G'day,
I was wanting to add a header in an email sent via the node-red-node-email node but I am having trouble with the format of the headers element.
I have tried both a simple string "X-header-name: value" and a JSON object {"X-header-name": "value"} but they are not coming through with the email.
Is there some other format that the underlying nodemailer library is requiring?
Thanks for any input on this.
E1cid
2
Reading the help text the "X-header-name" should be sent in msg.headers
eg
in a change node
set msg. headers["X-header-name"]
to value string value
In a function node
msg.headers = {};
msg.headers["X-header-name"] = "value";
Thanks @E1cid
I tried a setting the header in that way in an inject node and also in a function node.
Both present like this in a debug:
headers: object
X-header-name: "value"
But the header is not included in the email received.
Quite strange.
Could you try something:
- Edit your email node & remove the email address.
- In your function, set
msg.to = "the_email@address" (where the_email@address is the email removed from step 1)
I don't know why but it seems headers won't be sent if the to field is set: node-red-nodes/social/email/61-email.js at ea48b6acdd469d8c790503459c3f96994e3eab9b Ā· node-red/node-red-nodes Ā· GitHub
@dceejay any thoughts on this ^?
TBH. No idea. Must have been a reason back in the mists of timeā¦. But canāt recall now.
G'day Steve,
Thanks for the suggestion.
That works.
Regards,
Christopher
