",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/remotecontrol?command=113",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 720,
"y": 620,
"id": "f578101f.9078a",
"devicename": "Silence",
"roomhint": "",
"passthru": true,
"topic": "",
"onvalue": "true",
"x": 410,
"y": 620,
"b10a33b8.c7eee"
"id": "984e6990.ca3c38",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 420,
"y": 720,
"f578101f.9078a"
"id": "b10a33b8.c7eee",
"type": "switch",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 570,
"y": 620,
"a50714db.df9658",
"984e6990.ca3c38"
"id": "60099893.3ba2c8",
"devicename": "Voice Up",
"roomhint": "",
"passthru": true,
"topic": "",
"onvalue": "true",
"x": 400,
"y": 800,
"5f697f04.8112d"
"id": "be90b6df.685a18",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 410,
"y": 900,
"60099893.3ba2c8"
"id": "5f697f04.8112d",
"type": "switch",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 560,
"y": 800,
"9778bffa.544bb",
"be90b6df.685a18"
"id": "d2921067.04c09",
"devicename": "Voice Down",
"roomhint": "",
"passthru": true,
"topic": "",
"onvalue": "true",
"x": 410,
"y": 960,
"623d7ba8.820c44"
"id": "635d17dd.e91fc8",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 410,
"y": 1060,
"d2921067.04c09"
"id": "623d7ba8.820c44",
"type": "switch",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 560,
"y": 960,
"5fbd81eb.86ccd",
"635d17dd.e91fc8"
"id": "d910adb1.08721",
"type": "inject",
"topic": "",
"payload": "true",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 190,
"y": 620,
"f578101f.9078a"
"id": "8b9d5661.d61e48",
"type": "inject",
"topic": "",
"payload": "true",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 190,
"y": 800,
"60099893.3ba2c8"
"id": "859089ae.b525a8",
"type": "inject",
"topic": "",
"payload": "true",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 190,
"y": 960,
"d2921067.04c09"
"id": "9c443524.f79758",
"type": "debug",
"active": false,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "false",
"x": 1090,
"y": 720,
"id": "ff9fd1cc.97234",
"type": "switch",
"name": "Programy",
"rules": [
"t": "eq",
"v": "",
"vt": "str"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 1020,
"y": 440,
"id": "8083adc7.306e4",
"type": "nora-light",
"devicename": "number",
"lightcolor": false,
"brightnesscontrol": true,
"passthru": false,
"statepayload": true,
"brightnessoverride": "",
"roomhint": "",
"topic": "",
"onvalue": "true",
"x": 900,
"y": 620,
"4e628663.af28f8"
"id": "4e628663.af28f8",
"type": "function",
"name": "kanal",
"func": "msg.payload = msg.payload.brightness\nreturn msg;",
"outputs": 1,
"noerr": 0,
"x": 890,
"y": 720,
"9c443524.f79758",
"b83150ed.e807"
"id": "b83150ed.e807",
"type": "exec",
"command": "/home/pi/.scripts/channel.sh ",
"addpay": true,
"append": "",
"useSpawn": "false",
"timer": "",
"oldrc": false,
"name": "set N program",
"x": 1100,
"y": 820,
"9c443524.f79758"
"9c443524.f79758"
"9c443524.f79758"
"id": "da2afc59.1878a",
"type": "ftp-download",
"server": "4ddcf12c.ac8ca",
"files": "/etc/enigma2/userbouquet.vh21.tv",
"directory": "/home/pi/.scripts",
"output": "payload",
"filesType": "str",
"directoryType": "str",
"x": 1060,
"y": 560,
"9c443524.f79758"
"id": "5f10ac7a.b75334",
"type": "inject",
"name": "Refresh channels",
"topic": "",
"payload": "",
"repeat": "",
"crontab": "00 07 * * *",
"once": false,
"onceDelay": 0.1,
"x": 790,
"y": 560,
"da2afc59.1878a"
"id": "182cd0a.703c72f",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 870,
"y": 880,
"id": "fdb77746.4cbb78",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 870,
"y": 840,
"id": "8516d6f2.c10e58",
"type": "delay",
