Hey,
I am new to node red and have no experience with it. So my questions are: How can I write a JSON-Message and integrate it into an insert-statement? Furthermore, how can i transfer a Message into a Postgres Database?
Code:
[{"id":"43a7968a456ad836","type":"inject","z":"bba055f91ed61523","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"hello\":\"word\"}","payloadType":"json","x":350,"y":560,"wires":[["b1c5f77a335127f4"]]},{"id":"b1c5f77a335127f4","type":"postgresql","z":"bba055f91ed61523","name":"","query":"INSERT INTO table_name(column1)\nVALUES ('{{{payload.hello}}}');","postgreSQLConfig":"1e4da63817fa609c","split":false,"rowsPerMsg":1,"outputs":1,"x":570,"y":560,"wires":[["14946f51cb515194"]]},{"id":"14946f51cb515194","type":"debug","z":"bba055f91ed61523","name":"debug 77","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":770,"y":560,"wires":[]},{"id":"1e4da63817fa609c","type":"postgreSQLConfig","name":"","host":"localhost","hostFieldType":"str","port":"5432","portFieldType":"num","database":"postgres","databaseFieldType":"str","ssl":"true","sslFieldType":"bool","applicationName":"","applicationNameType":"str","max":"10","maxFieldType":"num","idle":"1000","idleFieldType":"num","connectionTimeout":"10000","connectionTimeoutFieldType":"num","user":"username","userFieldType":"str","password":"password","passwordFieldType":"str"}]
You need to install this node:
node-postgresql
exemple insert:
Thank you very much for your help.
When i try to deploy it, i get a "Error: certificate has expired" Message. Do you know how i can resolve it?
I don't understand at what node you received this message?
The Error occurs at the postresql node.
I see that you have specified SSL true in the server node config. I haven't used that node, but I wonder whether that is part of the problem. Did you intentionally set SSL?
