Most definitely.
Something to get you started...
demo flow (use CTRL+I to import)
[{"id":"9358d3d721f4b18f","type":"inject","z":"85e1791bc0cd6285","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"{\"location\":100,\"job_id\":1,\"operator\":\"Jenny\",\"curve\":{\"time_series\":[1,2,3,4,5,6],\"Momentum\":[1,2,3,4,5,6]}}","payloadType":"json","x":2330,"y":1282,"wires":[["e974f54d76d72765"]]},{"id":"e974f54d76d72765","type":"change","z":"85e1791bc0cd6285","name":"","rules":[{"t":"move","p":"payload.curve","pt":"msg","to":"curve","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":2362,"y":1334,"wires":[["4feffe5c5fd46429","e4936e949e7d4801"]]},{"id":"4feffe5c5fd46429","type":"function","z":"85e1791bc0cd6285","name":"Built insert Query","func":"msg.payload = `INSERT INTO t1 (location, job_id, operator)\nVALUES (${msg.payload.location}, ${msg.payload.job_id}, '${msg.payload.operator}')`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2632,"y":1334,"wires":[["ab0bcbd8a6aff070"]]},{"id":"e4936e949e7d4801","type":"function","z":"85e1791bc0cd6285","name":"Built insert Query2","func":"\nconst ts = JSON.stringify(msg.curve.time_series)\nconst mom = JSON.stringify(msg.curve.Momentum)\nmsg.payload = `INSERT INTO t2 (time_series, Momentum)\nVALUES ($'{ts}', '${mom}')`\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":2632,"y":1394,"wires":[["4666a71a77e9d22a"]]},{"id":"ab0bcbd8a6aff070","type":"debug","z":"85e1791bc0cd6285","name":"To Database →","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":2862,"y":1334,"wires":[]},{"id":"4666a71a77e9d22a","type":"debug","z":"85e1791bc0cd6285","name":"To Database →","active":true,"tosidebar":true,"console":false,"tostatus":true,"complete":"payload","targetType":"msg","statusVal":"payload","statusType":"auto","x":2862,"y":1394,"wires":[]}]
PS
in order to make code readable and importable it is important to surround your code with three backticks
like this
You can edit and correct your post by clicking the pencil icon.
PS2
As a new user, I recommend watching this playlist: Node-RED Essentials. The videos are done by the developers of node-red. They're nice & short and to the point. You will understand a whole lot more in about 1 hour. A small investment for a lot of gain.