"timeout": "2",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 720,
"y": 840,
"fdb77746.4cbb78"
"id": "b7ea5d9e.df965",
"type": "delay",
"timeout": "4",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 720,
"y": 880,
"182cd0a.703c72f"
"id": "79100498.601d4c",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 870,
"y": 920,
"id": "89ebb28e.992e1",
"type": "delay",
"timeout": "6",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 720,
"y": 920,
"79100498.601d4c"
"id": "1193b3c3.bf674c",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 870,
"y": 1080,
"id": "d3533f68.d052d",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 870,
"y": 1040,
"id": "c4e87fda.438dc",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 870,
"y": 1000,
"id": "947afb07.eee5b8",
"type": "delay",
"timeout": "2",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 720,
"y": 1000,
"c4e87fda.438dc"
"id": "3c01d4d9.eaeefc",
"type": "delay",
"timeout": "4",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 720,
"y": 1040,
"d3533f68.d052d"
"id": "884e7240.e1c4e",
"type": "delay",
"timeout": "6",
"rate": "1",
"nbRateUnits": "1",
"randomFirst": "1",
"randomLast": "5",
"drop": false,
"x": 720,
"y": 1080,
"1193b3c3.bf674c"
"id": "a8746438.cebcd8",
"name": "SAT Ch Up",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/remotecontrol?command=402",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 710,
"y": 1140,
"id": "200d4801.4e8f48",
"name": "SAT Ch Dw",
"method": "GET",
"ret": "txt",
"paytoqs": false,
"url": "http://192.168.1.65/web/remotecontrol?command=403",
"tls": "",
"persist": false,
"proxy": "",
"authType": "",
"x": 710,
"y": 1300,
"id": "ee2a14cc.b8cf68",
"devicename": "Channel Up",
"roomhint": "",
"passthru": true,
"topic": "",
"onvalue": "true",
"x": 410,
"y": 1140,
"fa7eab71.1359a8"
"id": "acd272c6.3dbfd",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 410,
"y": 1240,
"ee2a14cc.b8cf68"
"id": "fa7eab71.1359a8",
"type": "switch",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 560,
"y": 1140,
"a8746438.cebcd8",
"acd272c6.3dbfd"
"id": "88bcb5bc.97d208",
"devicename": "Channel Down",
"roomhint": "",
"passthru": true,
"topic": "",
"onvalue": "true",
"x": 420,
"y": 1300,
"e327bfc0.5c3ca"
"id": "8b84b9f3.01b838",
"type": "change",
"rules": [
"t": "set",
"p": "payload",
"pt": "msg",
"to": "false",
"tot": "bool"
"action": "",
"property": "",
"from": "",
"to": "",
"reg": false,
"x": 410,
"y": 1400,
"88bcb5bc.97d208"
"id": "e327bfc0.5c3ca",
"type": "switch",
"rules": [
"t": "true"
"checkall": "true",
"repair": false,
"outputs": 1,
"x": 560,
"y": 1300,
"200d4801.4e8f48",
"8b84b9f3.01b838"
"id": "e3763f17.c6a45",
"type": "inject",
"topic": "",
"payload": "true",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 190,
"y": 1140,
"ee2a14cc.b8cf68"
"id": "dde3c9bb.86af28",
"type": "inject",
"topic": "",
"payload": "true",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 190,
"y": 1300,
"88bcb5bc.97d208"
"id": "3629b28a.9a237e",
"type": "mqtt-broker",
"z": "",
"name": "pi4",
"broker": "192.168.1.10",
"port": "1883",
"tls": "",
"clientid": "",
"usetls": false,
"compatmode": true,
"keepalive": "60",
"cleansession": true,
"birthTopic": "",
"birthQos": "0",
"birthPayload": "",
"closeTopic": "",
"closeQos": "0",
"closePayload": "",
"willTopic": "",
"willQos": "0",
"willPayload": ""
"id": "df7a24c4.66de68",
"type": "nora-config",
"z": "",
"name": "nora config",
"group": "",
"notify": false
"id": "4ddcf12c.ac8ca",
"type": "ftp-download-server",
"z": "",
"host": "192.168.1.65",
"port": "21",
"user": "satinfo",
"connTimeout": "10000",
"pasvTimeout": "10000",
"keepalive": "10000",
"name": "SAT"
