Node-red Json to database writing
Hello everybody,
i am a newbie in node-red. I want to use it to write a json file into a PostgreSQL database, where the json file should be divided into different tables and written in a database. Is there an easy way to do that?
example json file:
{ 'location': 100 ,
'job_id': 1,
'operator': 'Jenny',
'curve': {'time_series':[1,2,3,4,5,6], 'Momentum':[1,2,3,4,5,6]},
I want a table of:
data with columns location, job_id, operator curve and another table named curve with columns time_series and Momentum, is that possible with Node-Red.
Most definitely.
Something to get you started...
demo flow (use CTRL+I to import)
[{"id":"9358d3d721f4b18f","type":"inject","z":"85e1791bc0cd6285","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"location\":100,\"job_id\":1,\"operator\":\"Jenny\",\"curve\":{\"time_series\":[1,2,3,4,5,6],\"Momentum\":[1,2,3,4,5,6]}}","payloadType":"json","x":2330,"y":1282,"wires":[["e974f54d76d72765"]]},{"id":"e974f54d76d72765","type":"change","z":"85e1791bc0cd6285","name":"","rules":[{"t":"move","p":"payload.curve","pt":"msg","to":"curve","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2362,"y":1334,"wires":[["4feffe5c5fd46429","e4936e949e7d4801"]]},{"id":"4feffe5c5fd46429","type":"function","z":"85e1791bc0cd6285","name":"Built insert Query","func":"msg.payload =  `INSERT INTO t1 (location, job_id, operator)\nVALUES (${msg.payload.location}, ${msg.payload.job_id}, '${msg.payload.operator}')`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2632,"y":1334,"wires":[["ab0bcbd8a6aff070"]]},{"id":"e4936e949e7d4801","type":"function","z":"85e1791bc0cd6285","name":"Built insert Query2","func":"\nconst ts = JSON.stringify(msg.curve.time_series)\nconst mom = JSON.stringify(msg.curve.Momentum)\nmsg.payload =  `INSERT INTO t2 (time_series, Momentum)\nVALUES ($'{ts}', '${mom}')`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2632,"y":1394,"wires":[["4666a71a77e9d22a"]]},{"id":"ab0bcbd8a6aff070","type":"debug","z":"85e1791bc0cd6285","name":"To Database →","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":2862,"y":1334,"wires":[]},{"id":"4666a71a77e9d22a","type":"debug","z":"85e1791bc0cd6285","name":"To Database →","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":2862,"y":1394,"wires":[]}]
PS
in order to make code readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
PS2
As a new user, I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
