Node-red modbus
I am trying to turn on a LED using node-red.
I have attached a LED to a PIN in PLC ( %Q0.0) .
I have made the configuration in modbus-write node accordingly as shown in screenshots below. but Its not working for some reason.
any help is appreciated.
with warm regards
This is the flow.
I have used a trigger node for sending high for 3 seconds.
This is the configuration for modbus-write node. ( Address 1 corresponds to %Qx0.0 in my openPLC )
Screenshot%20from%202019-01-11%2005-19-58
I see that you asked the same question in OpenPLC forum a couple of days ago.
Your statement that "Address 1 corresponds to %Qx0.0 in my openPLC" conflicts with the reply you received.
Did you try changing your Modbus address in Node-RED contrib node for testing ?
%Qx0.0 in OpenPLC = Modbus address 0 in modbus contrib node.
Or perhaps trying to use for instnace %Qx0.3 in OpenPLC and Modbus address 3 in modbus contrib node ?
There are many other posts in OpenPLC forum explaining config , using pins in raspberry pi , priority of ladder logic over Modbus, etc...
Thanks it worked. :wink:
