Node-red keeps restarting
I am new to node-red. I try to use node-red-contrib-viseo.
Everything was fine at first but now I am stuck with node-red rebooting all the time.
I thought my flow somehow get corrupted so it rename flows.json temporary as flows.json.bak but the same error keeps occuring.
0|MyFirstBot | Welcome to Node-RED
0|MyFirstBot | ===================
0|MyFirstBot | 5 Nov 13:32:50 - [info] Node-RED version: v0.17.5
0|MyFirstBot | 5 Nov 13:32:50 - [info] Node.js version: v8.12.0
0|MyFirstBot | 5 Nov 13:32:50 - [info] Linux 4.4.0-138-generic x64 LE
0|MyFirstBot | 5 Nov 13:32:50 - [info] Loading palette nodes
0|MyFirstBot | Loading locale: default for /home/godestalbin/mybot/bot/data/locales/default.json
0|MyFirstBot | ###
0|MyFirstBot | ### The "request" library is not installed automatically anymore.
0|MyFirstBot | ### But required by "request-promise".
0|MyFirstBot | ###
0|MyFirstBot | ### npm install request --save
0|MyFirstBot | ###
0|MyFirstBot | 5 Nov 13:33:01 - [warn] ------------------------------------------------------
0|MyFirstBot | 5 Nov 13:33:01 - [warn] [rpi-gpio] Info : Ignoring Raspberry Pi specific node
0|MyFirstBot | 5 Nov 13:33:01 - [warn] [dialogflow] Error: Cannot find module 'request' (line:4)
0|MyFirstBot | 5 Nov 13:33:01 - [warn] [log-sqlite] Error: Cannot find module 'sqlite3' (line:5)
0|MyFirstBot | 5 Nov 13:33:01 - [warn] [salesforce-cc-object] Error: /home/godestalbin/mybot/framework/node_modules/node-red-contrib-viseo-salesforce/node-salesforce-cc-object.html does not exist
0|MyFirstBot | 5 Nov 13:33:01 - [warn] [salesforce-cc-config] Error: /home/godestalbin/mybot/framework/node_modules/node-red-contrib-viseo-salesforce/node-salesforce-cc-config.html does not exist
0|MyFirstBot | 5 Nov 13:33:01 - [info] Settings file : /home/godestalbin/mybot/framework/conf/node-red-config.js
0|MyFirstBot | 5 Nov 13:33:01 - [info] User directory : /home/godestalbin/mybot/bot/data/
0|MyFirstBot | 5 Nov 13:33:01 - [info] Flows file : /home/godestalbin/mybot/bot/data/flows.json
0|MyFirstB | 5 Nov 13:32:47 - [info] Settings file : /home/godestalbin/mybot/framework/conf/node-red-config.js
0|MyFirstB | 5 Nov 13:32:47 - [info] User directory : /home/godestalbin/mybot/bot/data/
0|MyFirstB | 5 Nov 13:32:47 - [info] Flows file : /home/godestalbin/mybot/bot/data/flows.json
0|MyFirstB | 5 Nov 13:32:47 - [info] Server now running at http://127.0.0.1:1880/
0|MyFirstB | 5 Nov 13:32:47 - [info] Starting flows
0|MyFirstB | Missing server configuration, fallback on Node-RED server
0|MyFirstB | 5 Nov 13:32:47 - [info] Started flows
0|MyFirstBot | TypeError: Cannot read property 'getSessions' of undefined
0|MyFirstBot | at loadSessions (/home/godestalbin/mybot/framework/node_modules/node-red/red/api/auth/tokens.js:57:34)
0|MyFirstBot | at Object.get (/home/godestalbin/mybot/framework/node_modules/node-red/red/api/auth/tokens.js:75:16)
0|MyFirstBot | at WebSocket. (/home/godestalbin/mybot/framework/node_modules/node-red/red/api/comms.js:114:36)
0|MyFirstBot | at emitTwo (events.js:126:13)
0|MyFirstBot | at WebSocket.emit (events.js:214:7)
0|MyFirstBot | at Receiver.ontext (/home/godestalbin/mybot/framework/node_modules/ws/lib/WebSocket.js:841:10)
0|MyFirstBot | at /home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:536:18
0|MyFirstBot | at Receiver.applyExtensions (/home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:371:5)
0|MyFirstBot | at /home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:508:14
0|MyFirstBot | at Receiver.flush (/home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:347:3)
0|MyFirstBot | at Receiver.finish (/home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:541:12)
0|MyFirstBot | at Receiver.expectHandler (/home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:493:33)
0|MyFirstBot | at Receiver.add (/home/godestalbin/mybot/framework/node_modules/ws/lib/Receiver.js:103:24)
0|MyFirstBot | at Socket.realHandler (/home/godestalbin/mybot/framework/node_modules/ws/lib/WebSocket.js:825:20)
0|MyFirstBot | at emitOne (events.js:116:13)
0|MyFirstBot | at Socket.emit (events.js:211:7)
0|MyFirstBot | at addChunk (_stream_readable.js:263:12)
0|MyFirstBot | at readableAddChunk (_stream_readable.js:250:11)
0|MyFirstBot | at Socket.Readable.push (_stream_readable.js:208:10)
0|MyFirstBot | at TCP.onread (net.js:601:20)
0|MyFirstBot | 5 Nov 13:32:49 - [red] Uncaught Exception:
0|MyFirstBot | 5 Nov 13:32:49 - TypeError: Cannot read property 'getSessions' of undefined
PM2 | App [MyFirstBot:0] exited with code [1] via signal [SIGINT]
PM2 | App [MyFirstBot:0] starting in -fork mode-
PM2 | App [MyFirstBot:0] online
You cut out the version of Node-RED and nodejs you are using.
I updated my post with the beginning of the log showing node-red version: Node.js version: v8.12.0
You are on a very old version of Node-RED - v0.17.5 0- the current release is v0.19.5
Is there a reason you are so far behind?
What OS?
You need to sort out the errors at the start of the log. I suggest starting by using npm to install request as it suggests. I don't recognise the directory structure you have so I don't know which folder you should go to in order to install it. Is it a Mac? If so then possibly someone who uses Macs can advise.
I installed node-red using the Documentation from node-red-contrib-viseo
I tried to update node-red using npm install -g --unsafe-perm node-red but I still see v0.17.5 0 in my logs.
I've had problems with viseo before. The author tends to make too many assumptions. I believe he wrote the node to be part of a custom installation for his customers. He assumes that you are using his custom installation and not a standard node-red installation.
So if you are still seeing the different version of Node-RED, I think it likely that you are running his custom install version rather than your global version.
Given this the best route is probably to open an issue on the github page you linked to.
