Node-red-node-annotate-image - using canvas
While playing with the Good-I-Deer nodes, I wanted to visualise the output, so I used the above node, however it is very slow (no offence @dceejay @knolleary ) :grinning:
So with some help from chat-GPT I modified it to work with canvas instead, and it really is so much faster.
Has anyone else done something similar ?
I couldn't seem to find any other nodes, please do let me know if I missed something.
Is there any likely hood of an alternative "core" node using canvas ?
I'm no expert with creating a new node etc, so for now I just edited annotate.js directly in node_modules.
Would be interested to hear others thought about this.
If what you are doing is likely to be fairly one-off (e.g. just in 1 node-red instance), then it is a good idea to start by applying the external library to a function node and doing the processing in that.
You can always move the processing to a custom node at some later point (or raise a PR against an existing node if the authors are happy) but if you don't ever need to re-use or share then a function node is surely fine.
I'm sure a Pull Request to the core node would be much appreciated.
I had assumed that using the pureimage package was a conscious decision, perhaps as I have read, that canvas can be difficult to install on some systems ?
If not then its not difficult to change the code, but not sure about having canvas install correctly on different system automatically.
After modifying annotate.js to work with canvas, I installed the pre requisites listed for Ubuntu and did --build-from-source on my Pi as detailed here -
Modified code - added bonus now also works with PNG and GIF files
module.exports = function(RED) {
    "use strict";
    const { createCanvas, loadImage, registerFont } = require("canvas");
    const path = require("path");
    let fontLoaded = false;
    function loadFont() {
        if (!fontLoaded) {
            registerFont(path.join(__dirname,'./SourceSansPro-Regular.ttf'), { family: 'Source Sans Pro' });
            fontLoaded = true;
    function AnnotateNode(n) {
        RED.nodes.createNode(this, n);
        var node = this;
        const defaultFill = n.fill || "";
        const defaultStroke = n.stroke || "#ffC000";
        const defaultLineWidth = parseInt(n.lineWidth) || 5;
        const defaultFontSize = n.fontSize || 24;
        const defaultFontColor = n.fontColor || "#ffC000";
        loadFont();
        this.on("input", function(msg) {
            if (Buffer.isBuffer(msg.payload)) {
				   if (Array.isArray(msg.annotations) && msg.annotations.length > 0) {
                    const buffer = Buffer.from(msg.payload);
                    loadImage(buffer).then(img => {
                        const canvas = createCanvas(img.width, img.height);
                        const ctx = canvas.getContext('2d');
                        ctx.drawImage(img, 0, 0);
                        ctx.lineJoin = 'bevel';
                        msg.annotations.forEach(function(annotation) {
                            ctx.fillStyle = annotation.fill || defaultFill;
                            ctx.strokeStyle = annotation.stroke || defaultStroke;
                            ctx.lineWidth = annotation.lineWidth || defaultLineWidth;
                            let x, y, r, w, h;
                            if (!annotation.type && annotation.bbox) {
                                annotation.type = 'rect';
                            switch (annotation.type) {
                                case 'rect':
                                    if (annotation.bbox) {
                                        x = annotation.bbox[0];
                                        y = annotation.bbox[1];
                                        w = annotation.bbox[2];
                                        h = annotation.bbox[3];
                                    } else {
                                        x = annotation.x;
                                        y = annotation.y;
                                        w = annotation.w;
                                        h = annotation.h;
                                    if (x < 0) {
                                        w += x;
                                        x = 0;
                                    if (y < 0) {
                                        h += y;
                                        y = 0;
                                    ctx.beginPath();
                                    ctx.rect(x, y, w, h);
                                    ctx.stroke();
                                    if (annotation.label) {
                                        ctx.font = `${annotation.fontSize || defaultFontSize}px 'Source Sans Pro'`;
                                        ctx.fillStyle = annotation.fontColor || defaultFontColor;
                                        ctx.textBaseline = "top";
                                        ctx.textAlign = "left";
                                        if (annotation.labelLocation) {
                                            if (annotation.labelLocation === "top") {
                                                y = y - (20 + ((defaultLineWidth * 0.5) + Number(defaultFontSize)));
                                                if (y < 0) y = 0;
                                            } else if (annotation.labelLocation === "bottom") {
                                                y = y + (10 + h + ((defaultLineWidth * 0.5) + Number(defaultFontSize)));
                                                ctx.textBaseline = "bottom";
                                        } else {
                                            if (y < 0 + (20 + ((defaultLineWidth * 0.5) + Number(defaultFontSize)))) {
                                            } else {
                                                if (y < 0) y = 0;
                                        ctx.fillText(annotation.label, x, y);
                                    break;
                                case 'circle':
                                        x = annotation.bbox[0] + annotation.bbox[2] / 2;
                                        y = annotation.bbox[1] + annotation.bbox[3] / 2;
                                        r = Math.min(annotation.bbox[2], annotation.bbox[3]) / 2;
                                    } else {
                                        x = annotation.x;
                                        y = annotation.y;
                                        r = annotation.r;
                                    ctx.beginPath();
                                    ctx.arc(x, y, r, 0, Math.PI * 2);
                                    ctx.stroke();
                                        ctx.textBaseline = "middle";
                                        ctx.textAlign = "center";
                                    break;
                        const outputBuffer = canvas.toBuffer('image/jpeg', { quality: 0.9 });
                        msg.payload = outputBuffer;
                        node.send(msg);
                    }).catch(err => {
                        node.error(err, msg);
                } else {
                    node.send(msg);
            } else {
                node.error("Payload not a Buffer", msg);
    RED.nodes.registerType("annotate-image", AnnotateNode);
Julian, I have been using that approach also to make changes to @BartButenaers Image info node :wink:
This then allowed me to get rid of 2 of the dependencies by including their code in the function node.
I have also "hacked" the good-I-deer face detection node to output both image buffers and found object data in the output, as by default it is one or the other. So that may be a good candidate for transferring to a function node as well.
@dceejay @knolleary
Do you have any interest in modifying the core node for canvas ? (as above)
I created a fork for testing but it's not my area of expertise, so just interested to know before I spend more time on it.
Pros -
  • Depending on image size can be from 18 to 30 times faster
  • Supports PNG JPG and GIF
Cons -
  • I understand that canvas can be "difficult" to install in some environments ?
